pittss1s
pittss1s
hamilton, va
29 registered members (Al Eckstadt), 177 guests, and 353 spiders.
10476 Registered Users
NickL 89
franko 72
Triless 67
746,785 mail-order LSR
Topics68,808
Posts670,219
Members10,476
Page 22 of 24 1 2 20 21 22 23 24
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #695393
05/16/17 12:51 am
05/16/17 12:51 am
Maybe some pictures after that Springfield mile? I always thought by now I'd have enough spare time hit things like that. Not yet. I rode my 66 today, first time in 3 or 4 years. Never anything wrong with it, but I started robbing parts off it. Felt good, runs strong. This is one I want to change back to ET now that I have some nice stuff stashed.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #695398
05/16/17 1:09 am
05/16/17 1:09 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Speaking of west coast Hornets, do yal have the same issue as I do...can't get the oil drain plug/filter all the way out as it hits the frame tube after it is unscrewed about 3/4". Have to unbolt the oil tank at its rear, but can't kick the bottom outward to unscrew the plug until the smaller 5/16" oil line is removed which is up against the forward frame tube. Even with the hose removed, the hose spigot in the tank is in the way up against the frame tube. A real design nightmare.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #695568
05/17/17 3:15 pm
05/17/17 3:15 pm
Nor Cal
Roadwarrior Offline
Roadwarrior  Offline
Nor Cal
I am going to use the "S" 37 degree hole on my 3 hole rotor. My manual must be older because it only shows the 2 hole rotor, with the "S" being 34 degrees for the 500, and the "R" for the 650 being 37 degrees. The 3 hole rotors have the "R" at 41 degrees. Here is a picture. It is getting close, but is not show stock. I had a west coast Hornet in 1969, and I seem to remember that most of these were modified within a month of being sold. I went East Coast pipes for 2 reasons. 1. I like the look better, and 2. My side stand lug is missing. I went with the B44 Front fender, because I had one, and it fit nice. I still have to paint the side covers, so they are not on yet. The heat shields have been installed since the picture. I plan to use it on the street. Hopefully that will quiet it down a bit. The foot pegs are a little funky, still working on that.
Who are the brain police?
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #695573
05/17/17 3:43 pm
05/17/17 3:43 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
I know someone that has a set of used TT pipes for sale. They need work...scrapes and dents.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #702321
07/20/17 7:23 pm
07/20/17 7:23 pm
Tom A65LR Offline
Tom A65LR  Offline
The link to pages 1-64 will not work for me. I would like to see Gary's post on restoring fiberglass side covers.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Tom A65LR] #702325
07/20/17 7:40 pm
07/20/17 7:40 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
I will contact John G. to reset the server that has all of it on it. It's his server.
Then, the next problem to resolve is Photobuckets nixing of all of the images...everywhere. Once John resets the server so we have access to those first 64 pages, then I will have to go find the posts that you are interested in, and reload those particular images to a different image Hosting site and reload those image links to that particular thread page. I will do that.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #702400
07/21/17 10:47 pm
07/21/17 10:47 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
John has reset the server, so the first 64 pages link in the first post on this thread now work. I will now attempt to find the posts on the subject of restoring the fiberglass covers and replace the associated images.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Gary E] #702412
07/22/17 2:13 am
07/22/17 2:13 am
Tom A65LR Offline
Tom A65LR  Offline
Thank you, Gary. They are on page 24, in case you have not yet found them. I am grateful for help.
Regards, Tom
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #702485
07/22/17 5:53 pm
07/22/17 5:53 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
I was not able to re-create the images on the original first 64 pages. It doesn't let me edit. What is there, or not there, is locked in stone. So PhotoBucket has really f...ked us again. So, what I have done is re-created here the whole post on that original page 24, plugging in the original images. Any one that has a desire to have the same applied to any of the other posts I made in those original first 64 pages, I will do it upon request.
Page 24 Post #354129 1/21/2011 11:57AM
SIDE COVERS AND FIBERGLASS RESTORATION
Does your Hornet, or for that matter any model, fiberglass side covers look like this (note the five layers of paint added over the last 44 years)?
OR THIS? And look at the stress cracks in the gel coat that will always continue thru every layer of re-finishing if not repaired first. And a real brilliant idea by someone for the location of the switches and ignition switch.
And you want them to look like this?
It can be done with work. Here is what has been done to get them ready for primer and paint.
After stripping all layers of paint of via sanding, stripping agent, or medium blasting, The stress cracks are ground out thru the gel coat to the underlying glass. Be careful how far you go as the glass is thin in places. The glass is not glass cloth mat but typically shot into the mold from a course chopper gun, so the covers have various thicknesses in places. The ground out areas are then filled with an appropriate 2-part glazing putty.
Some repairs require glass work. With the covers below, mounting holes needed to be rebuilt, a broken cover (in the typical front spot) needed repair, and the lower portion of the cover was too thin to hold up well in the future. Also, the top corner was reinforced on each where it is in constant contact with the frame (even with the buffer in place). It is usually a source of stress cracks in a new finish.
After restoration, hopefully the covers will hold up well for the next several years...until the next guy decides to shortcut the re-finish process with an old can of spray paint from his garage.
_________________________
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #702507
07/23/17 1:30 am
07/23/17 1:30 am
Kinda feels like the end of an era.......or the end of something. anyway. We all used photobucket and recommended it to others. This big, long thread was a goldmine for anyone working on mid-sixties A65s. Kinda happened just as I am moving on to flathead Fords as my chief obsession. Gary: hope you are doing well, and many thanks for all the time and effort you put into this deal.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #702510
07/23/17 2:42 am
07/23/17 2:42 am
wadeschields Offline
Yes Thanks for the extra effort Gary !!
