Joolstacho
Joolstacho
Australia
38 registered members (AML), 248 guests, and 414 spiders.
Crockermc, mpotter78, Frezz, MackenzieBM, Metisseguy
10483 Registered Users
NickL 100
franko 85
Triless 69
751,968 mail-order LSR
Topics68,888
Posts671,025
Members10,483
tribsa alloy 8 stud pre-unit head #714366
11/09/17 11:45 am
11/09/17 11:45 am
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
Hi
About to start rebuilding the Tribsa engine, but the head needs sorting, usual cracks and the threads in the exhaust ports are not really useable, apart from filling the ports with weld and recutting the threads in a milling machine,apart from this, so far I have thought about about using alluminium brazing rods, and simply filling around the stub, (but not sure the repair will survie the temperature when the engine is run.) or simply boring the port and using a push in stub.
Any suggestions as this bike is a tribsa not really bothered about originality but any repair must be durable
To fix the cracks was going to ream the holes and make a couple of steel hollow dowels to press in
Yosemite
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #714668
11/11/17 9:32 pm
11/11/17 9:32 pm
bon Offline
bon  Offline
If you go onto "gordy's goodworks" on youtube, you will see how he does it. If it were me i'd bore out the ports and weld in a fresh piece of aluminium and recut the threads.
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #714848
11/13/17 1:06 am
11/13/17 1:06 am
AR
bryan johnson Offline
AR
have you thought about just using this as an excuse to switch to a 9 stud unit construction top end?
Re: tribsa alloy 8 stud pre-unit head [Re: bryan johnson] #715005
11/14/17 10:25 am
11/14/17 10:25 am
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
thought about it , still thinking but would need 9 stud barrels,and would probably end up putting a big bore kit on it, high comp pistons.......
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #715210
11/15/17 2:51 pm
11/15/17 2:51 pm
AR
AR
It is a slippery slope...
Re: tribsa alloy 8 stud pre-unit head [Re: bryan johnson] #715227
11/15/17 5:21 pm
11/15/17 5:21 pm
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
maybe nows the time to take up a new hobby.......skiing
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #734588
05/09/18 7:04 am
05/09/18 7:04 am
Les P Offline
Les P  Offline
How far gone are the threads, you might get away with an oversize spigot ?
More bikes and projects than you can shake a stick at but they should be done in two shakes of a lamb's tail.
Re: tribsa alloy 8 stud pre-unit head [Re: Les P] #735276
05/14/18 6:58 pm
05/14/18 6:58 pm
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
The threads in the exhaust port are too bad to use an oversize stub, the cracks are the usual ones from the valve seats to the bolt holes, but the rebuild has had to be put on hold, due to having to spend time working on the new house
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #754370
10/28/18 6:23 pm
10/28/18 6:23 pm
H
harvey_mushman Offline
H
How is the Tribsa coming along? i was out on mine yesterday, pinking a bit with high comp pistons but otherwise good. I have 9 stud head on mine.
cheers
derek
Re: tribsa alloy 8 stud pre-unit head [Re: harvey_mushman] #756756
11/21/18 6:08 pm
11/21/18 6:08 pm
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
hi derek
just read your message, the tribsa is sitting in the front room of our house in Ireland, never had a chance to l;ook at it, bottom end , gearbox and primary drive are in the rolling chassis., reamed and bushed the cracks on the head, turned a couple of bushes for the exhaust ports, still tempted to look for a 750 top end with 9 stud head,
If we ever get moved then its second on the list of bike projects so work will commence as soon as I get a workshop built, I find it easier to work on a couple of bikes at the same time sothat whenIhit a problem I can think about whatt to do/ hunt for parts while making progress on something else..The new house is virtually finished structurally, really want to be in before christmas so will take the enfield over next week and start on kitchen, then its just ride the rest of bikes over one at a time with one in the transit with another lload of furnture, another 3 trips should see all the bikes over and most of the house in the borders emptied
