Atlanta Bonnie
Atlanta Bonnie
Atlanta, Georgia
34 registered members (Alexp), 215 guests, and 371 spiders.
10256 Registered Users
Lannis 62
608,735 mail-order LSR
Topics67,113
Posts651,292
Members10,256
Page 3 of 3 1 2 3
Re: 441 [Re: kevin roberts] #714279
11/08/17 4:00 pm
11/08/17 4:00 pm
gavin eisler Offline
My old red Boyer circa 2000 runs fine with 6V coils ( twin),if the leads are reversed it puts the timing miles out and creates a bang in the exhaust pipe.
Boyer used to offer a great service, return the box to the Factory with some cash for postage and they would send back a working unit if it was faulty. Dont know if this still applies. i never used it but others certainly did.
Re: 441 [Re: kevin roberts] #725489
02/13/18 9:54 pm
02/13/18 9:54 pm
kevin roberts Online content OP
fefsa
kevin roberts  Online Content OP
fefsa
got some parts to simplify the ignition:
i like electronic ignitions in general, but this one has been a bear. with a 12-degree mechanical AAU, i can expect some retard to make starting easier.
couldn't get the Boyer to retard at all. it would run at full advance without retarding at low rpm, which could have been reversed points leads, i'm told. except i couldn;t start it with the points leads the other way. so we'll see what original low-tech can contribute.
the AAU is interesting. i have never owned an AAU that had a visible scribe mark on the points cam for setting the points. i've always just turned the little bastards until the points were all the way up. maybe this one will save a minute or two.
live every day.
die once.
Re: 441 [Re: kevin roberts] #725494
02/13/18 9:58 pm
02/13/18 9:58 pm
triton thrasher Offline
You've got the famous "quicky-wear" nylon points heel.
Re: 441 [Re: kevin roberts] #725515
02/14/18 12:38 am
02/14/18 12:38 am
fefsa
fefsa
the old originals? they're all burnt up.
i bought dai ichi points and condensors from peter quick to install instead of the Boyer.
[Linked Image][Linked Image]
hope the system works better.
live every day.
die once.
Re: 441 [Re: kevin roberts] #725524
02/14/18 1:39 am
02/14/18 1:39 am
BSA_WM20 Offline
BSA_WM20  Offline
Check the cam bush very carefully.
If there is any up & down play, that will be amplified over the distance between the bush and the points cam,
The act of the valves pushing against the cam and then releasing pressure on it can cause the points to open & close at funny times.
I have had this problem twice and it took a long time to work out what it was.
The dirty bodge was to open the points to .020" on the cam with a point on it anc close down to 0.008" on the cam with the flat on it.
Then adjust the points plat to get the correct timing.
And duble ditto on the fast wear nylon rubbing block.
They are most likely the only ones you can get now days.
Originals were bakalite and only rarely required adjustment for wear.
The nylon ones required weekly adjustments and I have seen some melt at the pivot.
To be fair that bike was overheating.
These are car points and designed to be in a nice cool distributor not stuck in the crankcase of a stinking hot air cooled engine.
And do yourself a big favour, put a second pair of points, adjusted so they are not touching the cam in the other loacting place on the backing plate.
That way you will have a spare set.
Now to be fair, we ride long distances down here oft in really hot weather but I have had more than one set of them wear excessively on the pivot due to excessive heat, so keep it lubed.
Mount the cap on one of the coil mounting bolts where it will get some cooling air.
Re: 441 [Re: kevin roberts] #725657
02/15/18 2:41 am
02/15/18 2:41 am
fefsa
fefsa
interesting on the cam bush. that's obvious in hindsight, but it never occurred to me until you mentioned it. i'll do some wiggling and see how it looks.
re the contact breaker rubbing block, i have never seen any made in bakelite. the nylon or plastic ones are the only ones i have ever come across for british stuff, although the points for the magneto in my ARD are bakelite, i believe.
i haven't run points seriously in a lot of years, as soon as i could afford my first Boyer, in fact. that was back when bad condensors were eating my points, and new condensors cost as much as a month's rent for me. i run some now in an old A65, but they were the first ones i'd messed with in a lot of years. putting these in will be interesting.
might put them in tomorrow. i'm backing up on projects, but the shop is due to warm up a bit so we'll see where we are.
live every day.
die once.
