meatwagon
meatwagon
San Diego CA
22 registered members (Alan_nc), 198 guests, and 467 spiders.
10291 Registered Users
Stuart 92
Lannis 66
Mori55 64
637,405 mail-order LSR
Topics67,385
Posts654,246
Members10,291
Unit 650/750 engine breather #718453
12/11/17 9:01 pm
12/11/17 9:01 pm
bon Offline OP
bon  Offline OP
I have a t140 engine that i want to run with a dry belt primary. Where else to run the breather ? I have seen some run the breather through a hole in the front engine mount. Has anyone done that ? Whats involved and does anyone have any pictures of the modification ?
Re: Unit 650/750 engine breather [Re: bon] #718469
12/11/17 11:17 pm
12/11/17 11:17 pm
Pleasant Hill, California USA
TR7RVMan Offline
TR7RVMan  Offline
Hi Bon, I don't know about where to add breather.
Not suggesting a bad idea in any way, but why do you want dry belt drive?
Re: Unit 650/750 engine breather [Re: bon] #718473
12/12/17 12:00 am
12/12/17 12:00 am
kevin roberts Offline
fefsa
fefsa
i've done breathers on a unit triumph, front and top:
some people run a front crankcase breather out from the side. other people put a fitting in the timing cover.
you'll need to put the old-pre OIF oil seal back into the left crankcase under the engine sprocket, and plug the little level holes in the primary chaincase, which is easy to do with patent-plate pins after drilling the holes a bit larger. mine works very well.
i have no idea what i'm doing.
Re: Unit 650/750 engine breather [Re: TR7RVMan] #718474
12/12/17 12:04 am
12/12/17 12:04 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
snagged from the inter-web :
as necessary , Inlet and drain back holes are made between the mount-void and crank-space.
void space can be filled with stainless pot scrubber , as a condensate medium
then the outside hose attachment(s) , as these two pictures illustrate ... can be as subtle or dramatic as you desire
and of course, a sealed driveside bearing is used. .. and those three little drain back holes into the primary, get sealed too.
Re: Unit 650/750 engine breather [Re: bon] #718478
12/12/17 12:21 am
12/12/17 12:21 am
fefsa
fefsa
lol
two of those are my 65, quinten!
Re: Unit 650/750 engine breather [Re: kevin roberts] #718500
12/12/17 6:34 am
12/12/17 6:34 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
lol
excellent, I just snagged the pictures from the web .
we posted about the same time. .. as I wouldn't intentionally repost the same pics.
in my haste, I didn't credit the source. ..
i think I found your pics on triumph-rat.
the t140 case half was from fleabay.
Re: Unit 650/750 engine breather [Re: bon] #718506
12/12/17 11:48 am
12/12/17 11:48 am
gavin eisler Offline
An interesting video on one way breather valves versus open breathers.
https://www.youtube.com/watch?v=LBqUDIYxgAA&feature=youtu.be
Re: Unit 650/750 engine breather [Re: bon] #718617
12/13/17 10:53 am
12/13/17 10:53 am
Skudeneshavn Norway
Stein Roger Offline
Stein Roger  Offline
Skudeneshavn Norway
Without entering into a big debate on primary drives and so on, in my opinion the standard breathing system on any Triumph twin is adequate for it's intended use. The timed breather works fine, as does the later plenum chamber version. This is provided the engine is in good shape, too much blow by and both systems struggle.
Racing is different and I don't have the experience to comment on it. The same with belts.
I do however have experience with one-way valve breathers, from several Nortons, and lately from a pre-unit Triumph were the rotary breather was damaged beyond repair.
I use Yamaha XS reed valves, they are available, affordable and compact. They work like Schmidt demonstrates, by reducing the under piston pressure by pumping gases out but not letting air back in. It takes a few seconds to reach this state but it will eventually create a lower than ambient pressure in there, in a reasonably healthy engine.
This is exactly the same as the rotary breather valve is designed to do, but possibly more efficient.
You don't want additional breathers in the rocker boxes or anywhere if you use a valve rotary or reed, that would in effect negate what you want to achieve with it.
(Though Bunn advocated letting in a small amount of filtered air to flush out gases.)
The vent-to-chaincase principle is totally different. It works by reducing the effective under-pistons compression ratio by letting crankcase gasses escape through the main bearing and into the vented chaincase. There's quite a bit of resistance through the bearing though, so IMHO it can't be totally effective. That's why I drilled a good number of 1/4" holes in the cases of a tuned unit twin I owned, to see if it made a difference. Can't really say, but I used the bike for a decade afterwards and it stayed as dry as a biscuit on the outside and went well. Be that as it may, the standard set-up is good enough even for racing, so I don't mess with it anymore.
But thumbs up for one way valves, possibly PCV or brake assist valves, but definitely Yamaha XS650 valves They work.
