Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
Plug spark at startup, testing #713280
10/31/17 12:29 am
10/31/17 12:29 am
Massachusetts, U.S.A.
btour Offline OP
btour  Offline OP
T120R 71
This goes along with the hard to kick start thread.
So, the thought is that perhaps the coils are not up to snuff. I know the plug needs more juice to spark under compression. The plugs do spark when out. Bike runs fine after startup. But perhaps there is not enough when starting. If the inline led gizmo is lighting does that confirm that the plug is firing?
As I remember, the distance the spark should jump should be 3/8 inch. Is that correct? I realize that this does not confirm that plug will spark in the cylinder. It is just an indication.
I can perform both tests.
Re: Plug spark at startup, testing [Re: btour] #713352
10/31/17 2:23 pm
10/31/17 2:23 pm
JubeePrince Offline
JubeePrince  Offline
Not sure about 3/8", but the proper gap on a plug to run is 1/40"
Re: Plug spark at startup, testing [Re: btour] #713354
10/31/17 2:44 pm
10/31/17 2:44 pm
btour Offline OP
btour  Offline OP
Got em gapped at .025, Steve. They came out of the box set a big larger. They used to come out dead on. No change in behavior from old plugs, so I guess that was not the problem. I mean faulty plugs.
Now I am trying to determine if they are sparking in the cylinder with kick start. I did search, and confirmed that "in the air", using adjustable gap tool, the spark should travel 3/8 inch.
Thank you.
Re: Plug spark at startup, testing [Re: btour] #714354
11/09/17 8:19 am
11/09/17 8:19 am
Pleasant Hill, California USA
TR7RVMan Offline
TR7RVMan  Offline
Hi Bob, I don't know about the actual air gap the spark can jump.
However, On bikes running points, I've seen many Triumph spark plugs out of bike during kicking. The gap is indeed supposed to be .025". Visually the spark looks weak. Not a strong crack like on modern cars or even old cars. Yet the bikes start & run perfectly with this seemingly weak spark. If bike starts & idles, I doubt spark is the root problem.
I've never tested spark with Boyer or the like.
Re: Plug spark at startup, testing [Re: btour] #714357
11/09/17 8:40 am
11/09/17 8:40 am
Christchurch NZ
R Moulding Online content
R Moulding  Online Content
Christchurch NZ
Are the coils not new ones?
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: Plug spark at startup, testing [Re: R Moulding] #714375
11/09/17 1:40 pm
11/09/17 1:40 pm
btour Offline OP
btour  Offline OP
Rod
Coils are new 6 volt.
Re: Plug spark at startup, testing [Re: TR7RVMan] #714504
11/10/17 3:48 pm
11/10/17 3:48 pm
JubeePrince Offline
JubeePrince  Offline
Hi Don -
Just in case you ever need to: http://vintagebikemagazine.com/technical-articles/Boyer-trouble-shooting/. wink
Bob - if you can get a blue/white spark out of the plug, that should be (notice the qualifier) sufficient to fire. Yellow spark, not so much. Easy enough to check in a dimly lit area.
Re: Plug spark at startup, testing [Re: btour] #714511
11/10/17 4:31 pm
11/10/17 4:31 pm
btour Offline OP
btour  Offline OP
Steve, I get the spark when they are out of bike, but as you know it takes more when they are in compressed area.
