Arlo
Arlo
Indianapolis, IN
35 registered members (AngloBike), 280 guests, and 413 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,170 mail-order LSR
Topics67,366
Posts654,078
Members10,288
Greasing the Speedo Drive #717405
12/01/17 5:26 pm
12/01/17 5:26 pm
Oceanside California
mrcarb Offline OP
mrcarb  Offline OP
Can someone tell me how to grease the speedo drive on the rear wheel? I tried the grease tool that I use on a cars front steering and cannot get grease into it. Maybe I need a different grease fitting on the tool or a different zerk fitting on the speedo drive.
Re: Greasing the Speedo Drive [Re: mrcarb] #717407
12/01/17 5:48 pm
12/01/17 5:48 pm
You need a UK grease tool, doubt you can get the nipple with a Zerk head and the thread Smiths used, 2BA thread from memory. Alternatively remove the drive and hand pack the grease from the inside.
Re: Greasing the Speedo Drive [Re: kommando] #717411
12/01/17 6:51 pm
12/01/17 6:51 pm
Canada
LarryLebel Online content
LarryLebel  Online Content
Canada
I replaced all the grease nipples on my B44R with North American versions. The threads were not exactly the same but with only 2 or 3 threads involved it didn't make any difference.
Re: Greasing the Speedo Drive [Re: mrcarb] #717415
12/01/17 7:29 pm
12/01/17 7:29 pm
New Jersey
Keane Lucas Offline
Keane Lucas  Offline
New Jersey
If you change the nipple,make sure the threaded length,is not too long as screwing it all the way in,
will create interference with the drive,affecting your speedometer reading.
My experience.
I use a Lincoln #5803 'needle nozzle'.
Push the spring loaded ball in, and grease.
Since you need 3 hands-
I leave the gun on the ground,hold it with my knee,hold the needle,square and firm to the nipple,
If there isn't any ancient petrified grease in there,
a pump, or maybe two, should suffice.
You should see a radial pattern of grease,after the first ride.
1969 BSA A65T w/A70 engine
1970 Royal Enfield Interceptor S ll
Re: Greasing the Speedo Drive [Re: mrcarb] #717438
12/02/17 1:00 am
12/02/17 1:00 am
Mullaloo Western Straya
Bodie Offline
Bodie  Offline
The method I use is to slip a couple of small O rings over the original nipple ..
.. push the grease gun firmly into place & Bob's your uncle ,
You still can't beat pulling it apart once in a while to clean out the old crud & repack fresh grease in around the larger outer drive ring ,
Re: Greasing the Speedo Drive [Re: mrcarb] #717468
12/02/17 4:37 pm
12/02/17 4:37 pm
California, US
Peter_Joe Offline
Peter_Joe  Offline
California, US
I have a Needle Nose Adapter for Grease Guns that works great for the speedometer drive as well as those oddball British grease fittings. I also use it on my car universal joints. You should be able to get one at your local auto parts store.
Here is an example:
http://www.partdeal.com/alemite-needle-nose-adapter-for-grease-guns-b6783.html
Also available is a mini grease gun with a needle point already built into it which could be handy for speedometer drives.
Here is an example:
http://www.denlorstools.com/home/dt..._101_mini_grease_gun_with_needle_no.html
If you do an online search there are other examples that you may interest you.
I hope this helps.
Peter Joe