Re: Unit 650/750 engine breather [Re: bon] #718619
12/13/17 11:10 am
12/13/17 11:10 am
fefsa
fefsa
one way to see just how much air goes back and forth in a primary that breaths through the main bearing is to loosen the three screws that hold the rotor cover plate on. back em out halfway and start the engine. the plate on mine dances like gene kelley as the pulsing air hits the back of the little cover.
Re: Unit 650/750 engine breather [Re: bon] #718634
12/13/17 2:52 pm
12/13/17 2:52 pm
Carmel, CA
Doc_dup1 Offline
Doc_dup1  Offline
Carmel, CA
What about using the timing hole at the rear of the cylinders? I have seen several bikes using that with a hose running to the rear fender and I have been thinking of doing that on my current project bike.
Doc
Doc
Mostly Triumphs with a few BSA's a Norton, and two BMW's
Re: Unit 650/750 engine breather [Re: bon] #718644
12/13/17 4:22 pm
12/13/17 4:22 pm
bon Offline OP
bon  Offline OP
Thanks for all the replies. I want to run the primary dry because it is one place less to leak oil, and besides the belt and clutch doesn't need oil. Even so i do not like the idea of running the primary in the same oil as the engine, its too thick for the chain.
Running the breather off the timing plug hole, i have heard can be problematic as oil is flung into this area by the crankshaft. Dave Degens uses the front engine mount as site for the breather tube.
Re: Unit 650/750 engine breather [Re: bon] #718651
12/13/17 5:20 pm
12/13/17 5:20 pm
Running from demons in WNY
Hillbilly bike Offline
Breathers on my various bikes.....
650 race bike, one breather on the front similar to what Kevin shows. One breather on the timing cover
Pre unit dual engine race bike, one large breather hose on the timing covers...The rocker boxes are also vented with small tubing
T120/750 street bike with breather on the timing cover only
None of the above have one way valves All the breather setups function and don't blow oil out....It's easy to fit one to the timing cover..But you may not care for the look of external hoses on a stock bike..
I ride junk
Re: Unit 650/750 engine breather [Re: Hillbilly bike] #718675
12/13/17 10:52 pm
12/13/17 10:52 pm
fefsa
fefsa
lol
how many times did you change your mind on that rod connecting the gearshift lever to the box?
Re: Unit 650/750 engine breather [Re: kevin roberts] #718701
12/14/17 12:17 am
12/14/17 12:17 am
lol
Uh...No comment lol
I ride junk
Re: Unit 650/750 engine breather [Re: bon] #718743
12/14/17 1:40 pm
12/14/17 1:40 pm
Scotland, UK
jimmymckenna Online content
jimmymckenna  Online Content
Scotland, UK
Back in the mid 80s I owned a T140D. I bought a QPD? belt drive system for it. As it was dry running I had to block off the 3 drain holes on the cases and fit the seal on the crank. For breathing the kit included an adaptor that fitted into the Timing hole at the rear of the barrels. I ran a hose from there to the rear mudguard. The problem I (well not me, but anyone unlucky enough to be sitting behind me) had was the pressure forced a fine mist of oil out this hose. Not being very mechanically minded I tried a variety of methods to stop this without success.....If only I'd known about one way valves back then
Re: Unit 650/750 engine breather [Re: bon] #718751
12/14/17 2:41 pm
12/14/17 2:41 pm
Skudeneshavn Norway
Stein Roger Offline
Stein Roger  Offline
Skudeneshavn Norway
Hi Jimmy, I doubt fitting a valve in that position would have made much difference. It would have pumped oil out of there anyway because the oil fling off the flywheel is at its greatest there. There is less oil fling at the front of the crankcase, and it's possible to device a labyrinth type of thing inside the snout to catch and re-direct the oil. I haven't tried it but that's where I would have placed the vent and possibly the valve too.
On a Norton Combat engine I built I devised a one-way valve inside the breather housing, which is placed at the lower rear of the crankcase on this model. It would spit oil all the time, but as it vented into the oil tank it didn't matter. It also served as an additional oil return system when the cases were flooded, as can happen on those things, very useful!
Re: Unit 650/750 engine breather [Re: bon] #718766
12/14/17 5:29 pm
12/14/17 5:29 pm
Scotland, UK
Scotland, UK
Hi Stein
Unfortunately for me that was where the manufacturer stated it should go, even providing the coupling to fit in there. As I said I did not have much mechanical knowledge back then, I was only about 20/21yrs old and my apprenticeship was in shipbuilding. If only we had access to the knowledge base that the internet provides now. I really looked forward to buying and fitting my belt drive but the oil spray spoiled my enjoyment of it. I replaced it with the standard set up about 2yrs later when the belt failed
