Lliam Harrison
Lliam Harrison
Windham ME
47 registered members (Al Eckstadt), 286 guests, and 400 spiders.
10256 Registered Users
Lannis 62
608,687 mail-order LSR
Topics67,112
Posts651,274
Members10,256
Wiring harness for 1969 t120r and tr6c #713228
10/30/17 4:51 pm
10/30/17 4:51 pm
Nashville TN
jchildr Offline OP
jchildr  Offline OP
Nashville TN
Can anyone tell me the difference between wiring harnesses 54955719 (for the 1969 tr6c) and 54955257 (for the 1969 t120r)? Can they be interchanged without modifications? Also, can you tell me what gage wire is used in these harnesses. Thanks.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713237
10/30/17 6:49 pm
10/30/17 6:49 pm
Geneva, Switzerland
BrettF Offline
BrettF  Offline
Geneva, Switzerland
hello, my understanding is that originally the wires were similar to this 14xSTRANDS, RATED 8.75 AMPS, OD 1MM SQ (.040") while I was recommended to use this : 32xSTRANDS,RATED 16.5 AMPS, OD 1MM SQ(.040").
As for the difference between the two harnesses I do not know. Two horns vs. one are the only difference I can think of though. a look at the schematic should clarify this.
Bikes:
'69 T120 on average (1967 rolling frame and 1971 Bonnie engine)
'56 1/2 T110 on average (58 rolling frame - with 55 iron head engine)
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713241
10/30/17 8:21 pm
10/30/17 8:21 pm
Isle of Wight, UK
koan58 Online content
koan58  Online Content
Isle of Wight, UK
Hi jc,
A quick look at the TMS Nottingham site lists all models as being the same for any year in the late 60's. I don't know if there were any differences, electrically, between the T120 and TR6C, but I am sure they would be trivial (eg maybe indicators or not) and I'd expect the harness to have provision for all the various models.
For any more detailed reassurance, wait for Stuart to come along, if he's not on holiday again! He knows the ins and outs of a wiring loom's arse! Dave
Re: Wiring harness for 1969 t120r and tr6c [Re: koan58] #713263
10/30/17 11:35 pm
10/30/17 11:35 pm
USA, WA state
russrudolph Offline
russrudolph  Offline
USA, WA state
I have a 1969 tr6c that I received in pieces. I bought a new Lucas harness for the bike. Harness was not equipped with the kill switch wires. I also have a 1969 tr6c that I have owned for 40 years and it has wires for the kill switch. I purchased a new Lucas 719 harness but have not installed harness yet. Just left 2 wires from kill switch loose inside tank and frame. New 719 harness in a drawer too lazy to change.
I also think wiring for ammeter is different bur not sure.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713291
10/31/17 1:47 am
10/31/17 1:47 am
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
So,...... Which one are you working on? I have an original NOS cloth covered harness for the '69 TR6C bought years ago and did not use. P/N on the old tag is 54955719. Wired the bike myself, and did so as Negative Ground/earth/minus/ whatever you care to call the low. I happen to see this post today as I was picking through things to sell.
Oops,.. add 1 Sporty
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713293
10/31/17 2:12 am
10/31/17 2:12 am
australia
tiger_cub Offline
tiger_cub  Offline
australia
TMS actually list 3 harnesses for 1969 - MC127 for T120R, MC133 & MC134 for TR6C (main differences are no ammeter on TR6C plus options for front brake switch & kill switch as noted above).
1970 TR6C
1970 TR6R
1974 T120RV
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713295
10/31/17 2:21 am
10/31/17 2:21 am
KC in S.B. Offline
KC in S.B.  Offline
How about the dangling Blue Capacitor Can?
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713327
10/31/17 10:30 am
10/31/17 10:30 am
Stuart Offline
Stuart  Offline
How long is a piece of string? Are the ones you're looking at original? If so, they're fifty years old.
