Prospect
Prospect
London UK
42 registered members (Adam M.), 263 guests, and 332 spiders.
Duckster, IDG1, pemdoc65, creativecroc, gregneal
10171 Registered Users
Lannis 96
Stuart 84
reverb 81
NickL 69
koan58 56
550,114 mail-order LSR
Topics66,555
Posts645,181
Members10,171
Lucas Zener spec. #707095
09/03/17 2:04 am
09/03/17 2:04 am
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Does any one know the current spec for the Lucas Zener. It is very easy to simulate them with a simple circuit.
The only question is how big to make the transistor. in this image the low power zener needs to be 13.8-0.6V
Re: Lucas Zener spec. [Re: Steven A] #707099
09/03/17 2:40 am
09/03/17 2:40 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
A 6 ampere transistor is not going to cut it. The early generators put out 120 Watts. Besides, these bikes are usually positive ground (although you can change it).
Re: Lucas Zener spec. [Re: DMadigan] #707101
09/03/17 3:28 am
09/03/17 3:28 am
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
That's why I am asking.
Do you know what the later 3 phase types produced?
This is symmetrical, just run the way you want it with an isolated heat sink.
Re: Lucas Zener spec. [Re: Steven A] #707104
09/03/17 3:53 am
09/03/17 3:53 am
Denver CO
Jerry Roy Online content
Jerry Roy  Online Content
Denver CO
Amps times volts equals watts. (More or less, but close enough for government work) cool
120 watts divided by 12 V = 10 amps.
If your headlight is working, you lose that many watts, so the amps go down. But if your headlight burns out, the amps go up.
I don't like to run transistors close to their rated capacity, so 12 - 15 amps might be a better choice. Or bigger, it won't care.
With a good heat sink.
JR
Re: Lucas Zener spec. [Re: Steven A] #707110
09/03/17 7:26 am
09/03/17 7:26 am
Stuart Offline
Stuart  Offline
Hi Steven,
12~12.5A.
Lucas supplied a single Zener in parallel with the battery and rectifier even with the '69-on RM21 alternator (rated 10.5A @ 5,000 rpm). The "headlight working" is irrelevant because, certainly in GB, we've never had a headlamp-on-in-daylight legal requirement.
Because of original Zeners' current limitation, the RM23 (14.5A @ 5,000 rpm, single-phase) was supplied with two Zeners - one connected between each AC wire and 'earth'/'ground'.
Initial oe supplies of the 3-phase RM24 to the Co-op in '79 were the 'low-output' (10.5A @ 5,000 rpm) version, so Lucas continued to supply a single Zener (but now 'negative earth/ground') in parallel with battery and rectifier.
Nevertheless, the 'high-output' (14.5A @ 5,000 rpm) version was always available. For after-market fitting to 'positive earth/ground', high-output RM24 versions were supplied with two Zeners also to be connected in parallel with battery and rectifier. However, these Zeners had to be 'matched' for Volts and Amps, Lucas originally supplied these 'matched pairs' under a different part number from the single Zeners; when Lucas stopped supplying, John Carpenter at Mistral Engineering in GB set up a test rig and continued to supply 'matched' Zeners 'til he retired.
However, when the Co-op offered the high-output RM24 as an option, and oe on the electric-start twins, Lucas supplied a 'pack' of three Zeners for connection to the AC wires. I believe this 'pack' was something off-the-shelf from a completely different application.
Btw, risking telling you something you know already, Lucas considered a Zener 'within spec.' until it allowed DC to exceed 15.5V.
Re: Lucas Zener spec. [Re: Steven A] #707152
09/03/17 3:11 pm
09/03/17 3:11 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
wht am i missing, i dont see the point?
if the transistor is sized large enough
youre just moving the heat off the zener and onto the transistor.
where the transistor is working as a variable resistor.
... a power zener by its self is a simpler circuit p
Re: Lucas Zener spec. [Re: Steven A] #707163
09/03/17 4:52 pm
09/03/17 4:52 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
The best and most reliable way is to use a Reg/Rec from any permanent magnet alternator Japanese bike. The two alternator wires connect to two of the three ac connections (usually yellow) pos to red neg to black. This also removes the fragile plate type rectifier
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Lucas Zener spec. [Re: quinten] #707234
09/04/17 6:57 am
09/04/17 6:57 am
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Because the zeners are expensive and seem to be "going away".
