Les P
Les P
22 registered members (Boomer), 154 guests, and 58 spiders.
locobeta, Walt, DennisMartin, Dwight V, urbanghost
10387 Registered Users
NickL 98
Triless 88
reverb 82
Rohan 80
Mori55 79
Stuart 77
DavidP 72
btour 66
690,412 mail-order LSR
Topics68,045
Posts662,075
Members10,387
tribsa alloy 8 stud pre-unit head #714366
11/09/17 11:45 am
11/09/17 11:45 am
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
Hi
About to start rebuilding the Tribsa engine, but the head needs sorting, usual cracks and the threads in the exhaust ports are not really useable, apart from filling the ports with weld and recutting the threads in a milling machine,apart from this, so far I have thought about about using alluminium brazing rods, and simply filling around the stub, (but not sure the repair will survie the temperature when the engine is run.) or simply boring the port and using a push in stub.
Any suggestions as this bike is a tribsa not really bothered about originality but any repair must be durable
To fix the cracks was going to ream the holes and make a couple of steel hollow dowels to press in
Yosemite
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #714668
11/11/17 9:32 pm
11/11/17 9:32 pm
bon Offline
bon  Offline
If you go onto "gordy's goodworks" on youtube, you will see how he does it. If it were me i'd bore out the ports and weld in a fresh piece of aluminium and recut the threads.
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #714848
11/13/17 1:06 am
11/13/17 1:06 am
AR
bryan johnson Offline
AR
have you thought about just using this as an excuse to switch to a 9 stud unit construction top end?
Re: tribsa alloy 8 stud pre-unit head [Re: bryan johnson] #715005
11/14/17 10:25 am
11/14/17 10:25 am
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
thought about it , still thinking but would need 9 stud barrels,and would probably end up putting a big bore kit on it, high comp pistons.......
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #715210
11/15/17 2:51 pm
11/15/17 2:51 pm
AR
AR
It is a slippery slope...
Re: tribsa alloy 8 stud pre-unit head [Re: bryan johnson] #715227
11/15/17 5:21 pm
11/15/17 5:21 pm
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
maybe nows the time to take up a new hobby.......skiing
Re: tribsa alloy 8 stud pre-unit head [Re: yosemite] #734588
05/09/18 7:04 am
05/09/18 7:04 am
Les P Offline
Les P  Offline
How far gone are the threads, you might get away with an oversize spigot ?
More bikes and projects than you can shake a stick at but they should be done in two shakes of a lamb's tail.
Re: tribsa alloy 8 stud pre-unit head [Re: Les P] #735276
05/14/18 6:58 pm
05/14/18 6:58 pm
kelso scotland
Y
yosemite Offline OP
yosemite  Offline OP
Y
kelso scotland
The threads in the exhaust port are too bad to use an oversize stub, the cracks are the usual ones from the valve seats to the bolt holes, but the rebuild has had to be put on hold, due to having to spend time working on the new house
