Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,884 guests, and 585 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,307 mail-order LSR
Topics65,693
Posts634,977
Members10,027
Page 2 of 2 1 2
Re: A65 crankshaft end float [Re: Mr Mike] #491984
05/28/13 1:27 am
05/28/13 1:27 am
Vic. Australia
Pete R - R.I.P. Offline
Vic. Australia
You should have somewhere between 0.0015" and 0.003" interference at room temperature,say 20C.
Aluminiuum expands roughly twice as much as steel.
The difference is about 0.001" per inch diameter for 100 C. temperature rise.With 50 degree rise on 2-13/16 diameter bearing,you lose 0.0014" of your interference fit.Crankcases can,and do occassionally,reach 100 C.
Even if you had 0.002" inteference at room temperature,you could have less than no interference when the engine is hot.
Re: A65 crankshaft end float [Re: jamie weeks] #491986
05/28/13 2:16 am
05/28/13 2:16 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
Pete,
If you are correct these bearings would not stay in the case very long but most do. I for one would have like to see an additional retainer of some sort but the BSA system seems to have worked but requires very accurate machining to hold tolerance for an interference fit. HOWEVER, once that outer race move relative to the case, the case is junk.
Re: A65 crankshaft end float [Re: Mr Mike] #491989
05/28/13 2:33 am
05/28/13 2:33 am
Vic. Australia
Vic. Australia
They always move when the engine gets hot.There was some discussion about this on the Norton Bulletin Board,a little over a year ago. Bearing Movement in Crankcase
Re: A65 crankshaft end float [Re: jamie weeks] #492057
05/28/13 6:18 pm
05/28/13 6:18 pm
From that Norton post:
"Just to re-confirm what I had found in the past I pulled an old virgin 750 bottom end off the shelf and checked the end play. It had a tight .002 IN.- about right for a ball bearing.
I stuck it in the oven at 220 F. for one hour.
The end play was then .034 and I could move it back and forth by hand."
I assume that this increase also happens to our BSA engines once they get up to temp?
Re: A65 crankshaft end float [Re: jamie weeks] #492127
05/29/13 3:54 am
05/29/13 3:54 am
Cape Carteret, NC
Mr Mike Offline
Mr Mike  Offline
Cape Carteret, NC
David,
I suspected the same thing and measured endplay on a roller motor. I then heated the whole assembled bottom end up in an oven. The endplay increased measurably with a dial indicator. Coefficient of expanison of Alum is approximately 2x that of steel. Based on that I would set the endplay at the bottom end of the limit, but, I have often wondered what gets hotter under normal operation the crank or the cases
Re: A65 crankshaft end float [Re: jamie weeks] #492136
05/29/13 6:32 am
05/29/13 6:32 am
derby england
wak Offline
wak  Offline
derby england
im not sure im buying this, when you run the bike its air and oil cooled,i cant see the cases getting much hotter than the oil, and if its growing that much whats happening at the cylinder base,timing gears ,primary chain? not to mention piston and rod alighnment.if it expanded that much every time it cooled all the bolts would be loose.
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: A65 crankshaft end float [Re: jamie weeks] #492164
05/29/13 1:24 pm
05/29/13 1:24 pm
Allan Gill Online happy
Allan Gill  Online Happy
My bike was running 018" of end float when cold, never checked it hot. The crank was perfectly fine when it was pulled apart. It probly didn't do the primary chain too many favours but if anything it probably worked in harmony with the wobble in the clutch basket laughing
I'm with wak though. If you just heat the whole engine then yes the cases will expand a bit, not at any great expanse though otherwise the cases would crack at its mounting points. When your running the motor, the moving components generating heat are made of steel, the oil flow is removing heat, some is transferring to the cases which is being cooled by air flow. The overall rate of expansion is probably fairly even. Run the engine for 20 miles and check it then!
I think as long as you have enough clearence so nothing nips up tight and not too much so that the engine throws its self apart there is little to worry about.
Re: A65 crankshaft end float [Re: jamie weeks] #713676
11/03/17 1:04 am
11/03/17 1:04 am
just a guy from Jersey [Hopewe...
nert Offline
nert  Offline
So, on a 1966 A65 roller type bearing, the crankshaft can still float with the spacer, gear, and rotor all tightened up? It doesn't feel like it. Or should I measure end float with out the spacer, gear, and rotor torqued up.?
Re: A65 crankshaft end float [Re: nert] #713705
11/03/17 12:12 pm
11/03/17 12:12 pm
new jersey usa
pushrod tom Online content
pushrod tom  Online Content
new jersey usa
Everything needs to be torqued up. A pain but necessary. PRT
Re: A65 crankshaft end float [Re: jamie weeks] #717050
11/29/17 12:58 am
11/29/17 12:58 am
Toronto Ontario Canada
6
69BSATONY Offline
69BSATONY  Offline
I'm learning as i go along.
Since the cases have to be assembled and pulled apart a few times to get the end float right
how do you guys install and remove the roller bearing without busting it. mine is very tight on the shaft.
