Dave Beef
Dave Beef
Great Britain
22 registered members (Alan_nc), 189 guests, and 61 spiders.
10389 Registered Users
NickL 95
Mori55 88
Triless 86
Rohan 84
reverb 79
btour 69
DavidP 68
691,951 mail-order LSR
Topics68,056
Posts662,208
Members10,389
6t pistons #714322
11/08/17 11:13 pm
11/08/17 11:13 pm
Ireland
Y
Yeksae Offline OP
Yeksae  Offline OP
Y
Ireland
I’m looking to get a pair of +40 6t pistons for 1959 thunderbird. What brand and where have he found good for pistons?
John.
Re: 6t pistons [Re: Yeksae] #714327
11/08/17 11:43 pm
11/08/17 11:43 pm
Les P Offline
Les P  Offline
When I was looking for pre unit pistons (1957 TR6) there seemed to be one logical place to shop.
I think they were JCC brand with good USA manufactured piston rings and weight match checked before dispatch, they are a ways from Ireland (as is Australia) but dealing with Dan was well worth the postal distance.
https://fagengine.com/
More bikes and projects than you can shake a stick at but they should be done in two shakes of a lamb's tail.
Re: 6t pistons [Re: Yeksae] #714330
11/09/17 12:09 am
11/09/17 12:09 am
Isle of Wight, UK
koan58 Offline
koan58  Offline
Isle of Wight, UK
Might take a bit of tracking down. TMS, then TriSupply maybe? Run of the mill say 9:1 easy to find, if you want 7 or so:1, not so easy. I guess that's an alloy head?
TT or Hawaian will hopefully chip in.
Re: 6t pistons [Re: Yeksae] #714331
11/09/17 12:26 am
11/09/17 12:26 am
Les P Offline
Les P  Offline
Finding pistons is not hard including plenty on UK eBay and various websites (30 second web search), finding someone who will supply a good set with decent rings can be the catch.
Even Gandini do low compression .
Re: 6t pistons [Re: Yeksae] #714332
11/09/17 12:39 am
11/09/17 12:39 am
Ireland
Y
Yeksae Offline OP
Yeksae  Offline OP
Y
Ireland
Iron head and low compression 7:1s is what I’m looking for, hard to tell what’s good or not on eBay 🙁
Re: 6t pistons [Re: Yeksae] #714334
11/09/17 1:12 am
11/09/17 1:12 am
I used ordinary JCC unit construction pistons for my 6T with iron head. The CR is pretty low. Not exactly sure how low, but it's a softly tuned motor. When I want standard CR or a little higher, I go with LF Harris pistons, which I believe are JCC's as well, but with the correct domes we need for our pre units.
It's always a good idea to clay the head. You never know who's been messing around with these motors...
Re: 6t pistons [Re: Yeksae] #714335
11/09/17 1:25 am
11/09/17 1:25 am
Les P Offline
Les P  Offline
Here is a set from 'montysclassicmotorcycles who I have purchased off before (Lucas lenses)
Iron head pistons + 0.040"
What is the deal with the iron head, is it the squish band change like the 500 cc engines ?
Re: 6t pistons [Re: Yeksae] #714336
11/09/17 1:49 am
11/09/17 1:49 am
The combustion chambers in the iron head are much deeper than the alloy heads, with the unit heads even shallower, so the piston crowns look decidedly different.
And those are the pistons I have used. They work just fine.
Re: 6t pistons [Re: Yeksae] #714352
11/09/17 7:30 am
11/09/17 7:30 am
Pleasant Hill, California USA
TR7RVMan Offline
TR7RVMan  Offline
Hi John, LF Harris makes them. Check their web site for sizes. They seem to be the only ones making them. They don't sell retail, so you'll have to have a retailer order them for you. Seem to be good quality & the rings they come with tend to work quite well.
Be sure to use real break in oil with them.
I actually had a set in my own hands recently at Raber's San Jose, CA USA.
They are often called "unleaded" pistons.
I don't know for sure what the true compression ratio will be with the iron head. It's said to be 7.1:1
Looking at iron head the combustion chamber shape around edges is deeper so I expect them to be 7.1.
I know for sure the alloy head piston is the same blank exactly but is machined around the edge so it doesn't hit the squish band area of alloy head. I'm currently installing these in '69 Bonnie.
I have friend that used these pistons on T140 7.4:1 to very good results. They are the same construction so to speak, but configured for 750. The casting is the same material & interior webbing etc. is the same as the iron head. Bore clearance was set to .0045" to good results. The bonnie 650 bore clearance is .0045 also. That has proven good on several motors.
Again break in oil can be very important. Use Torco TBO 40w. run for 200 miles then go to regular oil. In several cases this combination has given perfect results.
Here's an eBay link to iron head 7.1.
https://www.eBay.com/itm/TRIUMPH-PISTONS-IRON-HEAD-71MM-040-1MM-6T-TIGER-T110-7-1-comp-ratio/132108285863?rt=nc&_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D48754%26meid%3D234676220e4048269db881738d6dbd35%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D132165859448&_trksid=p2047675.c100005.m1851
Re: 6t pistons [Re: Yeksae] #714356
11/09/17 8:28 am
11/09/17 8:28 am
Skudeneshavn Norway
Stein Roger Offline
Stein Roger  Offline
Skudeneshavn Norway
Re: 6t pistons [Re: Yeksae] #714606
11/11/17 11:46 am
11/11/17 11:46 am
Ireland
Y
Yeksae Offline OP
Yeksae  Offline OP
Y
Ireland
Thanks everyone. Found a manual that said could only go +20 could that be right?
Re: 6t pistons [Re: Yeksae] #714610
11/11/17 12:50 pm
11/11/17 12:50 pm
triton thrasher Offline
No, I think you're reading it wrong. 20 thou may be (going by memory) maximum oversize for the 500 cc alloy barrel.
The iron cast iron pre-unit 650 barrel has a 40 thou recommended maximum oversize. +60 thou is usually ok though. I ride one on +60 and it works fine, althouh the studs look a bit close to the bore.