Re: 441 [Re: kevin roberts] #725673
02/15/18 9:02 am
02/15/18 9:02 am
i think it was the 4CA breaker plate had the bakelite heel,my 6CA had the nylon as well, that felt pad needs a drop of oil to stop the heel wearing real fast.
used to travel with a spare cap in my pocket, you either had very cheap rent or the cap man was gouging you!
Re: 441 [Re: gavin eisler] #725721
02/15/18 7:34 pm
02/15/18 7:34 pm
fefsa
fefsa
two Lucas capacitors were US$40, which was the cost of 40 loaves of bread, 80 packets of cigarettes, or 80 US gallons of gasoline.
at the time i shared a $160 house with three other students.
didn't know until i was told here on this forum how interchangeable capacitors were.
live every day.
die once.
Re: 441 [Re: NickL] #725722
02/15/18 7:35 pm
02/15/18 7:35 pm
fefsa
fefsa
Originally Posted by NickL
Better off mounting the cap up by the coil.
Buy a 0.22uf 400v 105 deg c mkp polyprop cap and solder some leads on it, much better than this bike and car crap.
Typical
https://www.eBay.com.au/itm/CAP-SUP-Y2-PP-0-22UF-300VAC-RAD-R413N32204000M-Fnl/391973940170?hash=item5b4377abca:g:wbQAAOSwtGlZJIFZ
http://www.ebay.com.au/itm/2pcs-PHILIPS-BC-MKP376-0-22uF-0-22-F-0-22uF-630V-5-P-27-5mm-Capacitor/161234340950?hash=item258a50cc56:g:mm4AAMXQVT9TDHiu
looking . . .
i am exceptionally non-electronic. how do you decide which post to ground on one of these?
live every day.
die once.
Re: 441 [Re: kevin roberts] #725728
02/15/18 8:40 pm
02/15/18 8:40 pm
Ewing. NJ
E
edunham Offline
edunham  Offline
E
Ewing. NJ
Kevin,
I prefer points and magnetos to electronic ignitions for a number of reasons. But one of them is visceral. When the advance bangs open on a Lucas Advance Unit, it feels like a big hand just started pushing you faster. You don't get that with most electronic ignitions. They advance in a much more linear fashion. Probably just as fast or faster, but they don't feel that way.
To avoid the quick wear heel issue, I buy old points plates with the original points on them at swap meets and on eBay. They are often cheap and the reason they are being sold is because the owners want electronic ignition, not because they are worn. They usually clean up just fine. I also either replace the springs in the advance units or bend the tabs out so that the springs pull back properly. Finally, I make sure the little felt for the cam is in place. I don't know why everyone used to pull them off. A little 3 & 1 oil on the felt (this goes for mags too) and on the advance unit helps the points hold their settings for a long time.
I was not a 441 fan when I was young. Twins and triples were all I was interested in. Then a few years ago I stumbled onto a T25, which led to a 441, which led to a B50. I love 'em all now (all on points- in fact, out of my 14 bikes, all are on points except my Trident and my '83 Honda which came with electronic ignition.).