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #702542
07/23/17 12:40 pm
07/23/17 12:40 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Thanks fellas. I also have switched gears a little bit. Although vintage bikes are still very prominent here, the current project in this shop is a 1942 WWII carbon arc 60" searchlight. A really big headlight, or as my friends call it, my big flashlight. Anyway, keeping on the subject of the of the Hornets and the Wasp, the "Three Tenors" are at a museum up in the northern part of the state for four months this summer. So, the shop looks like it needs more bikes in it.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: leon bee] #702557
07/23/17 3:35 pm
07/23/17 3:35 pm
melbourne florida
bodine031 Offline
bodine031  Offline
melbourne florida
There is a Ford Flat Head guru here in Ocala Fl. Friends call him "Big" His real name is not Mr.Earl but Big Daddy Don Garlits
You can catch him at his Museum Of Drag Racing in Ocala Fl.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #704575
08/11/17 12:34 am
08/11/17 12:34 am
I'm getting to the point of installing the front end onto my frame...
Got to the point of installing the damper assembly, and I need to ask; the connection to the frame for the steering limit plate, is it just supposed to be a flat bar?
And isn't the plate supposed to go above the flat bar?
My frame seems to have two "fingers" sticking up, 90 degrees from the plane of the bar.... These will not let me mount the plate above the bar.
Help!?
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Rickman] #704674
08/11/17 10:37 pm
08/11/17 10:37 pm
V
VicCyclone Offline
VicCyclone  Offline
V
Sounds like you've got the wrong damper plate. The flat one (same as A10) only fits frames up to 1965. The later one is turned up 90 degrees to match the "fingers"
VicCyclone
1965 A50 Cyclone Clubman
1966 Victor GP
1967 Victor Special
1968 Victor Special
1968 A65L
2009 HD FXDC
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #704675
08/11/17 10:49 pm
08/11/17 10:49 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
None of them are flat. All have bends and curves in them. The correct one has a bolt welded at the back of it. The best view of the proper one is in the '68 Spares manual, page 48, item 30, part number 68-5185 (anchor plate). The '66/'67 Spares manual has the old style shown.
And the Friction Washer goes on top of the anchor plate along with the special Spring Washer.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: VicCyclone] #704685
08/12/17 2:36 am
08/12/17 2:36 am
Thats interesting Vic,
I have one of those for my '69.... and there aren't any fingers, it's a full loop with a slotted hole so the 90 degree plate can be slide adjusted...
Another interesting thing I've found; there are at least 2 different "flat ones"... I have both...
Is that "special spring washer" the 'star' shaped one? Or something I'm still missing?
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Rickman] #704719
08/12/17 12:31 pm
08/12/17 12:31 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
The '69 anchor plate is the same as the '68.
You are still missing something.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #711291
10/12/17 3:52 am
10/12/17 3:52 am
Thanks for the photobucket fix Daryl D .... I can see all the photos again
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #715865
11/20/17 1:13 am
11/20/17 1:13 am
Essex, UK
A65_lover Offline
A65_lover  Offline
Essex, UK
Folks,
I hadn't picked up on post #702485, the left hand side panel on my 1967 West Coast Spitfire has these holes - I had thought that a previous owner had just been creative – was the switches move a common modification or just something that Hornet users did to protect switches from off-road damage?
All the best,
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #715869
11/20/17 1:38 am
11/20/17 1:38 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Not a common modification that I know of. Just something a particular owner decided to do back in the day. The big hole looks to have been for the ignition switch. The changes are not neccessarily done only on Hornets. It could have easily been done to a side cover on any year or model machine.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #717492
12/02/17 8:21 pm
12/02/17 8:21 pm
new jersey USA
goldstarfreddie Offline
new jersey USA
anyone know where i can purchase a rh tt pipe for a hornet thanks
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: goldstarfreddie] #717517
12/03/17 12:16 am
12/03/17 12:16 am
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Dang. The right side. I know someone that has a single pipe, but it is the left side. Figures.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: ] #736103
05/21/18 9:10 pm
05/21/18 9:10 pm
Medford, Oregon
Gary E Offline
Gary E  Offline
Medford, Oregon
Thanks for the info on the two machines.
Unfortunately, neither bike is very original. Neither one has original factory BSA TT pipes, and both rear fenders have been bobbed. Those two items are very hard to source. The eBay bike looks to have Triumph style TT pipes on it.
Re: Hornet, Wasp, Spitfire Hornet, Cyclone (Restored) [Re: Two Alpha] #749806
09/20/18 12:40 am
09/20/18 12:40 am
california
Mark M. Offline
Mark M.  Offline
california
Been reading a lot on this thread. Very helpful info. I just fired up my 65 Hornet after sitting for a few years and had to go thru the dreaded Leaking stock tank. It was a perfect tank a few years ago and stupid me, i left a small amount of gas in it over the years. Any way, I have a steel India tank on it now, even thou it has the 66 and later style gas cap, I will run it for the time being. My question is. I have the stock AMAL monoblocs on it, but it runs some what erratic. I put new slides in it just to try it out, but i am not happy. Has any one tried Lunds rebuilding their original carbs? I see i can by new AMAL's, but???????????????? Just trying to decide which way to go. Any comments would be appreciated.
