J Rowe
J Rowe
Orange, MA USA
34 registered members (Al Eckstadt), 204 guests, and 447 spiders.
10257 Registered Users
Lannis 55
TBolt72 47
610,743 mail-order LSR
Topics67,150
Posts651,632
Members10,257
Page 13 of 18 1 2 11 12 13 14 15 17 18
Re: What did you do to your bike today --join in [Re: chris l] #719162
12/17/17 10:09 pm
12/17/17 10:09 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
Andy .. Your idea brings to mind a full length method done that some of the race tuners did during 'The Era'. As described to me the OEM case inserts were threaded internally and a length of cro-mo tubing was threaded in and were used as head bolts with the upper end of the tubes tapped for bolts going through the top of the head. Using these bolts securing the head, vs full length studs allowed removing the head without disturbing the barrel or the tubular studs. I believe internal head modifications were also required dealing with oil drain down issues, I don't know the details....
dave - NV
Re: What did you do to your bike today --join in [Re: chris l] #719163
12/17/17 10:13 pm
12/17/17 10:13 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Yes, I plugged the drains between the valve cavity and stud hole and re drilled them at a different angle. There is still a hole between the stud hole and pushrod tunnel so I am fitting "O" rings on the studs at the head gasket line to keep the oil in.
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: What did you do to your bike today --join in [Re: chris l] #719300
12/18/17 9:42 pm
12/18/17 9:42 pm
Sverige
Pelle Offline
Pelle  Offline
Sverige
I just made it dirty again
Re: What did you do to your bike today --join in [Re: chris l] #720013
12/26/17 1:36 am
12/26/17 1:36 am
Mark Z Online content
Mark Z  Online Content
Well not MY bike, my son's TR5T. Getting ready to put the barrel on. I don't like these Tbolt clamps nearly as much as I like the wrinkle-band ring compressors I have for my A65, but I wasn't able to source those in the right size for the TR5T. With the Tbolt clamps, you have to figure the right tension, tight enough to sufficiently compress the rings, but not so tight as to bind on the pistons. We'll see how it goes...
Re: What did you do to your bike today --join in [Re: chris l] #720028
12/26/17 2:52 pm
12/26/17 2:52 pm
Dibnah Offline
Dibnah  Offline
Swapped trickle chargers around, four chargers and eight batteries.
Re: What did you do to your bike today --join in [Re: Pelle] #720030
12/26/17 3:12 pm
12/26/17 3:12 pm
Dibnah Offline
Dibnah  Offline
Looks good in the snow, what air temperature?
More snow: https://www.youtube.com/watch?v=DxqPMR9MCx4&feature=youtu.be&t=462
Re: What did you do to your bike today --join in [Re: Dibnah] #720033
12/26/17 4:18 pm
12/26/17 4:18 pm
Sverige
Pelle Offline
Pelle  Offline
Sverige
Just a couple of degrees below 0 Celsius. The snow is gone now, but we┬┤ll have more...
Re: What did you do to your bike today --join in [Re: chris l] #720051
12/26/17 8:35 pm
12/26/17 8:35 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
Today my 1976 R75/6: oil change, valve adj. check points and timing. Riding from Mel Fl. to Naples Fl. Tech weekend and camping for Airheads.
Did get the Hornet short block buttoned up last week also.
Re: What did you do to your bike today --join in [Re: chris l] #720056
12/26/17 9:06 pm
12/26/17 9:06 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
took 72 T120 for ride after installing new Lucas rotor/stator.....new motobatt battery had 12.3 volts across the posts when I left..went on 3 mile ride 45mph with lights on got home checked battery 12.1 volts......uh oh ..the tympanium on this bike is 20 years old so ordered a new podtronics will try that...also sanny claws brought me a new polished stainless front fender for the commando project so I put that on..also cleaned and scotchbrite pad cleaned innards of front caliper for that bike in prep for rebuild with new o-rings and stainless pistons..
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1969 Honda Mini Trail
1939 farmall f30 tractor
2004 Honda Shadow Aero
1972 BSA Thunderbolt
1975 yamaha xs650b
1972 Norton commando project
Re: What did you do to your bike today --join in [Re: chris l] #720098
12/27/17 2:42 am
12/27/17 2:42 am
raf, 12.3 is low for a new battery. With a full charge on it, it should be more like 12.7. Did you put a full charge on it before putting it into service? Don't ever believe a battery retailer if he tells you it's fully charged when it leaves the store. Motobatt, is that an AGM? If so, be sure to use a charger that has an "AGM" setting. Test static voltage 1/2 hr. after charging. If it's not 12.7-12.8, you may have gotten a crap battery. You wouldn't be the first. The battery can be further tested by powering a headlamp for 10-15 minutes. The voltage may drop to 11.8-11.9 while the headlamp is on, but should jump back up over 12 when the headlamp is disconnected.
