kboyd
kboyd
Kansas
33 registered members (bill50cal), 342 guests, and 474 spiders.
10291 Registered Users
Stuart 93
Lannis 66
Mori55 64
637,880 mail-order LSR
Topics67,396
Posts654,324
Members10,291
Page 2 of 3 1 2 3
Re: OPRV Leak Test [Re: DMadigan] #720117
12/27/17 9:22 am
12/27/17 9:22 am
No oil manufacturer will guarantee that it will prolong the lie of an engine, there will always be some [censored] who will thrash his Subaru till it blows up and then blame the oil company... being the big nasty corporation compared to a small guy.. the small guy might possibly win, so not worth it.
I’m a strong believer of when I ran my motor dry of oil in Italy that if it wasn’t for the quality of oil that I used at the time, the big end would have required a lot more work than a polish and nitiriding.
I too rarely check my sump plate/plug now for filings as there is never anything in there.
It might be worth adding that regardless of the viscosity, it will fail at the same temperature. So changing to a greater viscosity oil to suit a hotter temperature isn’t the best way to go, although using a 50wt instead of a multi grade will probably be better as there are no viscosty improving additives to break down. This doesn’t mean the oil won’t eventually fail if worked outside its temperature limit. Probably why SRM only guarantee their engines if used to monograde 40wt oil (least they used to)
Re: OPRV Leak Test [Re: DMadigan] #720122
12/27/17 10:39 am
12/27/17 10:39 am
kommando Offline
kommando  Offline
Proper full synthetics revert to the original viscosity once the viscosity modifiers are used up, that is the highest viscosity so a 20/50 reverts to a 50, dino oils revert to the lowest viscosity eg a 20/50 goes to a 20 which was its original viscosity.
Re: OPRV Leak Test [Re: kommando] #720124
12/27/17 10:58 am
12/27/17 10:58 am
OZ
Triless Online content
Triless  Online Content
OZ
All this concurs with something I learned years ago , in relation to " dino " oil. Basically, as has been said, a multigrade will shear down to its lowest rating before a monograde will shear at all ! This is why here in Oz, I use a 25/50 multigrade,in my Triumphs, and take care to warm up in cold weather. I always believed in the benefit of a multigrade for plain bearings ( bigends in the case of my Triumphs ). I use a 50 monograde in my 1932 Matchless, though.
But, with the weight ( pun intended ) of pros for synthetics, I'm having a real rethink here. Although the 25/50 I'm using in my Triumphs ( Castrol Edge ) is now, apparently, semi synthetic !
Re: OPRV Leak Test [Re: DMadigan] #720125
12/27/17 11:05 am
12/27/17 11:05 am
kommando Offline
kommando  Offline
I refuse to use any Castrol oil, Mobil took them to court as they were incorrectly referring to some of their oils as synthetics when they were not. Sadly Mobil lost and Castrol won.
http://www.1st-in-synthetics.com/a_defining_moment_for_synthetics.htm
So now you have to look for a Group 4 POA synthetic oil to ensure it really is synthetic.
Re: OPRV Leak Test [Re: DMadigan] #720129
12/27/17 1:43 pm
12/27/17 1:43 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
Perhaps one way to fix the leakage past the first three threads would be to use a low strength thread locker such as Loctite 222. You would need to apply directly onto the inner threads in the oil gallery avoiding the outer threads. When the OPRV is screwed in, assuming the threads are aligned, a seal should form preventing leakage.
Re: OPRV Leak Test [Re: gunner] #720132
12/27/17 2:32 pm
12/27/17 2:32 pm
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Gunner
Your trick suggestion has been propounded here before by Rich B. I had been doing it carefully (only the faintest smidge of Permatex on the relevant part of the OPRV housing, but found on a disassembly done over the last week that it can set quite hard, so that discouraged me). Thinking about this, it's unlikely to be blown into the feed side of the equation though. An anaerobic sealant along the lines of your suggestion would be the trick I think. I suspect one of the previous respondents might suggest a suitable Loctite product (515 or 518?).