If they aren't original, who were they made by? In theory at least, it should be possible to fit a T120R harness to a TR6C and simply join the Brown/Blue and Brown/White in the headlamp (that attach to the ammeter on a T120R or TR6R). In practice, some modern harness makers' interpretations of 'original' vary ... somewhat ... cool
Also bear in mind that certainly originally, a single harness didn't always make all the connections between everything; there were small harnesses to connect, say, the main harness and the ignition switch. Modern harness makers don't always supply these, or do so at extra cost ... frown
Original wire gauges vary. Ime, original wires were based on 32SWG (No.32 (British) Standard Wire Gauge) strands; wires to individual components were 14-strand, rated for 7.5 Amps, the wire between ignition switch and the junction of individual components' White wires was 28-strand, rated for 15A, the Brown/Blue, Brown/White and main Red were 42- (-ish) strand, rated for 22.5A.
Lucas did supply original harnesses with all-14-strand 32SWG wire but ime only '71-on. Note that the rating of either 14-strand Imperial or metric wire (that Brett posted) used to link rectifier and Zener is exceeded by the alternator output above about 2,000 rpm. In a '69 harness, if you find 14-strand used for main Red (to battery), Brown/Blue, Brown/White and either White or White/Blue from the ignition switch, the harness is poor-quality. frown
The problem of modern wire gauges is vexing but worth taking the time to understand, if only because it'll inform your choice of harness and also you will need to make changes and/or repairs at some time in the future:-
. The vast majority of connections in Britbike harnesses, including '69, are 3/16" o.d. (4.7 mm. equivalent, be wary of any supplier that quotes "5 mm.") 'bullet' terminals joined by tubular black-insulated 'snap connectors'. The most important criterion certainly of original-looking bullets is they stay on the conductor by friction, having been squeezed by a hex. crimping tool - Lucas stopped soldering years before '69.
. Brett mentioned the modern metric equivalent of one of the original Lucas wire gauges - "14xSTRANDS, RATED 8.75 AMPS, OD 1MM SQ". Original-looking crimp-on bullet terminals are only available as standard for this wire gauge, plus the metric 28-strand and 44-strand equivalents. None are available for any other wire gauges, including original Lucas, AWG (American Wire Gauge), the one Brett says he was "recommended to use" or any of the weird ones some pattern harness makers seem to be able to find. Modern bullet terminals vary a little by how much they can be squeezed when crimping; in certain circumstances, certain bullets can likely be make to 'work' on conductor they aren't sized for but it's a minefield. frown
Finally, bear in mind that almost any off-the-shelf harness will be a good or bad copy of an original, so it'll have connections to separate rectifier 'n' Zener, points, condensers, etc.; if you're considering modern reg./rec. (modern Zeners are particularly poor-quality eek) and/or e.i., as you're in the US, I'd strongly recommend at least talking to British Wiring; I know they use the aforementioned modern metric equivalent wire, terminals and connectors; aiui they can supply a harness without rectifier/Zener/points/condensers connections you then otherwise have to tape up ...
Re: Wiring harness for 1969 t120r and tr6c [Re: russrudolph] #713338
10/31/17 12:42 pm
10/31/17 12:42 pm
Stuart Offline
Stuart  Offline
Hi Russ,
Originally Posted by russrudolph
I have a 1969 tr6c that I received in pieces. I bought a new lucas harness for the bike. Harness was not equipped with the kill switch wires. I also have a 1969 tr6c that I have owned for 40 years and it has wires for the kill switch.
I'd be interested if you could clarify? The contemporary harnesses and (push-to-break button) kill switches I've seen, the White supply wire to the coils has a bullet terminal:-
. either into a big snap connector with other components' White wires and the (usually) White/Blue wire from the ignition switch;
. or into a single snap connector into a short White wire into a more-permanent crimped insulated connector with the other aforementioned wires;
. inside or around the headlamp area.
A kill switch then has two wires with bullet terminals, one's connected into the aforementioned snap connector in place of the coils' White wire, the other's connected just to the coils' wire with another snap connector?
