Jeff Covert
Jeff Covert
Benton, AR USA
48 registered members (Allan Gill), 191 guests, and 62 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,105 mail-order LSR
Topics68,855
Posts670,708
Members10,478
WTB: '71-'72 Triumph OIF Triple Trees #709939
09/28/17 10:55 pm
09/28/17 10:55 pm
Vancouver
ogoki Offline OP
ogoki  Offline OP
Vancouver
Does anybody have a set of 650 conical trees with which they can part?
Thanks!
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #709948
09/29/17 3:36 am
09/29/17 3:36 am
GrandPaul Offline
GrandPaul  Offline
If you give me the spacing between stanchion centers, and the offset from the stem centerline to the stanchion centerline, I can measure the ones I have and see I have a properly matched set.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #709950
09/29/17 4:19 am
09/29/17 4:19 am
hamden, ct.
hacksaw Offline
hacksaw  Offline
hamden, ct.
I should. send me an email hacksgarage@icloud.com
lets see what I can do for ya!!!!!
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #709955
09/29/17 5:08 am
09/29/17 5:08 am
Vancouver
ogoki Offline OP
ogoki  Offline OP
Vancouver
hacksaw - email sent
GrandPaul - castings numbers should be 97-4036 and -4038. And the stem is skinny (3/4"?) compared to 60s trees.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: GrandPaul] #709962
09/29/17 6:52 am
09/29/17 6:52 am
Stuart Offline
Stuart  Offline
Hi Paul,
The "Trees" of the title are unique - 6-3/4" between stanchion centres, upper "tree" doesn't have holes for Metalastik bushes for speedo./tacho. mounting, lower "tree" doesn't have the Zener heatsink mounting tab, steering stem is a nominal 3/4" o.d.; if you have a micrometer, the stanchion holes (in the lower "tree") are for 1.35" o.d. stanchions.
'69-on dry-frame trees will have one or more of those things, steering stem will be (1/4"?) longer, '69/'70 stanchion holes will be ~50 thou smaller.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #709981
09/29/17 1:07 pm
09/29/17 1:07 pm
GrandPaul Offline
GrandPaul  Offline
Casting numbers are easier, but thanx, Stuart!
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: GrandPaul] #710002
09/29/17 5:01 pm
09/29/17 5:01 pm
Stuart Offline
Stuart  Offline
Hi Paul,
Casting numbers are the same for twin and triple in both years, finished numbers for the lower tree are neither ("97-4038" is shown as the "finished" part number in the '71 T150 parts book). In addition to the aforementioned differences, there's also a difference to the rear edges of the casting. They were cast with a triangular block on each edge, that I believe were machined off for twins; on triples, these hit against the frame-mounted steering stops on full lock; oif have (a) different steering stop(s)?
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #710071
09/30/17 4:09 pm
09/30/17 4:09 pm
Vancouver
ogoki Offline OP
ogoki  Offline OP
Vancouver
Sorry for the faulty lower casting number. I took that from somebody's eBay auction. I have two sets - both bent in exactly the same spot - but the casting number is illegible on both.
Stuart, thank you for the info. Are the '71-'72 T150 "trees" the same, with the exception of the steering stem? These are for a "bitsa." I am set on running the conical front drum and forks, but if the T150 trees will work with the forks and drum, and have the dry frame 1.0625"(?) stem, that would be even better.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #710115
10/01/17 4:22 am
10/01/17 4:22 am
Stuart Offline
Stuart  Offline
Basically, yes - stanchions and 6-3/4" spacing between centres are the same on both twins and triples, conical front brake is the same too. As well as the cup-'n'-cone bearings stem on the T150 lower, it has a tab to mount the Zener (although many are broken off frown ) and, iirc, the triangular steering stop blocks on the rear edges. Btw, if your bitsa has a 'dry' frame, you know the steering stops unscrew and you can refit 'em with the smaller diameter below the steering head for more steering lock, as long as the forks then don't hit the tank?
Btw2, you know these can be straightened?
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: Stuart] #711814
10/17/17 4:01 pm
10/17/17 4:01 pm
Vancouver
ogoki Offline OP
ogoki  Offline OP
Vancouver
I do, although I don't really have the means to do it myself right now. I did approach a couple of people locally for help, and they advised against it (although I realize it is common practice)...
Bump... Anybody holding a set of '71-'72 650 "triple trees" (top yoke, and bottom yoke and steering stem), or corresponding T150 trees? I really only need the bottom yoke/steering stem....
Thanks.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #711850
10/17/17 10:05 pm
10/17/17 10:05 pm
San Rafael, Ca.
BikeVice Online content
BikeVice  Online Content
San Rafael, Ca.
I have an NOS 1971 T150 bottom yoke/stem and sleeve nut (1972 used a different stem thread pitch). I'd like $75.00 for them and can post pictures tomorrow.
Eric
1971 T120RV (R.I.P.)
1973 T140V/TR7
1993 Ducati 900 SS
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #711912
10/18/17 3:50 pm
10/18/17 3:50 pm
Vancouver
ogoki Offline OP
ogoki  Offline OP
Vancouver
I'm just realizing that the T150 stem might not fit through my neck cups. Could you confirm the stem diameter, Eric, or Stuart, or anybody? Thanks.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #711919
10/18/17 6:24 pm
10/18/17 6:24 pm
Stuart Offline
Stuart  Offline
Oif and 'dry-frame' stem diameters are the same - I measured it as 3/4" with just a ruler but Dave Madigan posted on Triples On Line it's 0.748". The oif length is a little (1/4"?) shorter than the 'dry-frame' length.
Eric is correct about the threads: '71, the steering stem nut thread is 3/4"UNF - 16 tpi (threads per inch). '72-on, it's 3/4"UNS - 24 tpi.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #712002
10/19/17 5:46 pm
10/19/17 5:46 pm
Vancouver
ogoki Offline OP
ogoki  Offline OP
Vancouver
Thanks for the additional info, Stuart.
Eric, I sent you a pm.
Re: WTB: '71-'72 Triumph OIF Triple Trees [Re: ogoki] #713541
11/02/17 3:44 am
11/02/17 3:44 am
Diamond Springs, Kalifornia
Buckshot1 Offline
Buckshot1  Offline
If what Eric has doesn't work for you, I have a set from my 72 T120R.
Michael
currently owned by a 72 T120R
'02 Sprint ST
maker of plunger conversion jig
Moderated by  Steve Erickson