I all ready ruined one and waiting for a replacement . At $ 100 bucks ???
Should I sand the shaft or the inner race ?
69 BSA lightning
Re: A65 crankshaft end float [Re: 69BSATONY] #717054
11/29/17 2:43 am
11/29/17 2:43 am
Mark Z Offline
Mark Z  Offline
The rotor nut pulls the crank tight to the inner race of the roller bearing. With a roller bearing however, the inner race can "float" with respect to the outer race.
Not sure what you mean by "it doesn't feel like it" - I doubt you could detect 2 thou of movement without a dial indicator. Also, are you trying to check this on a fully assembled motor? It should be checked with the rotor nut torqued down, but without the crank pinion and oil pump installed.
69 BSA lightning
Wow, if you ruined a bearing (just the inner race, right?) getting it off, it was really on there! They're usually not THAT tight. Yes, I would do a bit of sanding, on the crank. Fine emery, go slow, wipe it clean and apply a bit of oil before test-fitting.
Re: A65 crankshaft end float [Re: jamie weeks] #717089
11/29/17 1:33 pm
11/29/17 1:33 pm
6
69BSATONY Offline
69BSATONY  Offline
Thanks Mark z.
Will do that when I get the new bearing .
Re: A65 crankshaft end float [Re: jamie weeks] #717092
11/29/17 1:52 pm
11/29/17 1:52 pm
gavin eisler Online content
gavin eisler  Online Content
To get the shims correct it helps if an old main bearing is used, remove some material from the bearing inner bore ( a small flapwheel will do it) and outer shell to make trial fitting easy, as long as the width is the same as the new one this allows trial fits with no drama. its best to have tight/ snug final fit. I have had to resleeve a DS mainshaft so I am wary of removing material from this part.
Re: A65 crankshaft end float [Re: jamie weeks] #717104
11/29/17 4:02 pm
11/29/17 4:02 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
You need a bearing puller that clamps around the rollers with a lip behind. Something you would have if you did this more often.
If you use an old bearing as Gavin suggested you should measure the inner race width with a micrometer to be sure they are the same. Different manufacturers may have different tolerances.
I would not suggest doing anything with the crank to make removal easier. Since you do not have a bearing puller I doubt you have the equipment to do it properly.
Re: A65 crankshaft end float [Re: jamie weeks] #717151
11/29/17 9:01 pm
11/29/17 9:01 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
IMHO its not unusual to find that bearings don't fit easily on to crankshafts or other shafts. Whether this is due to inaccuracies in BSA or bearing manufacturing is unknown to me, I guess you would need accurate measurement apparatus to find out where the problem lies.
Also, its not clear to me what the ideal clearance between a crankshaft and bearing internal diameter should be. I'm aware that C3 clearance is intended to take up bearing compression when fitted into a crankcase housing and also tight fitting onto crankshafts. However what if both conditions exist, does this mean a bearing with even larger clearance is needed?
Where a bearing is a very tight fit on a shaft, my preference is to hone the inside diameter of the bearing so that its a nice tight sliding fit on the shaft. Its better to remove material from the bearing as these are easier to replace compared to crankshafts.
Re: A65 crankshaft end float [Re: jamie weeks] #717158
11/29/17 10:31 pm
11/29/17 10:31 pm
John Healy Online content
John Healy  Online Content
They were designed that way!
It is not either or.
It is if both are a press fit you use a C3. Of course it depends on the press fit. The shaft and bearing dimensions are plus or minus about .001".
The problem with having the bearing a slip fit is, if the rotor nut comes loose the harder bearing wears the crankshaft. It can wear the shaft enough that it will need plating to restore the fit. So, while you can make it a slip fit, it isn't such a good engineering practice.
Re: A65 crankshaft end float [Re: jamie weeks] #717163
11/29/17 11:47 pm
11/29/17 11:47 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
Thanks John, point well made and now understood.
Re: A65 crankshaft end float [Re: jamie weeks] #717170
11/30/17 1:00 am
11/30/17 1:00 am
Mark Z Offline
Mark Z  Offline
I will defer to the advice given above. Using an old bearing with some material removed to test fit is an excellent idea. Also using a bearing puller, and sanding the bearing rather than the crank if sanding is needed (although it's easier to evenly sand an outer surface than an inner surface).
I was always able to get the bearings off the cranks on my A65s with just a bit of prodding.
Re: A65 crankshaft end float [Re: jamie weeks] #718193
12/09/17 2:11 am
12/09/17 2:11 am
6
69BSATONY Offline
69BSATONY  Offline
Thanks for the advise.I do have one of those bearing pullers. This bike was sitting outside for 30 years and whoever worked on it last didn't shim the crank at all so the bearing was stuck against the crank side pretty good. Plus by the red ish color under the bearing they must have used locktite by the gallon.
I bought a bearing with shims and cup from CBS in California. Soon as it gets here I will compare widths . If they are the same I'll use the old one to set things up and use the new one on final assembly.
Thanks again
Page 2 of 2 1 2
