coopers
coopers
australia
195 registered members (1xfatboy), 1,788 guests, and 605 spiders.
Simon.Holyfield, Bushcreature, Gary Shackleton, Doug Valley, tim_v7
10033 Registered Users
Lannis 144
kommando 103
Stuart 67
476,618 mail-order LSR
Topics65,721
Posts635,216
Members10,032
Absolutely positive this fender will ... #719192
12/18/17 3:51 am
12/18/17 3:51 am
Santa Barbara, California
KC in S.B. Online content OP
KC in S.B.  Online Content OP
Need to come off some day!! Wiring up a '69 Triumph, and got to the tail light part. Didn't have a nice disconnect, and also ran a 3rd dedicated ground wire, so needed a connector with 3 contacts. Wasted a bunch of time looking around the shop for an answer, went over to the electrical supply store. They have tons of stuff for builders, but I just can't see a Molex Mate-N-Lock on my Triumph. Thought about the last time I had a reason to take a fender off a running motorcycle,.......... NEVER have. Decided to simply solder and heat shrink the connections !! SO,......... This will be the first time I do need to remove a fender. That is if this project ever does get to the running part. Even as noted, I did leave a "service loop" of extra wire, in case I need to cut it! You just have to move on sometimes !!
Down to 1 BSA, 2 Triumphs, 2 '56 Chevys
Re: Absolutely positive this fender will ... [Re: KC in S.B.] #719227
12/18/17 1:34 pm
12/18/17 1:34 pm
Stuart Online content
Stuart  Online Content
Hi KC,
Ime, originally with two wires, Lucas just used a single snap connector on each wire. Adding the ground wire, just add a third single snap connector? Or, after Lucas added the ground wire as standard, they supplied these.
Re: Absolutely positive this fender will ... [Re: KC in S.B.] #719235
12/18/17 2:20 pm
12/18/17 2:20 pm
Oh, didn't know they ever did supply a 3rd wire, must be on the OIF bikes?
Of course those 3 bullet connectors would work. I haven't got one of those on this bike, and I do have some in a box full of spares. I could have used individual connections also, just decided to test the theory!
Stuart,....... Did send you a PM on the switch query.
Re: Absolutely positive this fender will ... [Re: KC in S.B.] #719358
12/19/17 9:52 am
12/19/17 9:52 am
Hi KC,
Mmmm ... I've seen 'em '71-on but, when I posted that, forum contributors in the US said theirs were still 2-wire, so it seems Lucas started fitting a ground wire from part-way through '71?
grin
Yep, you should have the reply, sorry about the delay. blush