I'm very interested to see this data. I reassembled the oil feed system with no thread sealant on the relevant part of the OPRV cavity this time for the first time. On start up oil pressure came quickly up to a stable 50psi at slightly above idle (cold). I now feel I want to check the pressure hot as that check was only to see if the oil system had primed correctly. End-feed crank of course.
I dont think there is any shortage of oiling in my engine as I see a lot of evidence of the effectiveness of the drain holes in the oil ring groove and lots of 'cooked' oil inside the cases. The latter was the factor that pushed my decision for synthetic oil, even though I previously changed my dino oil frequently. The engine in question did 35000 miles on a nitrided crank that was still in spec with no detectable 'feel' of looseness for the big ends and the shells could have been re-used but were replaced.
This time round I've now run full synthetic oil for the first time. I always ran synthetic in my race H**** as Ray Easson (drag bike guy in Perth, W.A.) who did some of the engine prep said in his experience synthetics reduced wear in the race engines he was involved with. Of course there is no double blind trial and any evidence is subjective.
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Re: OPRV Leak Test [Re: DMadigan] #720270
12/28/17 6:13 pm
12/28/17 6:13 pm
There’s enough pommie idiots degrading this so don’t feel like your alone out there. Haha joke! Your certainly no fool.
You do however have a point, i have only damaged the motor once, and that was when it had a smere of semi synthetic on the shells... as you can imagine I don’t fancy repeating the exercise.
Another thing worth noting is that when I did use Dino oil I found after 3000 miles a soft sludge in the trap about a 1/4 full but not compacted either (I’ve seen some traps look like they are half full of cake) I did some work to the engine, ran it in again and post run in I switched to semi synthetic. After about 3000 miles I changed the cam and checked the trap again... it was still spotless, when I starved it of oil I checked again and still spotless. So it gives me a lot of confidence in the oil I am using and the length of time I may need to go before rebuild.
As for the leaking past the oprv. I run mine with an anealed copper washer under the head, I’ve never had a leak issue. The factory piston oprv units used something like a locktite under the acorn nut threads. When I bought my nos unit I stripped and checked it first, cleaned the threads as the sealer had crumbled away and used an RTV sealant instead.
Nick, thankyou for using cts, a unit I understand and work to.
Re: OPRV Leak Test [Re: DMadigan] #720276
12/28/17 6:39 pm
12/28/17 6:39 pm
kommando Offline
kommando  Offline
Kommando will probably remember the test Glacier did with STP and a few other additives in the 60's.
Not there at the time but they would have also checked Slick 50 in the test as they had lead PTFE bushes known as DU which they had invented in the 50's so they knew its properties .
Re: OPRV Leak Test [Re: DMadigan] #720305
12/28/17 10:39 pm
12/28/17 10:39 pm
Alaska
linker48x Offline
linker48x  Offline
Alaska
This is not really relevant to what the OP is addressing here, but it is similar, so I will briefly weigh in. I have roadraced the same Triumph T140 for about 25 years, and have done a fair amount of development of the oiling system to get it to live, and to avoid a long tale of problems, I will just kind of narrate where I have ended up. First, over the last 50 years I have raced other Triumphs in dirt track and motocross, and the stock oiling system worked well enough that I left it alone, but not true for road racing. Perhaps modifying the oiling system for a road bike is in the "perfecting something that is more or less ok" category, but if you ride hard (road speed, revs, high air temperature, long mileages) perhaps that is not the case. Anyway, on with what I discovered over the last 25 years.
As a base case, ever since I built this bike, I always have used Mobil 1, and a Norton oil filter in the return line.
First, using Mobil 15-50, I had oil pressure, oil temperature and windage/ring seal/leakage problems. I added a triple oil cooler, and a Morgo rotary oil pump, and since I was using a belt primary drive, I vented the crankcase through a standard T140 vent fitting I welded on the timing case over the end of the exhaust camshaft. That worked on a hot track, on a hot day, to solve a lot of the problems I had but I introduced some new ones.
In particular, the pump provided very good volume and pressure, but it did create some new problems I had to solve.
