Tiger
Tiger
Melbourne Australia
17 registered members (Chris Johnson), 171 guests, and 401 spiders.
Mal Wood, FireGuyKC, spuggy, Vinny Cotroneo, KeithM
10286 Registered Users
Stuart 95
Lannis 65
Mori55 58
635,765 mail-order LSR
Topics67,362
Posts654,030
Members10,286
Sand blasting #714419
11/09/17 10:19 pm
11/09/17 10:19 pm
Ireland
Y
Yeksae Offline OP
Yeksae  Offline OP
Y
Ireland
Hi
Is sandblasting the best way of stripping paint, rust etc or is there a better way? Less severe maybe with same result
Re: Sand blasting [Re: Yeksae] #714446
11/10/17 2:36 am
11/10/17 2:36 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
Depends on who is doing the sandblasting - and what you are getting blasted.
And even what sand they are using !
Silica sand is a no no (for the operator), garnet sand (the red stuff) is good.
There are also a variety of other sand types.
Large stuff is not good, high pressure is not good.
I saw a (car) bonnet blasted with high pressure, it expanded the bonnet at least 2 inches sideways - not good.
The place that gets my business has a rotary type compressor - no air tank - the sand comes out in large bucketfulls almost, and the sheer volume does a great job of removing all the old paint rust gunge etc. The steel surface (and it must be steel, never alloy) comes out a looking almost like its been lightly polished. You can't see any indents with the naked eye , but paint gets a great key onto it. It has to be thoroughly dusted off, several times, and I usually wipe it over with dilute phosphoric acid, to keep future rust at bay, before any painting.
You can of course get stuff bead blasted, and this is possibly gentler.
But it tends to be slower, and possibly much more expensive - because of the extra time
Probably in a smallish cabinet ?
Someone recently quoted someplace they were quoted 3 hours to do a Commando frame.
That is rather slow (bead blasting ?), I've had a frame , engine plates mudguards and a few bits and bobs and dodads done in ~20 mins (?) with said rotary compressor, cost about $50. Done in a steel container type blastroom.
Its also worth commenting that Nortons at least had their own sandblasting facilities, so we know for sure that Nortons were sandblasted in a past life (pre commando, not sure what happened with those).
Most shops that do powder coating will have sand blasting facilities of some sort - but will mostly then want to powder coat it also. !
Over to you - find a good operator. ?
Re: Sand blasting [Re: Yeksae] #714450
11/10/17 3:26 am
11/10/17 3:26 am
Mark Z Offline
Mark Z  Offline
In answer to the question "Is there any other way?": Paint CAN be removed with a chemical stripper; I've done this a couple of times. I like the water-soluble kind, as you can flush it with a hose. Even the original dipped-and-baked enamel on my '67 A65 came off this way, although it took three or four applications.
A painter may want to blast anyway, to give the metal a "tooth", but it's a lot less work if the paint has been removed.
Note that blasting is not required for powder coating, if you decide to go that way. In fact, powder coating can go on over old paint, as long as the old paint is firmly bonded to the frame. The last frame I did was powder coated, and all I did was sand the frame by hand to remove any rust or loose paint, and take the gloss off any remaining paint. The powder coater then dipped it in solvent to remove any dirt or grease, which is SOP.
Re: Sand blasting [Re: Yeksae] #714461
11/10/17 6:55 am
11/10/17 6:55 am
Oztralia
Rohan Offline
Rohan  Offline
Oztralia
I'm impressed you got paint stripper to remove baked enamel, I've not had much success with that.
Paint stripper (methylene chloride type) is about the only way to remove old powdercoat,
apart from melting/burning it off with a propane torch.
I've had good success with removing some types of paint off tinware parts using hot caustic.
Boil it up, and slosh it on. (below)
Took the paint neatly off a pair of Commando steel sidecovers, the old paint just drops off like a skin.
Beware, it will do this to human flesh too, so take all necessary precautions.
Also works well cleaning old paint and gunge off iron cylinders and iron cylinder heads.
It is water based of course, so watch it isn't left for long, could promote rusting.
