Britbodger R.I.P.
Britbodger R.I.P.
Houston Texas
18 registered members (Boomer), 259 guests, and 381 spiders.
bsapete, Kara Chaffee, Dan1818, Konaflyer, Begbie
10421 Registered Users
btour 88
Rohan 74
Triless 67
reverb 66
715,208 mail-order LSR
Topics68,345
Posts665,402
Members10,421
BSA A65 Big port valves #715081
11/14/17 6:27 pm
11/14/17 6:27 pm
France
pete Offline OP
pete  Offline OP
France
Hello to everyone,
Finishing actually the restoration of my BSA lightning, I'm waiting for the delivery of my head that had the following
modifications :
- Inlet port to 32 mm with 43.5 inlet valves
I have twin AMAL carbs 389 1' 1/8 (Main jet 220 / Throttle : 3 1/2 / Pilot jet : 106)
My questions :
Do I need to rebore my carbs to 32 mm to maximise the performance of my engine ?
Pete
Re: BSA A65 Big port valves [Re: pete] #715091
11/14/17 7:37 pm
11/14/17 7:37 pm
John Healy Offline
John Healy  Offline
What are you going to do with this engine? Are you looking for top speed, maximum acceleration, or a good all around motorcycle?
Re: BSA A65 Big port valves [Re: John Healy] #715165
11/15/17 5:36 am
11/15/17 5:36 am
France
pete Offline OP
pete  Offline OP
France
=> => => "a good all around mtorcycle".
Re: BSA A65 Big port valves [Re: NickL] #715234
11/15/17 5:53 pm
11/15/17 5:53 pm
France
pete Offline OP
pete  Offline OP
France
Thanks Nick for your reply.
What settings do you recommend => Throttle cutaway, main jet, pilot jet ??
Re: BSA A65 Big port valves [Re: pete] #717545
12/03/17 8:58 am
12/03/17 8:58 am
Not sure what Nick has posted as it wasn’t on the thread,
For a good all round bike the standard head is fine, however the earlier 68-466 head is quite tractable (it has a 1,1/8” port tapering to 1,1/16, about 1/4” in is the taper) these work well with the change from 38mm valve to 40mm and I have 32mm carbs mounted to mine, although they do pull very well with 28mm and for standard road use will be more tractable still.
In comparison the bigger port head will seem flatter at certain points in the Rev range and will work well... but only within a smaller RPM window, the smaller port head will pull much stronger over a bigger window. Cam will make a difference also.
Re: BSA A65 Big port valves [Re: pete] #717562
12/03/17 2:35 pm
12/03/17 2:35 pm
derby england
wak Offline
wak  Offline
derby england
the carbs should always be bigger than the port or at least the same size,
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA Gold Star Daytona
BSA Gold Star Scrambler
BSA Rocket Gold Star
BSA C15S
BSA Cyclone
Triumph T120
Triumph T100 Daytona
Triumph 5TA Trials
Triumph T100 Scrambles
Cheney 560 TT
Re: BSA A65 Big port valves [Re: pete] #717620
12/04/17 12:46 am
12/04/17 12:46 am
Thunrbolts have 1,1/8” ports (28.5mm) yet they still match them with 28mm carbs, so half an inch is neither here nor there,
Re: BSA A65 Big port valves [Re: pete] #717781
12/05/17 2:36 pm
12/05/17 2:36 pm
derby england
wak Offline
wak  Offline
derby england
That wasn't a serious answer was it Allan , thunderbolts are single carb with a Y adapter which goes a lot smaller , having a smaller carb than the port drops the gas velocity
BSA lightning
BSA B50MX
TRIUMPH TR6C
BSA BUSHMAN
BSA C15S
BSA Cyclone
Triumph T120
Triumph 5TA Trials
Cheney 560 TT
Re: BSA A65 Big port valves [Re: pete] #717816
12/05/17 6:42 pm
12/05/17 6:42 pm
Mississauga, Ontario.
Adam M. Offline
Adam M.  Offline
Khm, smaller ports give higher gas velocity, but less volume.
Moderated by  Allan Gill