I encountered problems in the early morning practices on cold race days with turning the oil seal on the crank end inside out from overpressuring, with the cold pressure up around 90 psi. Eventually I figured out I could not warm the engine up enough at, say, Savannah in February and 40 degrees, using the Morgo high flow pump, 15-50 oil, and the very large triple oil cooler, so I kept the high volume oil pump but substituted a much smaller oil cooler that had a thermostat built into it, and I started using Mobil 1 10-30, still with good 65-75 psi pressure hot at high rpm, much less pressure cold starts, and the seal problem was solved. (Pioneer seals, of course.)
Also, I encountered big time oil pump priming issues with the Morgo rotary pump until I figured out it needed to be bled, and bled, and bled, by rotating the rear wheel in 5th gear, with the timing cover off and the spark plugs out, until absolutely no bubbles came out. Much more bleeding than the directions said, is the point here. And to make sure it didn't pick up any air while running and had proper pressure at every startup, I put a liquid filled oil pressure gauge on it in place of the oil presure switch. Any time the supply line is off or empty for whatever reason, I have to bleed the pump.
To solve the windage and heat problems, I wanted to get the oil out of the engine, so I also welded up the relief hole into the crankcase for the relief valve, and instead drilled a new hole the same distance in, but aimed to the bottom, and welded on a bung on the bottom of the valve body on the crankcase, and returned the relief oil directly to the tank with a new oil line. The hole is double the area of the stock holes to make sure it does not constrict flow. As I have blown this thing up and replaced crankcases, I have experimented with the hole venting into the timing case, and have now left it alone.
That brought to light the leakage problem around the threads of the valve that is discussed above--there were only 2 or 3 threads on the inside of the relief hole in the case at the lead end of the pressure relief valve, so I did what someone above mentioned--carefully put Yamabond 3 on the inside of the hole each time the valve is out, problem solved. Oil now flowed through the valve first, then to the relief hold and line, and not up the threads and directly to the relief hole avoiding the pressure relief. I still do this, and although pretty subtle, it was an important discovery in maintaining oil pressure at high heat and rpm.
And, you cannot have oil filter problems if you don't have a filter, so when the chromoly bracket I welded up failed, I finally took it off, and so I have no filter these days.
So, Morgo rotary pump to create modern levels of flow and pressure, modern oil weight-10/30 synthetic Mobil 1, Pioneer seal, small oil cooler with thermostat, external oil return for relief valve, oil pressure gauge, and putting Yamabond 3 on the threads of the valve orifice inside the relief hole. All seems simple, except it took me a couple decades to figure all this out.
I know other Triumph roadracers and tuners have done it differently, with external oil feeds, filters in the feed side, etc., but this is what worked for me. Here's a couple pics--not much shows on the outside, but for what it is worth.
Re: OPRV Leak Test [Re: DMadigan] #720307
12/28/17 10:53 pm
12/28/17 10:53 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
I was comparing the leak area of the main bearing with the OPRV to show the relative magnitude.
Here is the output of the journal bearing calculations for 0.002" main and 0.002" rod bearing clearances.
SAE40 oil at 170F, 1000 RPM producing 4 HP with the ideal pump output the pressure is 10.4 PSI (iterate until pump output and required flow are equal).
If the OPRV has 1/3rd the leakage of the main bearing the pressure would certainly be below the switch pressure.
So the pump does not have 2 times the capacity with clearances that are "supposedly" within specification.
Viscosity does affect pressure which is why thicker oils produce higher pressure with the same clearances.
Forgot to mention, I tried sealing the last three threads inside the OPRV cavity (below the relief holes) with Marstan Hylomar and retested the ball valve. The cavity drained in 30 seconds. Not as good of a seal as the O-ring on the face of the OPRV but better than nothing. Loctite 518 may be better
NickL - no worries, it is all about the exchange of information.
Re: OPRV Leak Test [Re: DMadigan] #720353
12/29/17 9:40 am
12/29/17 9:40 am
triton thrasher Offline
Originally Posted by Simon
Any leak on a pressure system contributes to pressure loss so it dosen't make sense to compare one leak to another and then ignore two other leaks.
Oil reaching the big ends is important. The oil that leaks in and around the relief valve plunger and threads and through the main bush does not reach the big ends.
