YankeeJerry
YankeeJerry
Connecticut
38 registered members (Al Eckstadt), 262 guests, and 407 spiders.
10416 Registered Users
btour 84
Rohan 79
Triless 77
reverb 75
Stuart 70
707,857 mail-order LSR
Topics68,285
Posts664,779
Members10,416
Pre-Unit Kick Start Gear issues #713687
11/03/17 3:26 am
11/03/17 3:26 am
city island ny
H
hunter h Offline OP
hunter h  Offline OP
H
city island ny
cheers to all after some delay I am get my 60 gold star back on the road but every few kicks the kickstart pinon jams . I read some where that there were a few types of gear profiles and looks like have a mismatch. my gear box is std t with Day gears . would anyone know part #s that work . I do have all the parts books. thanks hunter
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713690
11/03/17 4:14 am
11/03/17 4:14 am
Magnetoman Online content
Magnetoman  Online Content
I'm puzzled by your question. The part numbers that work are the numbers that are in the parts book that you say you have. Early gearboxes (pre-'54 or so) had different profiles but if an early spindle is used with a later pinion, or vice versa, the mismatch is enough that it will barely turn, not jam only every few kicks.
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: Magnetoman] #713714
11/03/17 3:03 pm
11/03/17 3:03 pm
Middle East,
Kerry W Offline
Kerry W  Offline
Middle East,
I think, looking back a few decades, that the problem is one of wear - usually in the driven gear..
Oliver Wendell Holmes
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713759
11/03/17 10:10 pm
11/03/17 10:10 pm
city island ny
H
hunter h Offline OP
hunter h  Offline OP
H
city island ny
cheers all thanks for the input some time ago some one posted a few photos of kick start pinon gears . I was not able to fine it anybody remember that posting thanks hunter
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713837
11/04/17 4:21 pm
11/04/17 4:21 pm
It sounds like what you're looking for is this post. The original photos are still in my Photobucket account as well as on my computer, but searching for them would take quite a bit of time. And it wouldn't do any good anyway until the photo posting issue has been solved in a "permanent" way where the Photobucket apocalypse wouldn't be repeated. Sorry.
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713844
11/04/17 5:32 pm
11/04/17 5:32 pm
city island ny
H
hunter h Offline OP
hunter h  Offline OP
H
city island ny
thanks it looks like that post has the info I need but I will need to spend some time reading the text . thanks hunter
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713919
11/05/17 2:09 pm
11/05/17 2:09 pm
Lucan ON Canada
jfligg Offline
jfligg  Offline
Lucan ON Canada
Hi guys
Too bad the pictures don't work in MMs don't work. Jeff
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713974
11/05/17 9:29 pm
11/05/17 9:29 pm
Norfolk England
DBDBrian Offline
DBDBrian  Offline
Norfolk England
This may be of help Hunter,But not as comprehensive as MMs link with the measurements.
Quadrant tooth profiles
Pinions. Bottom and right is genuine BSA, Top and left is repro,
I also found these in a box, two different shaft lengths, long one is clubmans type. Approx 1/8" variation.
Standard one on top.
This is how I modified a standard quadrant for a clubmans type, by reversing it on the shaft.
This end requires building up with weld, and a spring anchor slot ground in.
Standard one underneath.
This end just requires grinding as above.
Modified quadrant in situ, at both ends of travel.
This little modification will stop oil dripping on your exhaust.
Brian
Made In England
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713979
11/05/17 10:29 pm
11/05/17 10:29 pm
city island ny
H
hunter h Offline OP
hunter h  Offline OP
H
city island ny
thanks Brian it looks like the one set that you show are flat at the peak of the tooth on both gears. hunter
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713981
11/05/17 11:06 pm
11/05/17 11:06 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
Many years ago I had modified my Goldie's kicker gear to allow the kicker to move ahead to clear my leg with rear set pegs. I did this by grinding off the last tooth on the kicker quadrant. This worked except sometimes if the engine didn't start the kicker would stay down and the bottom of the swing until you engaged a gear and roll the bike a bit. I cleared this issue by fitting a folding kicker. Nice.
The reason for my spiel is to suggest the possibility of a tooth being broken off the quadrant allowing it to disengage the gear on the mainshaft. You have removed the outer tranny housing?
Dave - NV
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: hunter h] #713983
11/05/17 11:23 pm
11/05/17 11:23 pm
Elko, Nevada USA
dave - NV Offline
dave - NV  Offline
Elko, Nevada USA
DB Brian .. Re your nice kicker bushing with a 'O' ring .... I've modified umm 35 outer tranny covers for other gents and 3-4 for myself. I replace the kicker and shifter shaft bushings with modern 'off the shelf' pieces. Then using a fixture and tooling accurately counter bore the bushing and cover and press in small metal body lip seals that are nearly undetectable. Also, using another fixture I bore the hole that's often found worn in the cover for the clutch arm shaft and press in a pair of 'oil less' bushings. Stop the drool! Now that speedo drive leak ... aargh.
Dave - NV
Re: Pre-Unit Transmission Info, Swing Arm Models [Re: dave - NV] #714081
11/06/17 8:06 pm
11/06/17 8:06 pm
Norfolk England
DBDBrian Offline
DBDBrian  Offline
Norfolk England
Hi Dave, the first quadrant I modified in this way was thirty odd year ago, and it has never given any trouble, the one in the pictures was done about five years ago, when I built a box with a Nova five speed C/R cluster, as can be seen by the machined selector quadrant slot, to date this has also been ok. As the lever is at the bottom of it's travel, there is probably not a great deal of force at this point. In the event of a kick back, the load would be in the reverse direction.
The seal arrangement in the cover sounds like a good idea, but as we are all only to aware, the problem then moves further on, ah well it keeps us out of mischief .
PS
I should have also mentioned. the leading tooth on the quadrant at the spring anchor end. requires grinding to allow for the lead into the pinion.
Brian
Made In England
Re: Pre-Unit Gear Kick Start Issues [Re: dave - NV] #714086
11/06/17 8:46 pm
11/06/17 8:46 pm
What lip seal do you use? When I get my 1928 Ariel's Burman apart one of my tasks will be to figure out ways to keep as much grease/oil in it as possible so I will be looking for appropriate seals at that time.
The solution is simple. The proper oil level is only ~1/4" above the speedometer gear shaft so if you slightly underfill the gearbox it won't leak from there when the bike is sitting still, and if you never ride your Gold Star it won't leak when underway...
Last edited by Magnetoman; 11/07/17 12:15 am. Reason: changed back to original title of thread
