sbolton
sbolton
Flint, Michigan
57 registered members (Al Eckstadt), 239 guests, and 447 spiders.
10256 Registered Users
Lannis 63
608,657 mail-order LSR
Topics67,112
Posts651,269
Members10,256
Lightning Clubman Cases?? #714986
11/14/17 4:33 am
11/14/17 4:33 am
Sacramento, CA
Denis J Offline OP
Denis J  Offline OP
Sacramento, CA
Hi guys!
Digging in a collection of stuff I've purchased i found an incomplete A65 engine.
Its stamped A65 LC 1119 3
I'm under the impression this is a Lightning Clubman case.
Any way I can identify this to be sure?
Thanks!
The formula for how many motorcycles to own is:
n+1=y
n = the number of motorcycles you currently own.
Motorcycle Mechanic at The Vintage Monkey in Sacramento, CA British and Old Motorcycle Specialists
Re: Lightning Clubman Cases?? [Re: Denis J] #715007
11/14/17 10:51 am
11/14/17 10:51 am
Rich B Online happy
Rich B  Online Happy
It is more likely a set of early 69 Lightning cases. Pics would help.
Stud type alternator mount or cast alternator mount?
Trans oil fill in RH main case?
Those are 2 big things to identify vintage.
Re: Lightning Clubman Cases?? [Re: Denis J] #715059
11/14/17 4:23 pm
11/14/17 4:23 pm
SE Ohio
No Name Man Offline
No Name Man  Offline
SE Ohio
Also raised lug on case where the vin is stamped. Even early 69s had that.
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
Re: Lightning Clubman Cases?? [Re: Denis J] #715064
11/14/17 5:22 pm
11/14/17 5:22 pm
gavin eisler Offline
The pic shows the cast alternator mount, so not Lightning Clubman too late, I make those numbers, 66 or 67 Lightning , there is no raised boss like the later numbers, 67 would have a finned rocker cover and that would fit the later type alternator mount, the C after A65 L may mean a close ratio gearset is installed.
Has the primary case got the strobe access cover?
Its hard to tell from the pic but the barrels look like they have heavy flanges and 3/8ths stud.
What way does the clutch cable enter, horizontal or vertical? Got any other pics?
Re: Lightning Clubman Cases?? [Re: Denis J] #715214
11/15/17 3:10 pm
11/15/17 3:10 pm
SE Ohio
No Name Man Offline
No Name Man  Offline
SE Ohio
Yep, more pictures would help. Another possibility is the original case had a large hole blown out of it and was replaced with an unstamped dealer bottom end who then stamped the original vin on it.
69 A65T
71 B50T
85 K100RS
54/59 A10SR
69 B44VS
71 A65FS
95 Trident
Re: Lightning Clubman Cases?? [Re: Denis J] #715303
11/16/17 1:32 am
11/16/17 1:32 am
Santa Barbara, California
KC in S.B. Offline
KC in S.B.  Offline
Oil Pressure switch?
Oops,.. add 1 Sporty