Re: Wiring harness for 1969 t120r and tr6c [Re: Stuart] #713351
10/31/17 2:20 pm
10/31/17 2:20 pm
USA, WA state
russrudolph Offline
russrudolph  Offline
USA, WA state
The original harness that cam with the 1969 tr6c I bought in 1975 has bullet connector to the white coil wires.
The new cloth wire harness for the 1969 tr6c I bought in pieces. Cloth Harness purchased from forum advertiser did not have bullet connectors for the kill switch. Only noticed this after installation. I have not fixed the kill switch. Again very lazy. I have only ridden bike a few miles since the rebuild.
I purchased a new Lucas harness 54955719 but have not opened the package. Will look at harness to see if it has bullet connectors for kill switch. Just thought it would be nice to have original 54955719 harness in reserve for my 3 1969 tr6c's
I have seen the on eBay a wiring harness to add the blue capacitor to a 120 harness.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713368
10/31/17 4:45 pm
10/31/17 4:45 pm
Nashville TN
jchildr Offline OP
jchildr  Offline OP
Nashville TN
Thanks everyone. The reason for this post is as follows: I have a 1969 T120R. My builder wrote down all the part numbers used to restore the bike. The part number he wrote down for the wiring harness was 54955719. I could not reach him at that time to verify. I finally was able to reach him after I made the post. He wrote down the wrong part number. He should have written down 54955257.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #713726
11/03/17 4:00 pm
11/03/17 4:00 pm
Lancaster, California
C.B.S Online content
Parts Dealer
C.B.S  Online Content
Parts Dealer
I'm pretty sure the TR6C has the 2MC capacitor. Also keep in mind that the headlight shell has different switches and indicators then a STD T120R
Re: Wiring harness for 1969 t120r and tr6c [Re: C.B.S] #713835
11/04/17 3:45 pm
11/04/17 3:45 pm
Stuart Offline
Stuart  Offline
2MC capacitor can be fitted to anything; if the wiring harness doesn't have the connections in the Brown/Blue wire and a Red wire, just connect the cap.'s -ve and +ve terminals to battery terminals.
Depends which year; the o.p. specifically said '69. All '69 have a headlamp hi/low switch and horn button; only difference on a C is only the horn button's on the handlebar, the hi/lo switch is in the headlamp shell; assuming by "indicators", you mean the o.p. warning and high beam warning, all '69 have 'em both in the headlamp shell.
Hth,
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #715408
11/16/17 7:35 pm
11/16/17 7:35 pm
Nashville TN
jchildr Offline OP
jchildr  Offline OP
Nashville TN
Hello Stuart. I called British Wiring to ask about their wiring harness for my 1969 T120R. The part number is MC27PB. They said this harness is built totally with 14 strand British (SWG) wire rated at 8 amps. Do you think this harness is poor quality? They also said this wire is comparable to 18 (AWG) wire. 18 (AWG) is rated at 13 amps. This does not seem comparable to me. What am I missing here? I know you can't believe everything you here and read, but there are lots of charts comparing British (SWG) to American (AWG). The chart I saw says 14 strand SWG is rated at 13 amps. There is also a Wire Gauge Comparison Chart in my 1969 Triumph Workshop manual. In the first column it has the number for the wire gauge. In the next two columns, it has the Imperial (SWG) diameter size in inches and millimeters. In the next two columns, it has the American (AWG) diameter size in inches and millimeters. In this chart, 18 gauge is .048 in (Imperial SWG) and .040 in (American AWG). I actually measured the bare wire from both 14 strand SWG and 18 gauge AWG and I got the same measurement as the chart in my 1969 Triumph Workshop manual. I understand amperage is determined by the diameter size of the bare metal of the wire. If this is true, then these two wires should have approx. the same amperage or current carrying capacity. Am I correct in this assumption? Any thoughts would greatly appreciated. The following website has a good article explaining British (SWG) wiring. https://books.google.com/books?id=9...%20stranded%20wire%20numbers&f=false
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #715992
11/21/17 1:07 am
11/21/17 1:07 am
Stuart Offline
Stuart  Offline
blush Sorry about the delay replying; I read this a few days ago, couldn't answer straight away, the forgot about it 'til a light-bulb moment ...
frown Regrettably, whoever you spoke to was talking from an orifice other than the one in the lower half of his face ... I couldn't get SWG wire in GB in the early 1980's, so I doubt it's available in the US at the back end of the second decade of the 21st century. And 14-strand wasn't rated as high as 8 Amps ...