Re: Lucas Zener spec. [Re: Steven A] #707284
09/04/17 4:21 pm
09/04/17 4:21 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Zeners are not "going away" but the need for high power zeners as regulators has been replaced by more sophisticated circuits. Instead of using a zener, you could use a linear voltage regulator such as this 13.7 volt 1.5 ampere:
http://www.mouser.com/ds/2/389/pb137-974199.pdf
to drive the regulating transistor.
A more sophisticated circuit would use a switching driver to turn on a (presumably) IGBT during the regulating phase so the voltage drop across it is minimal, reducing heat in the transistor.
Shunt regulators are the worst as they turn on when the voltage reaches the set point (because they use SCRs) which means you loose all the power from the rest of the cycle, not just the portion that exceeds the limit.
In any case it will need a heat sink since the excess power is dissipated by heat.
Not all regulators from Japanese bikes are "plug and play". Some need a sense input. You should check on line forums for which bikes have problems with their regulators.
Re: Lucas Zener spec. [Re: NickL] #707441
09/05/17 9:41 pm
09/05/17 9:41 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Originally Posted by NickL
The transistor will spend a lot of it's time in the semiconducting state so it's dissipation will be large.
The use of the good old 2n3055 would be a better bet but even then it'll get very hot. (IE.5 volts x 5 amps = 25watts)
Linear operation of any transistor generates heat. Pulse width modulation is far better but gets more complicated.
I posted a circuit for a single/bi phase regulator ages ago but as Andy says, you are better off
buying a ubiquitous regulator most of which use thyristors/scrs and work on the AC side as a shunt rather than on DC.
These are very good. (Just link 2 yellow wires together for single/bi phase operation.)
http://www.eBay.com.au/itm/5-Way-Regulator-Rectifier-Male-Plug-Connector-Fit-For-Honda-CB400-CBR600-DA-/162516257547?epid=907545014&hash=item25d6b94b0b:g:FD8AAOxy-gBR~G~e
http://www.ebay.com.au/itm/Voltage-Regulator-Rectifier-For-Honda-CBR600-F2-F3-CBR900RR-SC28-CBR400-NSR125-/172671240214?hash=item2834020816:g:LdsAAOSwo4pYEXPM
So this has a three phase rectifier that can be used single phase?
Re: Lucas Zener spec. [Re: NickL] #707477
09/06/17 6:02 am
09/06/17 6:02 am
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Correct, you can either link 2 of the 3 yellows together or cut 1 off.
Pos == Red
Neg = Green
Nick
Very good, I'll keep one on the shelf. Too cheap to pass up.
Re: Lucas Zener spec. [Re: NickL] #713503
11/01/17 9:14 pm
11/01/17 9:14 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Pos == Red
Neg = Green
Nick
Hi Nick. I have one on the bench. Single phase in as instructed, about 20V p-p. Out put is across 12 Ohms but with no battery present. I assume you need a battery across the output to see these things work.
Re: Lucas Zener spec. [Re: Steven A] #713637
11/02/17 8:06 pm
11/02/17 8:06 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
The latest Reg/Rec units for modern bikes are now series instead of shunt, this open circuits the windings instead of shorting them. This creates less heat and less drag
1962/67 Greeves 350
Re: Lucas Zener spec. [Re: Andy Higham] #713662
11/02/17 10:48 pm
11/02/17 10:48 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
I was wondering about that very thing. Opinion was divided in my lab but I think you are right.