If the battery checks out, and before giving up on the Tympanium, put a full charge on the battery, then start the engine and read voltage across the battery with the headlamp off. It should read around 13V at a "spirited" idle, and climb to around 14.5 when you rev it.
Re: What did you do to your bike today --join in [Re: Mark Z] #720169
12/27/17 8:03 pm
12/27/17 8:03 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
mark here's the saga..took bike out for a few rides before cold got here and noticed 3 year old scorpion battery was getting weak and last ride I barely made it home and checked battery it was about 11 volts (Boyer ignition) so got new motobatt agm and rode bike and barely made it home again about 10.5 volts showing upon landing...so battery not getting charge so took old rotor/stator off and date stamped on back of rotor was 4 72 it was obviously the original one...stator was old too and wires were toast...put new Lucas rotor/stator on with new connections to old tympanium (it was on bike and looked old when I got it 10 years ago) put battery on battery tender jr charger for an hour or so and took off got home and could not see that battery was charging...my multimeter is digital type and solid copper plug wires and nonsuppressed caps and wires drives it nuts when engine is running so I have to turn engine off and quickly put probes on battery posts...since wires on the old tympanium looked fishy I found a good deal on a anew podtronics and will try that when it warms up a bit...I don't see how it can be anything else.
happy new year
alan
belay all that above...took time off from work this afternoon and traced all wires...found culprit....broken tympanium ground wire hidden under ancient electrical tape oh well...got all new charging system so wont have t worry about that for a while
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: What did you do to your bike today --join in [Re: chris l] #720201
12/28/17 1:24 am
12/28/17 1:24 am
Glad you found the problem. Like the saying goes, "It's always the simple stuff".
Forgive my battery diatribe if I'm preaching to the choir. I work at a place where we make electric mobility scooters, so batteries are my life.
There's only one part I don't understand: "...my multimeter is digital type and solid copper plug wires and nonsuppressed caps and wires drives it nuts when engine is running..."
I've never experienced that with my digital meter, and it's nothing fancy, just a $35 Radio Shack. I've never heard of a VM picking up RF interference - or is it just voltage fluctuations, and the meter has no stabilization circuitry whatsoever?
Re: What did you do to your bike today --join in [Re: chris l] #720570
12/31/17 3:11 am
12/31/17 3:11 am
TR5T, the barrel is on. The Tbolt clamp ring compressors worked great, the barrel dropped right on. Getting the clamps off required a bit of fiddling; they open all the way up, but neither end of the clamp will fit between the cylinders, so I had to get one end down below the piston skirt and feed it through.
The picture shows the cut-off ring spanner I use for the front two base nuts. With the hose around it, I can get a good deal of torque on it. No torque wrench used, as was discussed in another thread. I just keep going around and pulling about as hard as I can until the nuts won't turn anymore. I figure that's about 25 ft.-lbs.
Re: What did you do to your bike today --join in [Re: chris l] #721888
01/13/18 1:30 am
01/13/18 1:30 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Decided it was time for some action on the Enfield.
Took out the primary cover, and tested if paint stripper would touch it
Yep, bubbled up nicely, easy to scrape off.
Done in no time.
Coat of paint or 2, and will be as good as new.
One small step for man...
Obviously been refinished some time in the past, genuine stoved enamel can be a real bear to get off. (And the local sandblasting guru has shut up shop, so tough to find someone with the right equipment these days.) Those silvery patches are some sort of levelling coat, not factory at all. Bit of hammer and dolly work required.
Re: What did you do to your bike today --join in [Re: chris l] #722084
01/15/18 3:18 am
01/15/18 3:18 am
Smackinthemiddle, NJ
rocketscientist Offline
disassembled and ultrasonic cleaned a 276 carb-a-tater.
Re: What did you do to your bike today --join in [Re: chris l] #722113
01/15/18 1:10 pm
01/15/18 1:10 pm
kommando Offline
kommando  Offline
Ongoing project to refurb this mill and use at the same time. Head has been refurbed and is running.
Bridgeport M Head mounted on a 1942 Adcock Shipley Model 1 horizontal mill. Its mounted on the Arbor support shaft with a right angle mount and surplus arbor support shaft is pushed through to rear. Just added back motor drive to the horizontal shaft so it can be used to drive the table and if the head is removed or swung horizontal then use it as originally setup as horizontal mill. VFD's on both motors and next addition will be 4 axis DRO, later I will mount a 2.5" shaft on the top so the head can be moved 6" higher to accommodate crankcases etc. Currently the head is too low to get large items under especially if a vice is used. The M head is early but not 1942 but the head serial number is unsearchable to find the age, the only references are for complete mills not the head alone.
