james johnson
james johnson
california
207 registered members (1xfatboy), 1,751 guests, and 570 spiders.
Lannis 145
kommando 105
Stuart 64
477,176 mail-order LSR
Topics65,724
Posts635,291
Cylinder head broken fin replacement #720408
12/29/17 7:54 pm
12/29/17 7:54 pm
England
F
ferretjuggler Offline OP
F
England
I've got one small fin broken off my A65 cylinder head.
I don't have the missing piece of fin, that has gone AWOL long ago.
So I have to find something that I can make a substitute fin from and then get it TIG welded onto the head.
I'm thinking that the best source would be a scrap British cylinder head from a similar era.
Nothing fancy maybe a Bantam or C15 head which is beyond economical repair.
So is there anything wrong with my cunning master plan ?
Re: Cylinder head broken fin replacement [Re: ferretjuggler] #720429
12/29/17 10:32 pm
12/29/17 10:32 pm
bon Online content
bon  Online Content
Have a look for a similar, but scrap head, maybe one thats dropped a valve at some stage, off eBay, and get it tigged. It saves you filing the new piece of fin to shape. Nothing wrong with your plan i would suggest.
Re: Cylinder head broken fin replacement [Re: ferretjuggler] #720476
12/30/17 11:31 am
12/30/17 11:31 am
gavin eisler Online content
gavin eisler  Online Content
A65 head fins have a distinct taper from root to tip, make sure the donor is similar or it will stick out when repaired.
SRM do a good job of fin repairs.
Re: Cylinder head broken fin replacement [Re: ferretjuggler] #720498
12/30/17 3:10 pm
12/30/17 3:10 pm
Magnetoman Online content
Magnetoman  Online Content
Unless the welder were able to attach the replacement piece perfectly parallel with the other fins the repair will be quite obvious. Instead, a better job usually can be done by building up the missing material with TIG and "sculpting" it into the right shape. This is especially true when the missing piece is relatively small.
Re: Cylinder head broken fin replacement [Re: Magnetoman] #720502
12/30/17 3:46 pm
12/30/17 3:46 pm
England
F
F
England
Yes I've had that done before on a Triumph twin head.
Quite successful but as I've got the opportunity to get one of the toolmakers at work to do the welding FOC I can only ask so much.
I suppose that I could weld it myself but I'm so far out of practice that I'd need a couple of hours practice first.
Not really practical when the job is a "foreigner" on a machine I'm not really supposed to be using.
I do actually own a spare A65T head from an earlier model.
I could use this as a donor but it seems a shame as it's a repairable head.
I'm thinking that if I can make myself a replacement fin, I could design a special clamp to hold it exactly in the right place during welding.
Yeah, maybe it would be easier just to build up a fin from weld.
Maybe time for a rethink ?
Maybe time to find someone with an AC TIG set in their shed ?
