Arlo
Arlo
Indianapolis, IN
35 registered members (AngloBike), 279 guests, and 412 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,170 mail-order LSR
Topics67,366
Posts654,078
Members10,288
Oil tank cap on 650SS keeps coming off ! #717523
12/03/17 1:30 am
12/03/17 1:30 am
Australia, N.S.W
the tanned gland Offline OP
Australia, N.S.W
Hi everyone, I've recently had a problem with the standard oil tank caps on my 1962 650 SS slimline loosening up & then disappearing off into the scenery despite making sure that they are done up tight before & during each ride, they've never done this before in the 35 years that I've owned her. I've lost two in rapid succession & the only reason I haven't lost a third is because I've chained the bastard on, but even so at the end of a 10 mile ride I'll find it hanging by it's chain & the inside of my right thigh oily : ( Has anyone else had these problems ? The first cap I lost was the original cap & the others are recent purchases but good quality English made ones, at around $55 a pop it's getting a bit expensive !
Eschew Obfuscation !
Re: Oil tank cap on 650SS keeps coming off ! [Re: the tanned gland] #717531
12/03/17 4:54 am
12/03/17 4:54 am
Qld, Aust and Otago,NZ
Ginge Offline
Ginge  Offline
There is no easy fix to this. The caps are not the problem, it's the bike. Keep the cap and send the bike up up to me in Mackay. I'll dispose of it for you.
Can you try an O ring around the threads ( if it's threaded ) or try cutting a fibre washer out of gasket paper or cork. Has the cap got tangs on it that you can tweak or bend?
Ginge
Re: Oil tank cap on 650SS keeps coming off ! [Re: Ginge] #717536
12/03/17 5:33 am
12/03/17 5:33 am
Australia, N.S.W
Australia, N.S.W
Nice try Ginge, I think I'll persevere some more just yet ! ; )
Re: Oil tank cap on 650SS keeps coming off ! [Re: the tanned gland] #717575
12/03/17 4:59 pm
12/03/17 4:59 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
Is it threaded cap ?
Re: Oil tank cap on 650SS keeps coming off ! [Re: the tanned gland] #717587
12/03/17 7:38 pm
12/03/17 7:38 pm
Hangtown, CA>
barncobob Online content
barncobob  Online Content
Hangtown, CA>
maybe some silicone sealant to keep it from rattling off, easy to remove..
Re: Oil tank cap on 650SS keeps coming off ! [Re: the tanned gland] #717590
12/03/17 7:55 pm
12/03/17 7:55 pm
Ottawa, Canada
gREgg-K Offline
gREgg-K  Offline
Ottawa, Canada
The oil tank cap is held in place like the Fuel cap: it is holds onto a collar via a 'bayonet' style fitting, and the claws of the cap are tensioned against that fitting with a spring inside the cap. Even if it works loose, the cap should not be able to undo far enough to come adrift, because the cap's claws should stay engaged with the bayonet fitting on the collar.
Could be that your new caps are not engaging the bayonet collar of the tank, or perhaps the collar is worn.
.. Gregg
magneto@spyder-it.com
Re: Oil tank cap on 650SS keeps coming off ! [Re: Adam M.] #717624
12/04/17 3:39 am
12/04/17 3:39 am
Australia, N.S.W
Australia, N.S.W
No, it's one of those 'Bayonet' type caps !
Re: Oil tank cap on 650SS keeps coming off ! [Re: gREgg-K] #717625
12/04/17 3:44 am
12/04/17 3:44 am
Australia, N.S.W
Australia, N.S.W
The collar is good, the bayonet clips on the cap are as new, i was wondering if it might be a build up of pressure in the oil tank, I've checked the breather hole in the cap, I haven't checked the breather tube exiting the tower yet but even so it shouldn't come loose, especially as it's never done anything like this before. The bike runs very smoothly too so I don't think vibration would be playing a major role in this !
Re: Oil tank cap on 650SS keeps coming off ! [Re: the tanned gland] #717634
12/04/17 5:39 am
12/04/17 5:39 am
Ginge Offline
Ginge  Offline
Can you add a bit of friction by tapping the bayonet indentations inwards towards the collar? Sounds similar to the Triumph oil cap. Spring loaded with a knurled outer ring.
Is the collar and neck on the tank out of round? Just an afterthought.
Ginge
Re: Oil tank cap on 650SS keeps coming off ! [Re: Ginge] #717983
12/07/17 12:28 am
12/07/17 12:28 am
Australia, N.S.W
Australia, N.S.W
I'll give that a try, sounds reasonable as the cap is a type fitted to a lot of British bikes including Triumph & BSA as well. If it works I'll let you know ! : )
Moderated by  Dave Comeau
