iansoady
iansoady
Birmingham UK
33 registered members (998John), 215 guests, and 455 spiders.
10257 Registered Users
Stuart 80
Lannis 57
610,000 mail-order LSR
Topics67,134
Posts651,487
Members10,257
Ammeter Lighting #714041
11/06/17 3:32 pm
11/06/17 3:32 pm
Oceanside California
mrcarb Offline OP
mrcarb  Offline OP
Does anyone know if there is a replaceable light bulb in the ammeter of a 69 Lightning and if so its part number?
Re: Ammeter Lighting [Re: mrcarb] #714045
11/06/17 3:44 pm
11/06/17 3:44 pm
kommando Offline
kommando  Offline
A Gentleman does not concern himself with amps in the dark, purely a daytime occupation wink .
No bulb, you had to wait until you went under a streetlamp to see how badly your amps were disappearing.
Re: Ammeter Lighting [Re: mrcarb] #714047
11/06/17 3:50 pm
11/06/17 3:50 pm
NY
David Kavanagh Offline
NY
I'd suggest removing a tiny spot on the headlight reflector right under the ammeter. :-)
'81 Yamaha XJ550 Seca
Re: Ammeter Lighting [Re: mrcarb] #714079
11/06/17 7:56 pm
11/06/17 7:56 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Why bother illuminating the most useless thing on the bike?
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Ammeter Lighting [Re: mrcarb] #714122
11/07/17 12:23 am
11/07/17 12:23 am
gavin eisler Offline
"You can drill a small hole in the ammeter and glue a 3mm white led in, put a 1k5 0.5w resistor in series with it and you will be able
to see at night as well as in the day, how totally useless those ammeters are." that made me laugh, Good one Nick.
Re: Ammeter Lighting [Re: mrcarb] #714128
11/07/17 12:55 am
11/07/17 12:55 am
Irish Swede Offline
Irish Swede  Offline
The Lucas ammeter makes a nice plug in the hole of the headlight where a VOLTMETER should have been.
Re: Ammeter Lighting [Re: Irish Swede] #714158
11/07/17 4:14 am
11/07/17 4:14 am
Canada
LarryLebel Online content
LarryLebel  Online Content
Canada
I put a voltage indicator idiot light as sold by Paul Goff on my B44R. It glows a different colour depending on the voltage. You could mount it between the gauges. Had there been a voltage gauge that fitted in the ammeter hole I would have bought that.
Re: Ammeter Lighting [Re: mrcarb] #714164
11/07/17 6:12 am
11/07/17 6:12 am
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Unlike some that think its useless I find an ammeter useful. To answer your question, sometimes your indicator lights in the headlight shell will actually illuminate the ammeter. Perhaps adding a small 281 bulb inside the headlight shell. Just make sure the ammeter body is completely transparent so it can shine through. Lucas ammeter never had bulbs fitted in them. I thought about using a 281 bulb and holder in the shell but I have never got to it.
Re: Ammeter Lighting [Re: C.B.S] #714177
11/07/17 2:14 pm
11/07/17 2:14 pm
BSA_WM20 Offline
BSA_WM20  Offline
If you are going to drill a hole in your ammeter shell, fill the thing with oil.
Once oil dmped they work a lot better and are less likely to be reading sympathetic engine vibrations than amps.
Re: Ammeter Lighting [Re: BSA_WM20] #714189
11/07/17 3:51 pm
11/07/17 3:51 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Sounds like you have tried that before
Re: Ammeter Lighting [Re: mrcarb] #714223
11/07/17 8:36 pm
11/07/17 8:36 pm
Illinois
Spitfire Ken Offline
Illinois
At night when you would want an ammeter light is the worst time to have on. It's when your electrical system is already over taxed be other useless energy wasters like a headlight, taillight, brake light and gauge lights. when all these are in use your ammeter is already discharging to the point that you want to get home before your battery goes dead. I suggest adding a flash light to your helmet of forehead in case you are not wearing a helmet.
The Devil is in the details.
1957 BSA A10 Spitfire Scrambler (number matching, very correct in decent condition)
2001 Kawasaki W650
Re: Ammeter Lighting [Re: Spitfire Ken] #714224
11/07/17 8:52 pm
11/07/17 8:52 pm
triton thrasher Offline
Can you not get the charging system to work on any of your BSAs?
Re: Ammeter Lighting [Re: mrcarb] #714255
11/08/17 6:42 am
11/08/17 6:42 am
The 6 V alternator systems were pretty bad too.
Hope he gets his ammeter lit up though.
Re: Ammeter Lighting [Re: mrcarb] #714278
11/08/17 3:54 pm
11/08/17 3:54 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
So pretty much I'm reading that a standard 12V Lucas stator cant power a small bulb in a headlight shell.....
Re: Ammeter Lighting [Re: C.B.S] #714287
11/08/17 5:48 pm
11/08/17 5:48 pm
Where ya reading that?
Re: Ammeter Lighting [Re: mrcarb] #714291
11/08/17 5:56 pm
11/08/17 5:56 pm
Ipswich England
wbabojo Offline
wbabojo  Offline
Ipswich England
My 1965 A50DC has a battery status monitor fitted where the steering lock should go. Works a treat. http://aoservices.co.uk/data/bsm.htm
I also have a 12-0-12 Ammeter, which looks pretty.
Gavin
Re: Ammeter Lighting [Re: triton thrasher] #714340
11/09/17 2:04 am
11/09/17 2:04 am
Illinois
Illinois
Yes they are working as deigned with all that implies.
2001 Kawasaki W650