The wire he was talking about was undoubtedly this, as that's one wire BW actually sells.
Mmmm ... this is an "apples and oranges" comparison; depends what you want out of it. If it's the answer to, "Are they both round?", the answer is, "Yes."; otoh, if the question is, "Are they the same colour?" or "Do they taste the same?", the answer is obviously, "No."
To be absolutely clear, the wire BW sells is neither SWG nor AWG but metric - that "14 strand", "8 amps" is better-known as '14/0.30' and/or '1 sq.mm.', meaning 14 strands, each strand is 0.3 mm. o.d., total conductor cross-section is 1 sq.mm.; it's actually rated for 8.75 Amps. Certainly BW started out being supplied by Autosparks - BW's early catalogues were a straight copy of contemporary Autosparks' ones and BW still uses the same Autosparks part numbers. If Autosparks still supplies BW, wire is neither SWG nor AWG and - digressing slightly - the bullets that look like the ones used in your bike's original harness will only work with the specific conductors they're sized for, they aren't available in SWG (or AWG) either ... smile
That "website" is actually a book of the same name. I disagree completely that it is a "good article": the page you've linked varies between over-complication and utter rubbish - e.g. "British car makers often used wire with different numbers of 0.1in (0.3mm) diameter strands", "Standard Wire Gauge (SWG) under BS3737: 1964 but that has since been largely superseded by AWG", etc. is horse-feathers. frown
British vehicle makers (including motorcycle makers) didn't do anything of the sort. The vast majority (including Triumph when BSA, NVT and the Co-op) were supplied by Lucas with wires made of SWG strands; the strands of 14-strand wire were 32SWG; 32SWG is 0.274 mm. o.d., so slightly smaller that the aforementioned metric 0.03 mm. o.d. strands; Lucas rated 14/32SWG wire for 7.5 Amps. AWG is utterly irrelevant, except possibly to an American rewiring a vehicle with wire he/she is sure is AWG-size.
Given the linked page is largely (all?) complete cobblers, 'fraid I've no idea where whoever compiled the accompanying table got the "Maximum recommended current" values from. eek Fwiw, they actually look more like fuse Amps values I've seen on some AWG tables on the www ...? Or ime, AWG current capacities on the www are often quoted for a solid conductor not insulated; insulation material has an effect on heat dissipation - e.g. metric specs. show a difference in current capacity just when the same conductor is encased in different PVC! Certainly they aren't sensible wire ratings.
I had been planning to get that book; I'm very glad I didn't.
Mmmm ... I've been recommending British Wiring based on earlier recommendations on this Forum, and those that've reported back have been very satisfied.
I'd be extremely disappointed if it turned out BW was really making '69 (any pre-'71) harnesses entirely out of that 14-strand metric wire: Lucas rated the standard RM21 alternator on your bike for 10.5 Amps @ 5,000 rpm and 75% @ 2,400 rpm. So the carrying capacity of 14-strand metric wire at least between rectifier and Zener would be exceeded above about 3,000~3,500 rpm. frown
For this reason, ime Lucas didn't use 14-strand for any of the original wires between battery, ammeter, rectifier, Zener and ignition switch, nor the main Red wire to battery +ve; they were all at least 28-strand (original Lucas rating 15 Amps when made with 32SWG strands).
To be clear, I appreciate all wire ratings have a safety factor, so 8.75A 14-strand metric wire isn't about to disappear in a puff of smoke when faced with the full output of the standard T120R alternator. However, even the retail cost of modern 17.5A or 25A 28-strand is pennies, the cost to BW to put it in a harness is fractions of a penny. Anyone buying a BW harness is not paying for cheap short-cuts. mad
Nevertheless, as I say above, simply the BW person you spoke with was talking out of his backside; it's possible someone more-knowledgeable can confirm they do use 28-strand where they should?