Beware also, it also eats alloy, so keep well away.
I have taken a fairly uncommon and scrappy old petrol tank, and sanded it back (using sandpaper) by hand.
No unexpected damage or surprises doing it this way - although it can take a while - some of those old paint types were tough. And old tanks can sometimes show many old layers and colors = many previous lives.... ?
Re: Sand blasting [Re: Yeksae] #714484
11/10/17 1:06 pm
11/10/17 1:06 pm
Irish Swede Offline
Irish Swede  Offline
Sand blasting is the way to go, as Rohan describes it, but only on steel parts. That's the way I do it, but if you are cleaning sheet metal, it should be blasted at LOW PRESSURE, and with fine grit blast media.
As for paint stripper: If there are seams , rolled edges, or two parts welded together or spot-welded, the stripper will
creep into the seams, only to re-emerge after you have applied new paint, to ruin the paint job in the area of the seam.
This is my reason for using low-pressure blasting on sheet metal parts,
Re: Sand blasting [Re: Yeksae] #714489
11/10/17 1:31 pm
11/10/17 1:31 pm
UK Berks
AngloBike Offline
AngloBike  Offline
UK Berks
Soda blasting leaves no residue
Re: Sand blasting [Re: Yeksae] #714499
11/10/17 3:10 pm
11/10/17 3:10 pm
Tridentman Offline
Tridentman  Offline
+1 for soda blasting.
Then remove obstinate bits with a scraper. I do these processes myself--therefore no external contractors to liaise with/delay the work/f**k up the work etc.
Also gets you close to the parts--you see things that you otherwise wouldn't.
Gets you to bond with the bike.
Sounds crazy?---that is just what my wife says!-----but it works for me.
Just my two centsworth of course.
Re: Sand blasting [Re: Yeksae] #714521
11/10/17 5:33 pm
11/10/17 5:33 pm
Farnham, Surrey, UK
gunner Online content
gunner  Online Content
Farnham, Surrey, UK
I guess the main question is what type of part you need stripping and what the subsequent finish is intended.
For frame and other body parts which you are going to paint yourself then an easy less severe but slow method is to use paint stripper as suggested. This usually requires multiple applications followed in between with pressure washing and/or use of a wire wheel on a drill to remove stubborn bits, make sure you use skin/eye protection. Following removal of all paint you might want to use a rust remover or suitable anti rust primer.
For engine parts such as crankcases, I would avoid sandblasting & bead blasting, A better alternative is Vapor blasting which uses a slurry of hot water, de-greasants, corrosion inhibitors and blast media. This process closes the pores of aluminum and leaves a semi polished wipe clean finish.
Additionally you can simply sand parts with wet & dry paper, starting with coarse and ending up with fine. Clearly this is very labor intensive but you can achieve a mirror finish on most metal surfaces depending on your requirements.
Re: Sand blasting [Re: Yeksae] #714939
11/13/17 11:49 pm
11/13/17 11:49 pm
South cone
reverb Offline
reverb  Offline
South cone
...for the frame, I sanded most parts by hand, about 40 hours; I had no rust (a 67 frame) at all; the swing arm was chromed so I went to a guy with a sandblaster, was very difficult to remove it.
Engine, the cases were mirror polished, the cyl is new and the head was bead blasted (I do not know of any vapor blasting machine in this country)
Re: Sand blasting [Re: Yeksae] #714988
11/14/17 5:19 am
11/14/17 5:19 am
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
For frame and related steel bits use a wire cup in an angle grinder. They are powerful enough to take paint off quickly but won't do any damage. Wear some eye protection!
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2004 XL 1200R Sportster
Re: Sand blasting [Re: Yeksae] #715263
11/15/17 8:35 pm
11/15/17 8:35 pm
Ireland
Y
Yeksae Offline OP
Yeksae  Offline OP
Y
Ireland
Thanks all, need frame, tanks, wheels done. Not much paint left but lots of rust to be removed so sandblasting still sounds like the best solution just need them to go easy on tanks etc to not cause any damage
