Arlo
Arlo
Indianapolis, IN
35 registered members (AngloBike), 280 guests, and 413 spiders.
vietnammotorbike, Lennart Liljedah, Mal Wood, FireGuyKC, spuggy
10288 Registered Users
Stuart 94
Lannis 65
Mori55 60
636,170 mail-order LSR
Topics67,366
Posts654,078
Members10,288
Need help identifying part #717334
12/01/17 4:53 am
12/01/17 4:53 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I'm putting my a65 lightning engine back together and ran into a problem. With the baggie of parts to put the crankshaft pinion gear etc back on I found a small metal dowel pin that is magnetic. I can't find a reference to such a part anywhere. Any ideas what it is? Thanks.
Re: Need help identifying part [Re: J. Grant] #717341
12/01/17 5:43 am
12/01/17 5:43 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Nothing to do with the pinion gear. How small? The oil pump has small (~1/16"?) dowel pins to align the parts.
Re: Need help identifying part [Re: DMadigan] #717344
12/01/17 6:02 am
12/01/17 6:02 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
Thanks.I think that is the answer. I only have the one and it fits snugly into the pump but is loose on the case side. The fork on the oil pump for the tach has one side missing so I think I have to buy a new one anyway.
Re: Need help identifying part [Re: J. Grant] #717345
12/01/17 6:08 am
12/01/17 6:08 am
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I just looked at some pictures and saw that the dowel pins are inside the oil pump used to locate th two halves of the pump together. Is there also two dowel pins that mate the pump to the case?
Re: Need help identifying part [Re: J. Grant] #717366
12/01/17 11:43 am
12/01/17 11:43 am
Au
markoz Offline
markoz  Offline
Au
There is no locating pins for the oil pump and cases that I remember.
I think a photo is needed.
If your not fitting a tachometer the busted tang won't matter.
Re: Need help identifying part [Re: markoz] #717418
12/01/17 8:01 pm
12/01/17 8:01 pm
los angeles
J. Grant Offline OP
J. Grant  Offline OP
los angeles
I don't have those dowels inside my pump but the one i found is between the size of the ones in the pump and the ones that locate the gearbox to the case. Weird thing is that it is magnetic so I'm wondering if it was just somewhere laying around and "hitched a ride". Only one of the tach drive tangs is missing and I'm not sure if it was working before I took it apart (wasn't running when got it). It would seem to work with just one tang but not sure about strength?
Re: Need help identifying part [Re: J. Grant] #717422
12/01/17 8:43 pm
12/01/17 8:43 pm
gavin eisler Online content
gavin eisler  Online Content
I think its a stray from something else, the TS gasket face has one or two dowels depending on year, the oil pump halves have two small dowels internally, thats it for dowels on the TS. The pump is not doweled to the cases.
My tach worked with a broken drive tang, I did replace the worm/ tang when I found it . usually a broken drive tang is matched with a nasty chisel mark on the gasket face where the DPO forced the cases apart, thus breaking the drive tang.