Re: OPRV Leak Test [Re: DMadigan] #720409
12/29/17 8:21 pm
12/29/17 8:21 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Unless you look at the equations on the Machinery Handbook for journal bearings, most of the numbers in the spread sheet will be meaningless.
What are these "other two leaks"? The rod bearings? They are included in the second column.
What pressure the OPRV opens is not significant to the problem of leakage past the threads and piston when the engine is idling.
The line labeled "flow required" (0.222) is the sum of the main total flow (0.065) and two rod total flow (2 x 0.079) bearings. The label "pump flow" is the theoretical output of the pump (assuming all the space between the teeth is moved). The total flow is the sum of the hydrodynamic and pressure flows.
To find the system pressure will be for the input conditions the "oil pressure" variable has to be iterated until the required flow equals the pump flow.
With the same bearing inputs except 7000 RPM, 50 HP, 50 PSI, the required flow is 1.522 in^3/s and the theoretical pump flow is 1.566 in^3/s. Not much margin there.
If the HP at 7000 RPM were reduced to 4 HP (say throttle closed to shift) the required flow reduces to 0.959 in^3/s. To keep the oil pressure at 50 PSI the OPRV has to flow 0.606 in^3/s. The drilling to the OPRV on an A65 is 0.205" diameter so the flow is 1.53 ft/s through that drilling. Without the OPRV the oil pressure would go up to 116 PSI.
I do not see where the "hit and miss" comes into it. The "centrif pressure" is the pressure from the main bearing feed to the centre of the crank. The centrifugal pressure of throwing the oil out to the rod journals is much higher and will help pull the oil to the bearing. This is not a Triumph Wheeze-Squirt oil system.
Many engines feed the rod journals through the main bearing. The 911 and VW W12 engines come to mind.
Re: OPRV Leak Test [Re: DMadigan] #720440
12/30/17 12:47 am
12/30/17 12:47 am
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Reference: Machinery Handbook pages 561-571 (in the 21st edition). These are the equations for designing journal bearings.
A number of these values come from charts that I scanned and put curve fits through so they could be used in the spreadsheet, for example - SAE30, SAE40 and SAE50 oil viscosity as a function of temperature, bearing pressure parameter P' and torque parameter T' which are functions of the eccentricity ratio ε and l/d of the bearing.
The second bit about 7000 RPM at full and idle load is to show that the oil flow to the OPRV is not just proportional to engine speed but also a function of bearing load. The crank seal on a Triumph might just be blowing out from fast unloading of the engine (such as shifting at high RPM) and the OPRV cannot keep up with the sudden increase in flow causing much higher pressure and inverting the seal (sound familiar?). This might be the cause of linker48x's problem.
Re: OPRV Leak Test [Re: Simon Ratcliff] #720474
12/30/17 11:24 am
12/30/17 11:24 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Originally Posted by Simon Ratcliff
You're the second poster to make an unsubstantiated claim regarding content of my posts. Your self and NickL obviously find it stressful reading them so do yourselves a favour and in the future I suggest you don't.
Maaaaate. I'd say substantiated. What I see is you being argumentative for the sake of it. Does it matter if DM hasn't provided any 'recognised' units. I think he's showing you his workings to suggest that he has an idea of what he is talking about. My quick look at that said I'd need to see the formulae in XL sheet (if that's what it was) to make any sense of it. You could always come up with an alternative approach. In my line of work we look for solutions not problems.
If you want to argue with 'theoretical', take the time out to do your measurements. First you better get yourself a BSA for this, generate the real world data, then come back with some constructive suggestions, theories, hypotheses or whatever. I'm a scientist not an engineer, but that's what I do. I can tell you the hot and cold oil pressure because I checked them on my run on my A65 this morning. I can also tell you today I have performed the experiment of sealing the last 3 threads on the OPRV of an A65 and will run the bike tomorrow to check the outcome.
I'm from a technical background but not the automotive or engineering world and I'm learning heaps here in some cases because of some of the discussions. What some consider general knowledge I have no idea about. I'm sure others are learning stuff too, but a constructive approach would be really helpful. If you are playing the devil's advocate instead of being a smart ar#e then say so.