This is the right angle mount which holds the head and grips the 2.5" shaft
Re: What did you do to your bike today --join in [Re: chris l] #722676
01/20/18 2:34 am
01/20/18 2:34 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Customer wanted to change his T140 head from push-in pipes to spigot. The stock spigots are too short to meet the port casting for the push-in head so I made up new ones from inoxidable, then thread milled the ports for the new spigots. 1-5/16" - 16 thread
Re: What did you do to your bike today --join in [Re: DMadigan] #722708
01/20/18 2:59 pm
01/20/18 2:59 pm
gastonia nc
raf940 Offline
raf940  Offline
gastonia nc
picked my 72 commando project up off the garage floor where I found it on its side this morning...somehow fell off jackstand overnight..rear fiberglas taillight destroyed no other damage that I can see
1972 Triumph T120
1968 BSA A65
1968 MGB Roadster
1975 yamaha xs650b
Re: What did you do to your bike today --join in [Re: chris l] #723051
01/23/18 11:25 pm
01/23/18 11:25 pm
Boston, Massachusetts, USA
kurt fischer Offline
#irideslow
#irideslow
Lifted the TR5T off the bench today, installed the wheels, ready to roll around.
The frame had gotten heavier what with the addition of suspension. Fortunately the furnace guy was in today tuning up the boiler:
When you're ready to lift, the helping hand will appear.
Kurt
1968-70-71 Triumph TR6R Bitsa - 1969 Triumph TR6R - 1971 BSA A65L - 1973 Triumph TR5T
2005 Ducati MTS 1000S DS - 2012 Ducati Hyper 796 - 2014 Kawasaki ZX1000
Re: What did you do to your bike today --join in [Re: chris l] #723062
01/24/18 12:57 am
01/24/18 12:57 am
GrandPaul Offline
GrandPaul  Offline
Moved bikes for garage cleaning. (Coincidental "Top 10", other bikes are in other sections of the garage)
Got in a group photo while they were out...
(Left to Right) '69 Triumph Bonneville vintage roadracer, '66 Triumph Bonneville, '69 BSA Lightning, '67 Triumph Bonneville, '03 Kawasaki ZRX1200R, '70 Triumph Bonneville, '92 Yamaha TDM850, '00 Triumph Legend 900 triple, '71 BMW R75/5 Boxer, and '81 Honda CB650 Four. Disregard the Yard Man lawn tractor at the end...
Re: What did you do to your bike today --join in [Re: kurt fischer] #723065
01/24/18 1:35 am
01/24/18 1:35 am
Getting ready to do an overhead cam conversion on it, are you? I see the cylinder head is almost ready behind it .... !!
Re: What did you do to your bike today --join in [Re: Lannis] #723067
01/24/18 1:39 am
01/24/18 1:39 am
GrandPaul Offline
GrandPaul  Offline
Wow, I had not heard of that conversion! What is the expected HP & torque numbers with the upgrade?
This was certainly a "hush-hush" project till now...
Re: What did you do to your bike today --join in [Re: chris l] #723074
01/24/18 3:18 am
01/24/18 3:18 am
gavin eisler Offline
Got the bike in the house, pipes are off, RHS header wasnt sealed well.
Job list.
Remove motor
Weld on new side stand bracket.
Fit new bearing tipped type cam index plunger , one of David Drews.
Change fork oil.
Rebuilt Konis ready to go, thanks to Kommando, lovely job.
Raise front mudguard an 1/8" to prevent gravel noise, now too close with the lowered bracket. steady.
Scored a NOS home market tank in original green paint.
Mod a pair of belt buckles to become tank badges.
Fit new feed side NRV spring.
Fit reed valve crank breather,
Replace the brake switch, lasted 2 years , maybe a record.
Should keep me busy for a month.
Re: What did you do to your bike today --join in [Re: chris l] #723076
01/24/18 4:24 am
01/24/18 4:24 am
lake elsnore california usa
barnett468 Offline
barnett468  Offline
i took my crank to the machinist to have a bushing installed on the oil seal end because it was heavily pitted. tomorrow i should have the sludge hole plugged for the crank oil mod.
Re: What did you do to your bike today --join in [Re: GrandPaul] #723111
01/24/18 2:08 pm
01/24/18 2:08 pm
#irideslow
#irideslow
lol ... I was wondering who would catch that photobomb ... Lannis did!
I picked up that 305 head at a swap meet, nice shape but for fin damage, but I sold my CB77 a couple of years ago to a friend who ran it in MotoGiro til 3rd gear disappeared, we'll meet up in the spring to tear it down.
Tomorrow me 'n' Tatlock, second owner of my TR5T, I'm the fourth, will drive out to Turners Falls MA to pay a visit to Nova Motorcycles, owner there races a CB77 with a Yetman frame, not many of those around, a friend of mine had one 50+ years ago when we both raced CB77s, which we sold and moved to Yamaha TD-1 production racers. Don Hutchinson told me recently that Dave Yetman is still around.
Kurt
