John Friday
John Friday
Hilton Head, SC
220 registered members (21inGoldie), 2,346 guests, and 559 spiders.
10071 Registered Users
Lannis 83
koan58 83
NickL 76
502,324 mail-order LSR
Topics66,008
Posts638,850
Members10,071
B40 Indicators. #714415
11/09/17 9:31 pm
11/09/17 9:31 pm
Cheshire
Graham Keen Offline OP
Cheshire
I have just bought a 1966 B40, having previously owned one back in the early 1970s.
It doesn't have indicators as do the later models and I was thinking of fitting a set.
Can anyone post or point me to an image or two that shows how they were fitted to the later models, that might give me some ideas. Alternatively, if anyone has fitted them to an early model already, how you went about mounting them and where, would be appreciated. Trying not to drill holes in the original bike bits frown.
Graham.
Graham Keen
Re: B40 Indicators. [Re: Graham Keen] #714416
11/09/17 9:38 pm
11/09/17 9:38 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
Oberon make indicators which fit in the ends of the handlebars, they are LED so shouldn't tax the electrical system much
http://www.oberon-performance.co.uk/acatalog/Oberon_Bar_End_Motorcycle_LED_Indicators.html
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: B40 Indicators. [Re: Graham Keen] #714547
11/10/17 9:24 pm
11/10/17 9:24 pm
Stuart Online content
Stuart  Online Content
Hi Graham,
Firstly, welcome to the Forum. smile
Afaict, the last B40's were built in 1970, but BSA didn't fit indicators as standard 'til '71. If you enter "1971 bsa b50" into your preferred internet search engine, it should return images showing standard indicators fitment. Not much different from the contemporary twins.
Hth..
Re: B40 Indicators. [Re: Andy Higham] #714553
11/10/17 9:41 pm
11/10/17 9:41 pm
Cheshire
Cheshire
Thanks for the help.
Andy, I like the LED in the ends of the bars but only downside is I would have to remove the mirrors that already in the end of the bars. I will apply myself smile.
Stuart, I will also look at the B50 images to see what ideas I can get.
Graham.
Graham Keen
Re: B40 Indicators. [Re: Graham Keen] #714596
11/11/17 5:02 am
11/11/17 5:02 am
BSA_WM20 Online content
BSA_WM20  Online Content
First of all you really will need to upgrade the electrics as there is a better than average chance it is 6V.
Next there are laws regarding separation of blinkers front & back, min heights, maximum heights etc etc etc so check with your local authority before you do anything.
Using those short "harley / bobber " style ones that fit directly over or replace the headlamp mounting bolts is in fact illegal in a lot of places.
There was a reason why BSA fitted those Lucas blinkers on those silly long stems and it was not to make them look sexy.
Re: B40 Indicators. [Re: Graham Keen] #714634
11/11/17 4:39 pm
11/11/17 4:39 pm
Irish Swede Online content
Irish Swede  Online Content
There may be laws regulating the distance between right and left turn indicators, so handlebar ends would work,
but how about distance between mirrors?
Back in the 1960s, BMW bikes mounted the mirrors on stalks screwed into the headlight mounts,
and it looked and worked well.
Just something to consider.
Re: B40 Indicators. [Re: Graham Keen] #714648
11/11/17 5:53 pm
11/11/17 5:53 pm
Bolton Lancs UK
Bolton Lancs UK
There are some nice neat LED indicators available.
I would personally steer clear of the Lucas units. The bodies are chromed plastic and not very securely fixed to the stems, hence the lenses often pointing to the road
1962/67 Greeves 350
Re: B40 Indicators. [Re: Graham Keen] #714652
11/11/17 6:26 pm
11/11/17 6:26 pm
Farnham, Surrey, UK
gunner Online content
gunner  Online Content
Farnham, Surrey, UK
I'm sure this is correct, however from May 2018 in the UK, vehicles older than 40 years will become exempt from the annual MOT, which presumably means any rules relating to fitting indicators wont apply but I'm happy to be corrected if this is wrong.
As I'm currently restoring a 1972 Norton Commando, I have been looking at various potential replacement indicators. I probably won't use the original Lucas version and the led types seem to be viable, so I will be following this thread with interest.
Re: B40 Indicators. [Re: Graham Keen] #714688
11/11/17 11:38 pm
11/11/17 11:38 pm
You won't need an MOT but you still need to comply with legislation so a minimum distance still applies.
Re: B40 Indicators. [Re: Andy Higham] #714744
11/12/17 1:13 pm
11/12/17 1:13 pm
Hi Graham,
From personal first-hand experience, in GB, the only conceivable "local authority" that could have any interest whatsoever in indicators mounted on your bike is the police. The possibility that you'll meet even a 21st century traffic cop who even knows 1971 Construction & Use regs. exist, never mind how they might be applied to a '66 bike ... well, if you do, don't bother buying any lottery tickets for a while ... laughing
Originally Posted by Andy Higham
lucas units. The bodies are chromed plastic and not very securely fixed to the stems, hence the lenses often pointing to the road
Nothing to do with most bodies, usually that's the stems coming loose at the mounting; the only bodies that can rotate on the stems are very early ones - that had a 7/16"UNC thread (99.9% now wrecked) and poor-quality pattern ones - that have a round mounting hole in the body. Certainly the vast majority of 'original Lucas' bodies have an oval mounting hole, that fits over a stem with two flats on the 3/8"UNF thread; 'course, these can be rounded by some dipstick forcing the body around the stem ... facepalm
That said, while I use Lucas indicators on my bikes fitted with them originally, when I wanted something not quite so visually obtrusive for my T100, I ended up working my way through the M&P site, eventually selecting https://www.mandp.co.uk/black-alloy-oblong-indicator.html for the front and https://www.mandp.co.uk/mini-stalk-indicators-chromed-alloy-amber.html for the rear; at the time, the dark lenses offered with this one was also an option on the ones I bought. smile
Page Time: 1.613s Queries: 15 (0.100s) Memory: 1.0659 MB (Peak: 1.2558 MB) Zlib disabled. Server Time: 2018-02-19 21:28:57 UTC