Having looked inside the OPRV cavity today I appreciate that the drain gallery is 'minute' and a potential issue as noted by Nick. Something I didn't consider until I took the time to digest this thread. I second Nick's comments about the value of the collective knowledge here. I'd hate to see that disappear because of toxic posts. I suggest that as an educated individual you take the time to digest the information of value here. As a kid I was told "sit back shut up and you'll learn a lot". Might be better put as " if you dont have anything constructive to say, say nothing"
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
Re: OPRV Leak Test [Re: DMadigan] #720479
12/30/17 11:55 am
12/30/17 11:55 am
As a user of a piston type valve in another well-known make of 650 twin, I had never considered seepage between piston and bore before.
The ball relief valves in BSAs were replaced by Triumph types as an improvement, but it looks like they brought with them the issue of loss at low rpm.
Ball valves have a safety disadvantage in that the ball can be held open by dirt, allowing serious loss of oil. With full-flow filtration by a real filter between pump and relief valve, that wouldn't be a problem, but there is no real oil filter on an A65 (or a Bonneville).
Re: OPRV Leak Test [Re: DMadigan] #720485
12/30/17 12:59 pm
12/30/17 12:59 pm
Running from demons in WNY
Hillbilly bike Online content
Probably 99.9 percent of car/truck engines feed through the mains to the rods. And 99 percent have piston type PRV's....The common Chevy V8 stock oiling system can support 70 HP per cylinder with a 2 inch diameter rod bearing slightly wider than a Triumph using 55 PSI oil pressure. Oil flow on the 8 cylinder engine is 7-9 gallons per minute.... I believe air cooled two valve belt cam drive Ducatis feed the oil into the crank end...They are like a Triumph with the roller/ball crankshaft mains and plain bearing connecting rods because there no other way to feed the oil with this design. Ducati oil pump flow is 2.6 liters per minute at about 3000 rpm......In WW2,the Rolls Royce Merlin aircraft engine was experiencing bearing failure at higher power levels...The best fix was feeding the crankshaft from both ends rather than from the mains...This was likely more to do with oiling system design rather than saying end feed is better ....
I've had oil pressure issues on my dual engine 650 pre unit Triumph LSR racer...The oil pressure was to high when cold, I converted the pre unit timing covers to a rubber lip crank seal.The engines have stock oil pumps and filters on the return lines... I bought a handful of relief springs and OPR valves and messed around with shims until I got about 80 psi..Then a valve might stay closed for no reason so I increased the piston clearance on the PRV..That worked for a time but now one valve is stuck open lowing the oil pressure to about 35 psi...
I ride junk
Re: OPRV Leak Test [Re: DMadigan] #720489
12/30/17 2:11 pm
12/30/17 2:11 pm
I have some info on modified vehicle engines that might be reverent here...I used to modify vintage GMC truck inline 6 cylinder engines for "racing". The oil pump pressure was always a problem and changing the OPV spring required removal of the oil pan, very messy time consuming job. So I set up a test rig...oil pump and pick up submerged in oil with a gauge hooked up to the outlet having having an adjustable orfice to simulate oil flow past the bearings..Due to pump design it was easy to use a variable speed corded drill motor to spin the pump...Ok ,so what does this have to due with Triumphs? I found on a pump flowing 7 gallons per minute at 3000 rpm pump speed with 10/30 room temperature oil, a 5/32 inch hole could maintain a maximum 45 PSI compared to about 80 psi with no relief opening....On a Triumph or maybe a BSA, the pump flows about 1-1/2 pints per minute? How big does the bypass hole need to be ?
