BritTwit
BritTwit
Kansas City area
201 registered members (1xfatboy), 1,879 guests, and 550 spiders.
Doug Valley, tim_v7, BosBSA, Ron 1973 TR7RV, barnett468
10030 Registered Users
Lannis 146
Stuart 67
475,652 mail-order LSR
Topics65,697
Posts635,023
Members10,029
T160 sump cover cap screw alternatives. #720320
12/29/17 1:15 am
12/29/17 1:15 am
Palmerston North, New Zealand,
W
wheller151 Offline OP
W
My T160 has a standard sump and fittings and is a complete pain to remove from the bike.
The exaust down pipes leave a very small gap between the pipes and the cover and only by using an adapted allen key can this be removed without taking the exaust off.
Is there a better type of bolt head that could be fitted that would give better access ?
I see the oil pick up pipe in the sump fits loosley into a hole in the top of the the gauze sump filter.
Is a better solution available that would be more efficent, as this looks a bit of a rough way of doing filtation when a simple magnet in my opinion could do the same job better.
The oil tank already has a gauze filtering the feed line and there is the cartidge filter also in place.
Any advice on this would be great.
T140v 1977 Export American Spec.
T160 Trident
Re: T160 sump cover cap screw alternatives. [Re: wheller151] #720338
12/29/17 6:52 am
12/29/17 6:52 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I do not have a T160, did you try a ball end hex wrench?
There are replacement sump plates available with a magnet drain plug. No need to remove the plate.
The gauze is only to keep the big chunks out of the pickup tube when the engine blows up. Particles that can go through the screen are still far larger than the clearance of the plain bearings. You should have a cartridge filter in the return line if you want to extend engine life.
Re: T160 sump cover cap screw alternatives. [Re: wheller151] #720348
12/29/17 8:36 am
12/29/17 8:36 am
Stuart Online content
Stuart  Online Content
If you look at the parts book, you'll see this isn't standard at all; a dpo has replaced the standard studs-'n'-nuts with the Allen screws. On the sump plate/filter, this is a crap idea, the Allen screws are wearing the UNC threads in the crankcase ally, instead of nuts wearing much longer-lasting UNF threads on standard steel studs. facepalm
Then, on any standard T160 exhaust system I've ever worked on, the centre exhaust pipes can be removed (with a bit of fiddling) for access to the standard nuts securing the sump plate and filter on the standard studs. No need to remove the whole exhaust system.
By definition, the gauze is far too large to catch the worst wear-causing particles (in the 15-30-micron range apparently) suspended in the oil, that's what the filter cartridge does. So, unless the hole in the filter is obviously damaged and enlarged, it's as good as it gets. As Dave posted, at best the sump filter stops the larger lumps from a blow-up circulating; one of the aftermarket kits that puts a/the cartridge filter in the hose between engine and rockers supply/oil cooler is a better idea?
Re: T160 sump cover cap screw alternatives. [Re: Stuart] #720350
12/29/17 9:18 am
12/29/17 9:18 am
W
W
Stuart you are correct and I see it should have 1/4 UNC UNF studs in place of these ruddy silly button heads.
The engine was completly rebuilt two years ago and it seems the guy who did had made a few of these daft changes.
I am guilty of beliving the guy who worked on it before had all his nuts and bolts together and hopfully I wont fall in that trap again.
I will have a look round for this in line filter you mention as that looks a pretty good solution.
I have thought about fitting an after market screw in filter cartrige type unit, like I now have on my Bonney, but finding a location for the unit on the Trident is prooving to be a bit of a task.
Only place I think I have found to put it is between the back wheel and the rear down leg of the frame near the swinging arm bushes, but its not ideal and will need a stone gaurd fitting which will make it an even tighter fit.
May I also whish you a Very Happy New Year and thank you for your help this year.
T160 Trident
Re: T160 sump cover cap screw alternatives. [Re: wheller151] #720354
12/29/17 9:43 am
12/29/17 9:43 am
The idea of adding a filter in the line out of the engine was shamelessly plagiarised from "jessem" on the TOL forum ... smile
I chose this one for my T100 because it takes a standard triple filter element, but the T100 does have the pictured space where T160's have ignition coils ... BritBike forum sponsor MAP in Florida do something similar, but I think without the ally mounting clamp?
You too. Looking forward to covering six hundred-odd miles between today and New Year ...
Pleased I've been able to help. smile Hope the above helps too.
