Ian Clifton
Ian Clifton
Rotherham, UK
44 registered members (barry2), 241 guests, and 474 spiders.
Tacet, Joe Bruney, Chip, Froger, Calthorpe
10413 Registered Users
btour 83
Triless 80
reverb 76
Stuart 72
703,383 mail-order LSR
Topics68,265
Posts664,585
Members10,413
A10 Super Rocket need help! #717975
12/06/17 11:36 pm
12/06/17 11:36 pm
San Francisco
Kazu Offline OP
Kazu  Offline OP
San Francisco
After I changed intake and exhaust valve guilds on a cylinder head, it doeson't start. It was running before the operation. The engine has compression and spark, and I cleaned a carburetor. I checked ignition timing is 3/8inch before top dead center. It has strong kick back and back fire but it doesn't start. Please tell me what can I think of why it doesn't start. Thank you!
Re: A10 Super Rocket need help! [Re: Kazu] #717990
12/07/17 1:30 am
12/07/17 1:30 am
tasmania australia
razor Offline
razor  Offline
tasmania australia
Are the plug leads the right way round.
Re: A10 Super Rocket need help! [Re: razor] #717993
12/07/17 2:47 am
12/07/17 2:47 am
Qld, Aust and Otago,NZ
Ginge Offline
Ginge  Offline
Strong kickback and backfire indicates it is sparking too early.
Reset timing closer to top dead centre. If it fires and runs then set the timing properly using a strobe or timing disk.
Ginge
Re: A10 Super Rocket need help! [Re: razor] #717998
12/07/17 5:47 am
12/07/17 5:47 am
+1
This won't take much and will eliminate one possibility.
Re: A10 Super Rocket need help! [Re: Kazu] #717999
12/07/17 6:21 am
12/07/17 6:21 am
San Francisco
Kazu Offline OP
Kazu  Offline OP
San Francisco
Thank you razor and Boomer! I tried to swich spark plug leads but it became after fire in extoust pipe instead of back fire. I will try to adjust timing, thanks Ginge!
Re: A10 Super Rocket need help! [Re: Kazu] #718023
12/07/17 1:36 pm
12/07/17 1:36 pm
Tridentman Online content
Tridentman  Online Content
Do you have manual or automatic advance/retard?
I think the Super Rocket had manual advance as standard but who knows what might have been changed in 50+ years.
You must have the advance/retard mechanism at full advance when timing it.
If manual then the lever must be in the right position.
If automatic then you must wedge the auto mechanism in the fully advanced position using small wooden wedges.\
Re: A10 Super Rocket need help! [Re: Kazu] #718172
12/08/17 10:40 pm
12/08/17 10:40 pm
Pushrods are in the correct place are they? If you’ve only done the head then the ignition and cam timing should not have changed... so why alter it?
If the pushrods are going the wrong way round then inlet valve will be open when exhaust is
Alternately, if you did change the timing... did you advance the magneto (assuming your still on manual advance being a Super rocket ( or wedge open the AAU mechanism if auto) when setting the timing to 3/8” btdc. From memory the crank angle is 37° or 38° BTDC for the super rocket. This will be more accurate way of timing.