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #716061
11/21/17 4:17 pm
11/21/17 4:17 pm
Nashville TN
jchildr Offline OP
jchildr  Offline OP
Nashville TN
Thanks Stuart. I forgot to mention that my bike has a 200 watt alternator and Boyer-bransden mark iv electronic ignition. I just wanted to know if someone makes a modern harness that can handle that. My bike builder says my bike has an original 1969 Lucas wiring harness. The cloth wrap on the harness is black with little green markings. Will an original Lucas harness handle a 200 watt alternator and Boyer-bransden electronic ignition? Thanks.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #716139
11/22/17 12:13 am
11/22/17 12:13 am
Stuart Offline
Stuart  Offline
I forgot to mention that my bike has a 200 watt alternator and boyer-bransden mark iv electronic ignition. I just wanted to know if someone makes a modern harness that can handle that.
Yes and no.
There isn't an off-the-shelf one but, in the past, I've suggested to US owners wanting similar to approach British Wiring with a list of modifications; owners that've replied have said BW was willing to make the modified harness. The mods. I've suggested are:-
. I'm guessing your bike also has a modern combined regulator/rectifier? With a higher-output alternator, the aforementioned 14-strand wire is most definitely unsuitable for the Brown/Blue, Brown/White and battery +ve main Red wires, and the main White or White/Blue wire from the ignition switch to the junction of individual component White wires.
. Ideally, these wires should be in 25A thinwall, aka 28/0.30 2 sq.mm. thinwall. If that isn't available, the wire(s) should be 17.5A, also 28/0.30 2 sq.mm. but in a different PVC insulation.
. The harness doesn't need a Brown/White to the Zener position.
. At the same time, the thick Red wire to battery +ve should be the only one (the standard harness normally has at least two) and it should contain a modern blade fuse holder (and fuse?). The Brown/Blue wire need not have a fuse/holder.
. Because of the e.i:-
. the harness doesn't need: White wires to both coil -ve terminals, Black/White and Black/Yellow wires from coils to condensers, the Red wire from the condensers position;
. however, the harness does need: White and Red wires to the Boyer-Bransden "Transistor Box" position, a Red wire for one of the coil +ve terminals, Black/White and Black/Yellow wires from the Transistor Box position to the original points housing in the timing chest; in practice, I suspect BW will probably leave unterminated extra-long lengths of those wires more than enough to reach the positions you specify, for you(/your "bike builder") to cut to final length and terminate.
Mmmm ... bearing in mind we're talking about a fifty-year-old bike, how does he know the harness isn't only, say, thirty years old ...? wink
Will an original lucas harness handle a 200 watt alternator and boyer-bransden electronic ignition?
Alternator, depends. Electronic ignition, definitely not.
Assuming you're talking about an alternator that fits in the primary chaincase on (rotor) and around (stator) the end of the crank like the original, given there isn't such a thing as a "200 watt" version (except in marketing men's dreams), you're talking about either a Sparx 3-phase or a 'Wassell Lucas' single-phase? A Sparx can't be using the original rectifier, a 'Wassell Lucas' shouldn't be, neither should be using the original Zener but could be. frown
If the harness really is "original ... Lucas", the aforementioned Brown/Blue, Brown/White, Red to battery +ve and White/or White/Blue from the ignition switch will all be obviously-thicker (at least 28-strand) wire than the 14-strand to individual components. Original Lucas 28-strand was rated just above (15A) either alternator type's 5,000-rpm output; however, if the rectifier and Zener need replacing, and you'd have to make alterations for the e.i., making the changes to a decades-old harness isn't advisable.
Re: Wiring harness for 1969 t120r and tr6c [Re: Stuart] #716174
11/22/17 5:02 am
11/22/17 5:02 am
Massachusetts, U.S.A.
btour Offline
btour  Offline
Stuart you are simply astonishing
Why not, pls?
Another question: pls. Why are the pod's wires so thin?