I ride junk
Re: OPRV Leak Test [Re: Hillbilly bike] #720496
12/30/17 3:06 pm
12/30/17 3:06 pm
Denver CO
Jerry Roy Offline
Jerry Roy  Offline
Denver CO
Ask Simon.
facepalm laughing laughing
Re: OPRV Leak Test [Re: DMadigan] #720524
12/30/17 9:27 pm
12/30/17 9:27 pm
Gentleman, this is a very interesting an informative thread, David has a wealth of knowledge on these bikes that many of us could only dream of knowing. I ask politely that you extend the courtesy and learn from what he is trying to teach, I’m sure, that like many of us he has work and family to which he could spend his valuable time. The fact he gives us that time to educate us and impart knowledge that has taken a long time and finance to learn is something we should all be grateful for. As previously mentioned if you don’t have anything of worth to bring to the party, no evidence to prove him otherwise then please don’t rock the boat. There can only be theoretical values of what you should be achieving and a tolerance from there... the wear of every engine is different and there will be other variables too.
In addition to this, I strongly advise that the back chat on this forum and this post especially ends now. Simon you have been notified by other valued forum members, however as one of the moderators for this forum I ask all participants to move forward with this topic and not the actions of an individual. I ask that those members make an edit to their posts.
Thankyou for using the forum.
Allan
Re: OPRV Leak Test [Re: Allan Gill] #720527
12/30/17 9:57 pm
12/30/17 9:57 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
Why not add a ball top/and seat... to the piston design.
ball and seat... would eliminate piston seepage when fully closed
Necessary piston seepage wouldn't matter when ball is unseated.
The piston-slide should still offer , more than adequate regulation if the ball/seat component is contaminated
And the piston slide design offers a way to more easily graduate the pressure pop off.
Re: OPRV Leak Test [Re: NickL] #720547
12/30/17 11:45 pm
12/30/17 11:45 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
I probably missed it
but
Has an estimated optimal or minimum oil flow rate , at high and low rpms,
for all the engines total collective bearing journals been establihed ?
Re: OPRV Leak Test [Re: DMadigan] #720554
12/31/17 12:11 am
12/31/17 12:11 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
There is not a problem as such with the OPRV. The oil pump is marginal at low RPM, then at high RPM when it should be relieving the pressure the passageways are too small to pass the oil. This is compounded by owners who think that thick gloopy oil must be "better" It will not pass down the passages when cold resulting in high pressure spikes that can destroy oil seals and damage oil pumps
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: OPRV Leak Test [Re: DMadigan] #720566
12/31/17 2:16 am
12/31/17 2:16 am
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
OK, results are in on my road test of 'sealing' the last 3 threads of the OPRV on my 69 A65F.
In this instance, I found a 2-4 psi increase after 'sealing' the threads. I'd call call that worth getting with a simple 'trick'. Effect greater at higher pressures (as might be expected). Overall max pressure didnt change much (~ from 40 up to 42 psi at 4-5k rpm). Ride conditions were the same between runs although oil temp in tank was ~ 80oC for the first run and ~ 83 for the second.
The synthetic seems to run overall lower psi than the dino oil I used previously in line with its reduced viscosity.
Not sure how good a job I did of this as I have only ever done this sealing before with the engine on the bench. For this time around, the engine was in the frame and the exhaust pipe blocked ready access.
Pressure was read from a temporarily fitted pressure gauge (SAAS fluid filled fuel pressure gauge, reading 0-100psi).
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
Re: OPRV Leak Test [Re: DMadigan] #720574
12/31/17 4:23 am
12/31/17 4:23 am
Les P Offline
Les P  Offline
I thought DMadigan was using a two stage gerotor oil pump.
More bikes and projects than you can shake a stick at but they should be done in two shakes of a lamb's tail.
Re: OPRV Leak Test [Re: BrizzoBrit] #720593
12/31/17 1:36 pm
12/31/17 1:36 pm
Rich B Offline
Rich B  Offline
Ray,
That is good news. In a low flow, low pressure system, 2 - 4 PSI increase is significant. And this is a fix that is almost free to do!
I have done this on the bench and on a bike. Definitely easier on the bench.
Did you eliminate the seal washer and go to an O-ring for the valve body?
Be happy you had 3 threads to work with. I have seen less than 2. The arrangement of the OPRV cavity and the angle drilling BSA did for the drain is poor. Not sure which is worse, the OPRV cavity or the oil manifold and ports feeding the pump. Both are pretty poor. eek
Page 2 of 3 1 2 3