Ed from
Re: 441 [Re: kevin roberts] #725748
02/15/18 10:52 pm
02/15/18 10:52 pm
fefsa
fefsa
i've kept all the mechanicals from my old morgo, humorously i could have used the 6CA plate from that T120 instead of buying a replacement one. i didn't realize that you could take a 6CA plate from a twin and just leave off one of the point sets. silly.
but i bought it from peter quick at bsa unit singles for US$11, so who's to complain? needed points anyway.
i messed with the AAU on my old morgo all the time. the cam was corroded from rust from the DPO, the little cam screws were all buggered up, the pins for the springs were worn so i had to wedge them out with pieces of beer can to hold a constant timing. i never had a gasket on the point cover so whenever it rained i had to loosen the cover and tip the bike to let the water run out before it would start.
once i stopped the springs from rattling mine had an on/off advance like you're describing, ed. i know a little more about them these days, so hopefully it will work a bit better for me.
live every day.
die once.
Re: 441 [Re: kevin roberts] #725750
02/15/18 10:59 pm
02/15/18 10:59 pm
Re grounding cap, theres two types of cap commonly used in electronics, electrolytics and normal ones, electrolytics are always marked for polarity, - one end + the other , get this wrong and they go pop, normal ones dont care, so if you get a cap without the polarity marks its a fair bet its not electrolytic and it will wire either way round, if it has the marks wire neg to points/ coil connection, and plus to chassis if its brit style positive ground/ earth. Up by the coil keeps them cool, caps dont like heat. BITD I bought car capacitors and fitted them up by the coils, they were about £1.50 each, you were being robbed for Lucas stuff, although if you had a 4 CA or Dizzy type you would struggle to get anything else to fit, the 6 CA doesnt care cos the cap isnt part of the structure. just part of the circuit.
Re: 441 [Re: kevin roberts] #725756
02/15/18 11:32 pm
02/15/18 11:32 pm
fefsa
fefsa
excellent. those things that nick linked to are cheap, and i can search on the specs to find similar things in america. looks like 22uf, lots of volts and heat resistance are the important parts.
years ago i rode my T120 across the american west with a buddy who had a 69 R60, with a magneto coil that was failing. somewhere in the oklahoma panhandle it finally died, and so we went into an auto parts place early in the morning and bought an ignition coil, tied it to the frame somewhere, and wired the magneto points to it. stuck another condensor on somewhere, too, i don;t remember where.
then we took off again, and the last i ever saw if him was as he disappeared into colorado headed for pueblo, while i took off across monument valley headed for phoenix.
nice thing about mechanicals is that you fix them mechanically, without digging into the epoxy to get intimate with the transistors.
of course, i dropped my own points as soon as i could afford EI.
live every day.
die once.
Re: 441 [Re: kevin roberts] #725789
02/16/18 10:49 am
02/16/18 10:49 am
"looks like 22uf,"
Import point, its 0.22 uFarads , not 22 , easy mistake to make , a 22 is 100 times too much, and its u ( micro ) , not m ( Milli) getting this wrong puts you out by 1,000 times.
Re: 441 [Re: kevin roberts] #725818
02/16/18 5:20 pm
02/16/18 5:20 pm
fefsa
fefsa
missed the decimal
we may have spring. thought i heard the peepers briefly day before yesterday
hyla crucifer they used to be, then tbey changed the genus to something i forget
live every day.
die once.
Re: 441 [Re: kevin roberts] #725863
02/17/18 12:17 am
02/17/18 12:17 am
missed the decimal
I've been keeping track of "First Peepers" here at our place since 1994, because it can be a good predictor of "last front" and planting time.
Only once, in 2001, did peepers peep on February 15th. Latest date is March 10, in 2010. Sure enough, "last frost" in 2001 was 4/7, and was 5/15 in 2010 ....
Re: 441 [Re: kevin roberts] #725908
02/17/18 2:10 pm
02/17/18 2:10 pm
GrandPaul Offline
GrandPaul  Offline
Those birds must watch channel 5 thru the neighbor's windows...
Re: 441 [Re: kevin roberts] #725921
02/17/18 5:24 pm
02/17/18 5:24 pm
fefsa
fefsa
robin!
and a brown towhee.
live every day.
die once.
Page 3 of 3 1 2 3
