Stuart SS
Stuart SS
Australia (FNQ)
18 registered members (Alan_nc), 208 guests, and 229 spiders.
10173 Registered Users
Lannis 95
reverb 83
Stuart 77
NickL 67
koan58 61
551,205 mail-order LSR
Topics66,571
Posts645,378
Members10,173
Amal Pilot Jet #720252
12/28/17 3:08 pm
12/28/17 3:08 pm
USA
Thunderlizard Offline OP
USA
Hello, I am working on an AMAL 928 for a single carb BSA A65. it has the removable pilot jet under the rim of the float bowl. I have read that this was changed to the fixed orifice behind the air bleed screw due to issues with the location of the removable jet.
How much of an issue is the removable jet, is it worth rebuilding this carb or should I look for one with the fixed orifice?
thanks for your help,
Randy
Re: Amal Pilot Jet [Re: Thunderlizard] #720254
12/28/17 4:13 pm
12/28/17 4:13 pm
The position of the pilot jet in the float bowel area was suited to 2 stokes, the pilot bush was suited to 4 strokes but how much improvement you got from the change differed from engine to engine with Triumph 500's showing the biggest improvement. If you don't have any issues carb wise currently then leave as is.
Re: Amal Pilot Jet [Re: Thunderlizard] #720258
12/28/17 4:37 pm
12/28/17 4:37 pm
Tridentman Offline
Tridentman  Offline
+1 with Kommando.
I would advise making the decision ref possible carb replacement based on the overall condition of the carb--not just the pilot jet position.
If the carb is the original one--as it sounds as if it might well be--then look carefully at bore wear. fit of slide in body etc etc.
You will also certainly need a new needle and needle jet.
In figuring out exactly what you need to refurb the existing carb and how much it costs you could well find that you are close to the price of a new Premier carb-- which should solve all carb issues at a stroke (only one stroke!--no pun intended!).
Re: Amal Pilot Jet [Re: Thunderlizard] #720259
12/28/17 4:38 pm
12/28/17 4:38 pm
John Healy Offline
John Healy  Offline
As Kommando stated, but before you go running off check the body and see if there is an other pilot jet pressed into the body. People add the second jet thinking it is missing. Several aftermarket manuals illustrate the screwed in jet and confuse people.
Also the screwed in jet could have been screwed in after the original pressed in jet was enlarged too big. This can happen while poking to clean it out or intentionally.
Re: Amal Pilot Jet [Re: Thunderlizard] #720271
12/28/17 6:17 pm
12/28/17 6:17 pm
They also don’t run right if you have a perfectly fine pressed in jet and a screwed in jet.
I used to find the engine wanted to die when shutting off with the screw in jet, the presses in jet sorted this. The premier carb is a nice upgrade!
Re: Amal Pilot Jet [Re: Thunderlizard] #720295
12/28/17 9:00 pm
12/28/17 9:00 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
When checking the carb for wear first look at the slide, it will show wear marks on the front and back. AMAL concentrics had rather a lot of play in the slides when they were new
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Amal Pilot Jet [Re: Andy Higham] #720299
12/28/17 9:49 pm
12/28/17 9:49 pm
USA
USA
Thank you for the responses. the carb is original to the bike, it had about 5K miles on it when it went out of service. I never heard the bike run. it now has a 71 tbolt engine in it.
the carb does not have the pressed in idle jet only the threaded one and as I understand it that's how they came in 68. the flange is straight, slide is a fairly good fit with some scratches but definitely serviceable. all parts are in pretty good shape.
I would have headed straight for a new carb but I already have all of the parts to rebuild this one, just need to know if it is going to give me idle and low speed problems with the screw in jet vs the pressed in one.
is it possible to get the pressed in jet and install it in this carb?
Randy
Re: Amal Pilot Jet [Re: Thunderlizard] #720309
12/28/17 11:09 pm
12/28/17 11:09 pm
Pilot Restricting Jet - Non-Changeable
Product No: 622/107
Out of stock on Snaps site but others may have it.
Re: Amal Pilot Jet [Re: Thunderlizard] #720317
12/29/17 12:35 am
12/29/17 12:35 am
MA
Nick H Offline
Nick H  Offline
MA
Isn't it true that the new Premier's located the pilot jet back in the original over the float bowl position?
1966 BSA Lightning
1967 Triumph "Choppa"
Re: Amal Pilot Jet [Re: Thunderlizard] #720318
12/29/17 12:43 am
12/29/17 12:43 am
John Healy Offline
John Healy  Offline
No!
Re: Amal Pilot Jet [Re: NickL] #720351
12/29/17 9:35 am
12/29/17 9:35 am
Originally Posted by NickL
No, they just made it accessible by fitting another screw in the opposite side to the mixture adjustment screw.
No they fitted a removeable jet in the opposite side from the adjuster screw.
Re: Amal Pilot Jet [Re: Thunderlizard] #720373
12/29/17 12:39 pm
12/29/17 12:39 pm
Jordan, NY
Al Eckstadt Offline
Al Eckstadt  Offline
Jordan, NY
I have a pair of Amals sleeved by Mike Gaylord (Thanks Mike, RIP) back in the 1980's. They have the early removable pilot jet. No idle problems, no stalling, and the air mixture adjusts easily. Since you have the parts, I would want to rebuild it and try it. Check (measure) the pilot jet and other parts carefully before installing.
I would not recommend sleeving today - but I won't post why... you'll have to PM me for the story.
Al Eckstadt
Re: Amal Pilot Jet [Re: Thunderlizard] #720383
12/29/17 3:23 pm
12/29/17 3:23 pm
USA
USA
The carb bore, slide, and flange are all in good shape, I'm going to give it a try. If I don't like it, a new one is easy enough to get. thanks for all of your input.
Re: Amal Pilot Jet [Re: Thunderlizard] #720385
12/29/17 3:40 pm
12/29/17 3:40 pm
When I find a good body with little or no wear then I always fit either a chromed or anodised slide as that removes the cause of the rapid wear concentrics suffer from. AMAL's own attempt at chromed pot metal slides failed but Surrey Cycles version works as its chrome on brass.
Re: Amal Pilot Jet [Re: Thunderlizard] #720386
12/29/17 3:49 pm
12/29/17 3:49 pm
John Healy Offline
John Healy  Offline
Actually Chris Williams - Autocycle version.
Re: Amal Pilot Jet [Re: Thunderlizard] #720387
12/29/17 4:03 pm
12/29/17 4:03 pm
Good to know.
Re: Amal Pilot Jet [Re: triton thrasher] #720667
12/31/17 11:23 pm
12/31/17 11:23 pm
Aus
NickL Offline
NickL  Offline
Aus
Frightfully sorry about the mistake, thank you for correcting me old chap.
Page Time: 0.061s Queries: 15 (0.006s) Memory: 1.1185 MB (Peak: 1.3748 MB) Zlib disabled. Server Time: 2018-04-23 09:28:24 UTC