Re: Wiring harness for 1969 t120r and tr6c [Re: btour] #716339
11/23/17 3:26 pm
11/23/17 3:26 pm
Stuart Offline
Stuart  Offline
Hi Bob,
Originally Posted by btour
Why not, pls?
"jchildr" mentioned his bike had a "200 watt" (aka 'high-output') alternator; if it's a Sparx, it must be a pattern of the original Lucas 3-phase. Otoh, an original '69 rectifier is single-phase - only two AC connections.
The ones I've seen, I thought the wire thicknesses were fine for the anticipated currents (AC and DC). However, I haven't seen a new one for a while so, if the wires are suddenly thinner, I hope it's because the maker's changed to using standard automotive 'thinwall'-insulated wire - 1 sq.mm. conductor, 'thinwall' insulated is rated for 16.5A, so more than adequate for anything a Lucas or pattern stator can produce. John Healy would know for sure.
confused Were you intending to add a question here?
blush Errm ... <koff> ... <shuffle> ... thank you.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #716357
11/23/17 5:05 pm
11/23/17 5:05 pm
Nashville TN
jchildr Offline OP
jchildr  Offline OP
Nashville TN
Hi Stuart. My builder didn't actually say '1969' when referring to the wiring harness. He just said 'original Lucas' and it was not a copy . My 200 watt alternator is EMGO and it fits just like the original. He wrote the part number down as 47974, but I can't find that part number anywhere. It has two wires (green and white, green and yellow). I still have the stock zener and rectifier. Originally, I didn't have electronic ignition; it had points. My current mechanic added the electronic ignition about a year later. I have been riding the bike with this set up for about 2000 miles with no problem yet, but that may change. Thanks.
Re: Wiring harness for 1969 t120r and tr6c [Re: jchildr] #716430
11/24/17 10:59 am
11/24/17 10:59 am
Stuart Offline
Stuart  Offline
To be clear, electrical Watts are a simple multiplication of Amps and Volts.
Without any need to 'puff', 'original Lucas' rated conservatively - the stator on which your EMGO is patterned is the Lucas RM23, which Lucas rated for 14.5 Amps and 180 Watts @ 5,000 rpm, so 12.4 Volts.
There's at least one way of increasing the actual Amps from a stator. But most pattern makers - Sparx as well as EMGO - prefer to bamboozle most buyers by just using a higher Voltage - e.g. 'original Lucas' said its Zeners were still within spec. if they allowed the DC to rise to 15.2V or 15.3V; then a standard RM23 is 'producing' over 220 Watts (but, because the system Volts are that high, all the consumers (ignition coils, bulbs, etc.) are using more Watts).
The only real indicator of a 'better' alternator is more Amps at a given rotor (engine) rpm.
My builder didn't actually say '1969' when referring to the wiring harness. He just said 'original lucas' and it was not a copy .
Whatever's fine as long as the wires I've mentioned already are obviously-thicker than the thinner wires to/from individual components.
It's in the format of an 'original Lucas' part number, but it isn't one.
Lucas rated single Zeners for 12~12.5 Amps and, on oem installations of the RM23 (e.g. police and electric-start Norton Commandos), Lucas supplied two Zeners, one connected to each wire between stator and rectifier. The rectifier was also 'half-wave' (meaning it only rectified half the alternator AC 'wave') and was insulated from 'ground'.
In practice, a running engine obviously needed the ignition coil(s) supplying (3-4 Amps) and riding with lights on will further reduce the current that a Zener has to turn into heat when the battery's fully-charged.
Nevertheless, not something I'd do deliberately; modern combined electronic reg./rec. are cheap and reliable, most (all?) replacement Zeners are neither. If I was redoing the electrics of a Britbike fitted with any variety of high-output alternator, I'd fit a reg./rec.
Re: Wiring harness for 1969 t120r and tr6c [Re: Stuart] #716463
11/24/17 4:55 pm
11/24/17 4:55 pm
btour Offline
btour  Offline
Stuart,
Would you lend me a hand on the hard to kick start thread? There is summary a few pages from the end.
