Kenneth Million
Kenneth Million
Jonesborough, TN
19 registered members (76degree-triumph), 166 guests, and 116 spiders.
10174 Registered Users
Lannis 94
reverb 91
Stuart 70
koan58 67
L.A.B. 54
552,769 mail-order LSR
Topics66,586
Posts645,507
Members10,174
A65 split in case #713711
11/03/17 2:19 pm
11/03/17 2:19 pm
Fergus, Ontario, Canada
Dave T Offline OP
Dave T  Offline OP
I just spent a few days chasing an elusive oil leak. Fixed the wet sumping but found that the leak was coming from a small split in the case where the oil pressure switch goes. Looks like someone has put double bond or similar in there before. I am guessing the crack starting after someone over tightened the oil pressure switch.
Is there anything I can run along the ( very small) crack that would seal it? Maybe Aluminium dust and super glue? Can I get a crack like that welded with the engine in the frame? I really do not want to pull it.
All ideas welcome.
Re: A65 split in case [Re: Dave T] #713712
11/03/17 2:33 pm
11/03/17 2:33 pm
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
You could try JB Weld which is basically an epoxy. Try to get it as oil free as possible.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: A65 split in case [Re: Dave T] #713720
11/03/17 3:53 pm
11/03/17 3:53 pm
Lancaster, California
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Try using three-bond or perhaps a gear box oil silicone. As with htown said, make sure the alloy is clean
Re: A65 split in case [Re: Dave T] #713721
11/03/17 3:54 pm
11/03/17 3:54 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Oh ya, the crack could have come from someone using an straight thread oil pressure when it should have had a taper?
Re: A65 split in case [Re: Dave T] #713732
11/03/17 5:55 pm
11/03/17 5:55 pm
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
Dave T, what year is your bike?
1974 Trident
Re: A65 split in case [Re: htown] #713743
11/03/17 8:16 pm
11/03/17 8:16 pm
Dave T Offline OP
Dave T  Offline OP
The engine is 1970 so, if uses the taper threaded switch. And that is what I have, although I think the one I took out when I rebuilt this engine was straight. probably why the crack developed in the first place. I am going to v out the crack, clean with acetone as best as possible, then apply the jb weld. I am thinking I might mount the switch first so I dont break the jb weld when I tighten up the switch.
Re: A65 split in case [Re: Dave T] #713750
11/03/17 9:34 pm
11/03/17 9:34 pm
Magnolia, TX
htown Offline
htown  Offline
Magnolia, TX
The 70 has the straight/parallel thread switch. Mine does. Probably someone put a tapered one in and over tighten it. Replace it with the correct straight/parallel thread switch. Some suppliers especially on eBay will send you a wrong tapered thread one. Use a reputable supplier.
See the reply by Stuart in this thread.
http://www.britbike.com/forums/ubbt...p;Board=1&main=48889&type=thread
1974 Trident
Re: A65 split in case [Re: htown] #713758
11/03/17 10:08 pm
11/03/17 10:08 pm
C.B.S Offline
Parts Dealer
C.B.S  Offline
Parts Dealer
Exactly as I said... Yep, use a supplier like my company - avoid problems
Re: A65 split in case [Re: C.B.S] #713766
11/03/17 10:35 pm
11/03/17 10:35 pm
Dave T Offline OP
Dave T  Offline OP
OK, now I am confused. my parts book for 70 lists 19- 6508. Your site lists this as tapered
https://www.classicbritishspares.co...60-2133-tr25w-t100r-t120-a50-a65-uk-made
On that same page you quote "We also stock the Late Veglia Type Oil Pressure Switch with "Straight" Piped Thread! Search 60-3719
•Made in Taiwan
•O.E.M Part number is 60-2133, D2133 or 19-6508"
Which is correct for 70, tapered or not?
Re: A65 split in case [Re: Dave T] #713767
11/03/17 10:47 pm
11/03/17 10:47 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
If the hole has a faced area around it chances are it will take a parallel thread and sealing washer, if not it will be a taper thread with thread sealant.
Taper threads can exert a massive force on the housing. Apply sealant screw in finger tight then 1/4 turn with a spanner-NO MORE
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Page Time: 2.231s Queries: 15 (0.044s) Memory: 1.0586 MB (Peak: 1.2480 MB) Zlib disabled. Server Time: 2018-04-25 08:46:12 UTC
