Prospect
Prospect
London UK
42 registered members (Adam M.), 265 guests, and 333 spiders.
Duckster, IDG1, pemdoc65, creativecroc, gregneal
10171 Registered Users
Lannis 96
Stuart 84
reverb 81
NickL 69
koan58 56
550,114 mail-order LSR
Topics66,555
Posts645,181
Members10,171
BSA A10 gearbox high rev problems #714358
11/09/17 9:58 am
11/09/17 9:58 am
northern germany
gunnix Offline OP
gunnix  Offline OP
northern germany
Hello everybody
Since I am a newbe in asking questions in a forum, I hope I am doing it right.
If not, please tell me.
I am riding a side car racer based on a BSA M20/A10 with an engine one cylinder, dohc 600cc and approx 65hp at 8500 rpm.
In my A10 std gearbox above 7000 rpm sometimes gears slip out and I am not able to get in any gear.
Sometimes the gear slips out and jumps in again (awefull noise!!!).
Is there anything I can do?
I changed the layshat to goldie type with needle rollers, and the main shaft wit one needle roller and one bush on the drive side side - no change.
The gears itself dont look worn.
Greetings from
Gunnar
in progress: BSA/Jawa 620cc supercharged sidecar racer
BSA/Jawa 600cc sidecar racer
BSA super Rocket
BSA B33 sidecar
Ariel VH
Triumph 6T custom
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714381
11/09/17 3:06 pm
11/09/17 3:06 pm
Edgewater, Md
Blown Income Offline
Edgewater, Md
Gunnar,
I think the best thing you could do would to have the gears undercut. This would keep the gears pulling together while engaged.
1955 BSA Bantam D1 Plunger
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1972 BSA Lightning LSR Bike
1974 Triumph T150V
Re: BSA A10 gearbox high rev problems [Re: Blown Income] #714480
11/10/17 12:44 pm
11/10/17 12:44 pm
northern germany
gunnix Offline OP
gunnix  Offline OP
northern germany
Thank you very much for the information.
Is it normal to happen if the gears are not undercut?
BSA super Rocket
BSA B33 sidecar
Ariel VH
Triumph 6T custom
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714492
11/10/17 2:24 pm
11/10/17 2:24 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
I don't want to rain on your parade but undercutting an A10 gearbox is almost impossible.
Only the layshaft 2nd and 3rd gears have "dogs" but they are rounded section and locate into rounded blind holes
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714493
11/10/17 2:27 pm
11/10/17 2:27 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
For racing I would either fit a Nova 5 speed cluster http://www.novaracing.co.uk/ManufacturerBSA.html
or a TTI gearbox http://www.ttindustries.com/bsa_gearbox.html
1962/67 Greeves 350
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714591
11/11/17 2:45 am
11/11/17 2:45 am
Riverside, CA.
noisy norton Offline
Riverside, CA.
The real solution is to scrap the BSA box and find an AMC box. Impossible to break.
Re: BSA A10 gearbox high rev problems [Re: NickL] #714604
11/11/17 10:17 am
11/11/17 10:17 am
OZ
Triless Offline
Triless  Offline
OZ
Yep, reminds me of something I once read about the poor old Matchless gearbox........ " designed for a thirty horsepower world and ending up in a sixty horsepower one !"
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714662
11/11/17 9:06 pm
11/11/17 9:06 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Years ago I used an AMC gearbox on a sprint bike, supercharged (28psi) 500cc Weslake speedway engine and a 6,5" wide rear slick. First drop of the clutch would bend the gearbox mainshaft making the clutch run out by about 2mm. subsequent runs would sometimes pull it straight, it never went worse
1962/67 Greeves 350
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714724
11/12/17 11:17 am
11/12/17 11:17 am
Edgewater, Md
Edgewater, Md
I've done 118 mph in Ohio and just over 120 mph at Bonneville with my A10. I have the scrambles ratio box fitted and have not had a problem at high speed with it jumping out of gear. The Nova 5 speed box's are great but do cost a lot. You may want to check the current setup on your gearbox to make sure you do not have excessive play on the mainshaft, the bearing may be worn out causing too much "end float" allowing top gear to not fully engage.
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1974 Triumph T150V
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714826
11/12/17 9:41 pm
11/12/17 9:41 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Racing sidecars are brutal on gearboxes, when drifting around corners the tyre is slipping and gripping which puts shock loads into the gearbox
1962/67 Greeves 350
Re: BSA A10 gearbox high rev problems [Re: gunnix] #714846
11/13/17 12:29 am
11/13/17 12:29 am
Edgewater, Md
Edgewater, Md
I could see that, straight line racing we dont really have the side loading. I guess the best plan of attack would be to upgrade to the Nova 5 speed box.
1961 BSA C15S
1966 BSA spitfire
1969 Triumph T100C
1970 Triumph TR6R
1974 Triumph T150V
Re: BSA A10 gearbox high rev problems [Re: gunnix] #723475
01/27/18 11:13 pm
01/27/18 11:13 pm
F
flowboy Offline
flowboy  Offline
F
Wow Gunnix that sounds like an interesting motor! 600cc DOHC M20/A10. That is a strange combination! I hope it has a wild nickname..
I've raced Goldstars - with anything from 30 to about 45 hp & never had jumping out of gear problems with a BSA box unless the gears were worn. It does suggest your gears are more worn than you think. On the other hand you're putting a lot more power through it!
The Nova 5 speed cluster is good (I think about £2k last time I looked & I think they also make a 6 speed) The TTI equivalent is over £3K for a 6 speed once you've imported it to the UK but I've only raced a Norton TTI box - very nice but not cheap...
I would suggest the Triumph 5 speed but suspect that may be more fragile than the BSA.
Regarding wear on the mainshaft did you fit a crowded needle roller? The caged ones which are often supplied these days are not up to the task, particularly what you are doing to it!. There is a thread on this in the goldstar forum. The mainshafts are available new from Autocycle but you probably know this.
Seems like you might need a heavy duty box from some other machine...
na
Moderated by  Allan Gill
Page Time: 0.079s Queries: 15 (0.009s) Memory: 1.0750 MB (Peak: 1.2892 MB) Zlib disabled. Server Time: 2018-04-21 15:28:00 UTC
