sbolton
sbolton
Flint, Michigan
55 registered members (Alan_nc), 241 guests, and 447 spiders.
10256 Registered Users
Lannis 63
608,657 mail-order LSR
Topics67,112
Posts651,269
Members10,256
BSA fuel tank #714865
11/13/17 12:46 pm
11/13/17 12:46 pm
Hermon N.Y.
mtrude Offline OP
mtrude  Offline OP
Hermon N.Y.
Hello, I have a 1968 BSA Spitfire, with a very nice but non original paintjob. The fiberglass tank leaks, it has been sealed at least once before. I would like to use a metal tank, Are Lightning and Thunderbolt tanks the same? I have a Thunderbolt tank (flat bottom) but It needs the rear of the tank raised to prevent fouling of the carb cables. I have seen tanks with recesses cut where the cables run, and tanks with a long curved recessed area , a 1968 tank would be nice,Thanks mtrude
Re: BSA fuel tank [Re: mtrude] #714927
11/13/17 11:21 pm
11/13/17 11:21 pm
Jon W. Whitley Offline
Or, you could use one of the new...reproduction Spitfire-Hornet tanks. They come in alloy and steel versions. Available from the UK and India. Several threads on this site regarding them. I have a steel one from a trusted source in India and it is well made and looks just like my original fiberglass tank. Pummy.8081 is the seller on eBay.
Re: BSA fuel tank [Re: mtrude] #714968
11/14/17 2:29 am
11/14/17 2:29 am
Mark Z Offline
Mark Z  Offline
Not sure what you mean by "flat bottomed", do you mean it has no channel for the frame? In that case, it would not be a Thunderbolt tank. Or do you mean with a channel, but otherwise flat on the bottom, with a seam around the bottom edge? That would make it a '66. I don't know about the Spitfire tank, but Lightning and Thunderbolt tanks (which are the same) are supported by two rubber "half-donuts", front and rear, and the rear one is bigger or smaller (I think smaller) than the front. There should be enough room for the cables between the frame and the tank channel, below the "donuts". Where the left cable crosses over, it will be under the frame. Anyway, the frames are all the same.
But if you're willing to spend some bucks, Jon's idea sounds like an excellent one!
Re: BSA fuel tank [Re: Mark Z] #715031
11/14/17 2:35 pm
11/14/17 2:35 pm
Hermon N.Y.
mtrude Offline OP
mtrude  Offline OP
Hermon N.Y.
Thank you for the replies, the Thunderbolt tank has no seam on the bottom and the cap matches the fiberglass tank cap so believe it to be the same year? What I mean by "flat bottom" is that I have seen photos of fuel tanks with a recess, or cavity built into bottom of the tank on each side near the petcocks where the carb cables would run. I thought that this may be for twin carburetors? The tank has a channel for the frame backbone . It could be my tank rubbers are incorrect. Probably as they are from the stock fiberglass tank.I really like the idea of the reproduction steel tank but I cannot find that seller on eBay? Is any contact information available? Thank You, Mike
Re: BSA fuel tank [Re: mtrude] #715057
11/14/17 4:17 pm
11/14/17 4:17 pm
This is pummy's shop on eBay.co.uk but there will be a .com version
http://stores.eBay.co.uk/royalcrusaders/
and his profile
https://www.eBay.co.uk/usr/pummy.8081?_trksid=p2053788.m1543.l2754
Re: BSA fuel tank [Re: mtrude] #715137
11/14/17 11:53 pm
11/14/17 11:53 pm
I believe they sell under more than one eBay store/handle. This tank and judging by the username is most likely pummy.8081. I purchased my tank from the same exact ad a few years ago but the seller was pummy.8081 at that time. Same price too. My tank is pretty nice in my opinion. None of us like to lose money but for the price, it is worth a try to me. Not expensive and if for some reason it didn't show up, a buyer could get their money back through PayPal, so no worries there. Definitely worth the effort IMO.
Spitfire-Hornet Gas Tank
Re: BSA fuel tank [Re: mtrude] #715155
11/15/17 2:40 am
11/15/17 2:40 am
Mark Z Offline
Mark Z  Offline
Originally Posted by mtrude
Thank you for the replies, the Thunderbolt tank has no seam on the bottom and the cap matches the fiberglass tank cap so believe it to be the same year? What I mean by "flat bottom" is that I have seen photos of fuel tanks with a recess, or cavity built into bottom of the tank on each side near the petcocks where the carb cables would run. I thought that this may be for twin carburetors? The tank has a channel for the frame backbone . It could be my tank rubbers are incorrect. Probably as they are from the stock fiberglass tank.I really like the idea of the reproduction steel tank but I cannot find that seller on Ebay? Is any contact information available? Thank You, Mike
Ok I get it now. No seam at the bottom edge makes it a '67-'70, '67 having the smaller Lucite badges, '68-'70 the larger die-cast badges. No, no relief for carb cables, but with the correct tank supports, there should be enough room for the cables to curve up and over across the bottom of the tank. I guess it does put a rather sharp bend in the cables. (I don't remember because I've run Mikunis ever since 1984, which may be even higher. I put fuel line around the cables to even out the curve and to keep the cables from scuffing the bottom of the fuel tank.) Someone in another post mentioned curved ferrules for the tops of the carbs, but that may have been for Mikunis. If they make those for AMAL carbs, that would be a good fix.
Re: BSA fuel tank [Re: mtrude] #715172
11/15/17 8:12 am
11/15/17 8:12 am
Only buy from pummy, if you look at the other guys feedback he is not checking the stuff he sells unlike pummy.
Re: BSA fuel tank [Re: mtrude] #715190
11/15/17 12:45 pm
11/15/17 12:45 pm
Hermon N.Y.
mtrude Offline OP
mtrude  Offline OP
Hermon N.Y.
Thanks for the replies, Im considering the bare steel tank with no cap, or am I better off with a painted tank with a cap, and repaint that? Just wondering as far as fitting the cap to the tank? Probably over thinking that problem. Thank You, again, Mike