Re: Lucas Zener spec. [Re: NickL] #713673
11/03/17 12:31 am
11/03/17 12:31 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
there is minimal drag when the stator is shorted/shunted ... .
why ? because no electromotive work is ask to be done .
there is no electrical circuit , there is no end of any wire in which to measure a voltage differential ... its magnetic
there is just this lump of copper and iron and the eddy current heat , same as normal .
nothing extra in the way of heat (drag) is coming from the induced magnetic field
because no work is being done .
the stator isn't
fighting the rotor so much ,
because the stator is safely unloaded and sort of freewheeling on minimal magnetic inertia ... out of phase with the rotor .
conversely , when a stator is open-shunted the induced open voltages can climb to levels higher
than the magnet insulation wire can handle ... open shunting is for stators specifically designed to handle the application
Re: Lucas Zener spec. [Re: quinten] #713698
11/03/17 7:30 am
11/03/17 7:30 am
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
the stator isn't
Not so sure that shorting the windings does not cause drag. I have a vague memory of doing this in a lab and there was an awful lot of resistant to rotation. It's to do with magnetically generated reverse torque.
A linear analogue is dropping a magnet down a metal tube. It goes pretty slow despite gravity.
Re: Lucas Zener spec. [Re: Steven A] #713730
11/03/17 4:29 pm
11/03/17 4:29 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
"there is no electrical circuit" There is an electrical circuit, the shunted winding is a circuit.
Try this experiment, take a small permanent magnet electric motor and turn the shaft with your fingers. You will feel the pull of the magnet on the armature poles. Now short the terminals together and you fill feel it is harder to turn. An electric motor and an alternator are essentially the same thing.
It is common practice to use shunt resistors including zero ohms and to brake a motor
1962/67 Greeves 350
Re: Lucas Zener spec. [Re: Steven A] #713807
11/04/17 12:55 pm
11/04/17 12:55 pm
FRANCE- DINARD -BRITTANY
marinatlas Offline
marinatlas  Offline
Hi,I had follow that thread with great interest , as the problem had been opened few times ago on another Norton forum by a canadian specialist , about using the lithium battery on our bikes , he said that most of classic rec/reg either over charged or under charged , and that the solution was the series modern rec/reg such as sh775.........???
Re: Lucas Zener spec. [Re: marinatlas] #719288
12/18/17 8:59 pm
12/18/17 8:59 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Yes
Re: Lucas Zener spec. [Re: Steven A] #719291
12/18/17 9:02 pm
12/18/17 9:02 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
The unit in action. As advised there is a resistor between the charger input and the AC source. Scope traces are the input.
[img]https://plus.google.com/photos/1034...00994286529500482?authkey=CL_f8u2DmP-LDg[/img]
[img]https://plus.google.com/photos/1034...00994289935810786?authkey=CL_f8u2DmP-LDg[/img]
[img]https://plus.google.com/photos/1034...00994286884019506?authkey=CL_f8u2DmP-LDg[/img]
[img]https://plus.google.com/photos/1034...00994287300364978?authkey=CL_f8u2DmP-LDg[/img]
The image function doesn't seem to like Google+.
Re: Lucas Zener spec. [Re: marinatlas] #719292
12/18/17 9:05 pm
12/18/17 9:05 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Does the SH775 reliably charge at 13.8v? I want to use a data logger that only tolerates 14V max.
Re: Lucas Zener spec. [Re: Steven A] #719297
12/18/17 9:16 pm
12/18/17 9:16 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
And an overview of regulation types.
http://www.shindengen.co.jp/product_e/electro/reg.html
Re: Lucas Zener spec. [Re: Steven A] #719298
12/18/17 9:19 pm
12/18/17 9:19 pm
Melbourne Oz
Steven A Offline OP
Steven A  Offline OP
Melbourne Oz
Re: Lucas Zener spec. [Re: Steven A] #719694
12/22/17 8:04 am
12/22/17 8:04 am
Aus
NickL Offline
NickL  Offline
Aus
If you are worried about your logger just stick a diode in it's supply, that'll drop 0.65v or so.
Re: Lucas Zener spec. [Re: Steven A] #719702
12/22/17 10:50 am
12/22/17 10:50 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
A fully charged 12v battery is actually 13.8v, to charge the battery the voltage needs to be above this voltage
1962/67 Greeves 350
Page Time: 0.240s Queries: 16 (0.006s) Memory: 1.2053 MB (Peak: 1.5638 MB) Zlib disabled. Server Time: 2018-04-21 15:31:33 UTC
