Carlo
Carlo
Eugene, OR
43 registered members (998John), 270 guests, and 454 spiders.
10257 Registered Users
Lannis 55
TBolt72 47
610,679 mail-order LSR
Topics67,148
Posts651,614
Members10,257
T140 Ported Head Question? #712092
10/21/17 5:15 am
10/21/17 5:15 am
Murrieta California
Mike Austin Offline OP
Murrieta California
My first post here, so hello everyone. I need an opinion on a head decision for a T140 Bonneville engine to be used for Sportsman Open Twins (motocross). Its being built on Johnson Cams version of the Spitfire cam set, and MAP forged 9 to 1 pistons set at .035" (ish) squish. The plan was to lightly prep a stock head and rebuild it with Kibblewhite guides and valves, but the head I bought was not stock... So run the ported head as described below, or find a stock one???
Like everyone I shop eBay for parts and I bought a generally nice T140 head but I got a surprise... The head was ported :cry, the intake ports match the example shown in Stan Shenton's book "Triumph Tuning, including opening the ports up to 32mm as shown below...
At some point after the head was ported someone attempted to add "texture" to the port walls and made things ugly but did no real damage. the plan is to clean the head up and rebuild with Kibblewhite guides and valves using the Norton spring set recommended by Johnson Cams
The plan is to run the MAP 3 inch tapered manifolds (port matched by boring on my lathe), with 32mm VM Mikunis.
The exhaust ports look like this, the plan is to get the ports threaded for stubs and run 1 1/2" exhaust.
The chambers are nice and the gasket surface is flat.
Thanks For Your Time And Comments: Mike
"An ill-assorted collection of poorly-matching parts, forming a distressing whole."
Re: T140 Ported Head Question? [Re: Mike Austin] #712098
10/21/17 7:12 am
10/21/17 7:12 am
kevin roberts Offline
fefsa
fefsa
run the ported head first and see how it works. you could probably avoid the cost of tbreading tbe exhaust by using push-in pipes and springs. or weld on external aluminum stubs.
i have no idea what i'm doing.
Re: T140 Ported Head Question? [Re: kevin roberts] #712179
10/22/17 1:20 am
10/22/17 1:20 am
Murrieta California
Murrieta California
Hi Kevin.
Thanks for that, I'm close to the Los Angeles area so I'm lucky to be in a "Triumph specialist" rich environment, I may take a day off his week and collect a few opinions as to what my options are with this head. The exhaust port has been opened up enough that the push in pipes are not well supported by what's left of the support ring that the pipe butts up against, I am afraid the pipe will chew it way through the support ring and end up in the port, and the push in inserts are thick wall so that won't work with this port without partially blocking it, so I will probably have to bite the bullet and go with a thread in conversion that will butt against the support ring, assuming the head is not so over ported as to be useless in my application.
I would like to run this head but there are a lot of unknowns with it, and as I am relatively new to Triumphs I do as much research as I can and make conservative decisions based on others experience and successes.
So I have found myself sort of out in the weeds with this head as its a circa 1967 full road race port job and I have no idea how flat the power will be below 3K RPM.
The Spitfire grind cams are reported have a smooth power delivery so that may be this heads saving grace as I'm 60 and no longer have the attention span to race a bike with peaky power delivery banging handlebars with other old men. So its kind of a blurry line as to what's ridable and what's not.
Thanks: Mike
Re: T140 Ported Head Question? [Re: Mike Austin] #712223
10/22/17 11:06 am
10/22/17 11:06 am
Running from demons in WNY
Hillbilly bike Online content
The "Spitfire" cam is a stock 750 intake cam?....Modern porting isn't always about big ports but more about high velocity from smaller properly shaped ports ...This is especially true on a street bike ...My opinion based on my 650 race bike...That head with Spitfire cams will have reversion problems and a big flat spot around 3500-4000 rpm....Perhaps a two into one or crossover pipe exhaust will help out...
Re: T140 Ported Head Question? [Re: Hillbilly bike] #712266
10/22/17 6:47 pm
10/22/17 6:47 pm
Murrieta California
Murrieta California
Hi Hillbilly bike,
That's Information I need. The Spitfire cam set is from Johnson Cams, so yes its their version of the Triumph inlet and exhaust cams. A flat spot in that range would make this head useless for a motocross engine. Not good news but I kind of suspected I was hosed when I got my first look at the ports, I have read enough of your posts here on Britbike that I value your opinion. I have poured enough money into this project a little more won't hurt, I guess its time to shop for another head. Thank you for taking the time and for an honest opinion.
: Mike
Re: T140 Ported Head Question? [Re: Mike Austin] #712270
10/22/17 7:09 pm
10/22/17 7:09 pm
Have you talked to Johnson Cams about the head? If you have money into the head then maybe just run it to see how it goes with the cams and whatever carbs and exhaust you're using...It's no big deal labor wise to swap heads if it doesn't suit your needs.
Re: T140 Ported Head Question? [Re: Hillbilly bike] #712334
10/23/17 2:25 am
10/23/17 2:25 am
Murrieta California
Murrieta California
You have a very good point, I have a set of tappits that has to go to Johnson cams for a regrind, I will give them a call in the morning and if they can do something for me, if so I will find a bigger box and ship the head to them and not worry about it until I hear back. It's one of those things one way or another I have to spend money If Johnson can fix my problems, I'm more than happy to pay them.
I wish I wasn't so OCD life would be much simpler. an example would be the Husqvarna wheel swap into the OIF swingarm. I didn't want to reduce the diameter of the rear axle from 5/8" to the 15mm Husqvarna standard, so the challenge was to find a bearing that fit the Husqvarna hub that had a 16mm ID. Motobecane moped crank bearings are dimensionally the same as a 6302 bearing with a 16MM ID, problem solved except the OIF axle is now too small, easy hard chrome the Triumph axle and grind the od to .6285... I had to buy a 16mm reamer to size the spacers and backing plate. But now I'm happy and it only took 2 weeks to figure out. this is that result...
Yes I'm nuts, I build everything with the same attention to detail and I am really enjoying this build and thank you for your input it's spot on, your advice has gotten me out of my funk and on to something productive. I will keep everyone informed on my progress.
Thanks Again: Mike
Re: T140 Ported Head Question? [Re: Mike Austin] #712880
10/27/17 5:54 am
10/27/17 5:54 am
Murrieta California
Murrieta California
Well things are going quite well, a 10 bolt T140 head has been located with good seats and a unnamed shop on the west coast that has a great reputation for supporting vintage flat track racing has agreed to build my new head, nothing exotic, Kibblewhite valves, guides, norton springs, steel pushrods, and porting that complements the cams, things are looking up. There was some confusion over the Spitfire cams from Johnson, in their catalog their called T65 cams described as "Between a Q and a Jomo 15. Good for hot street, short track, and TT in 650 and 750 twins" so that should clear things up a bit.
Its been a good week for hunting parts as I have a line on a pre 1965 T120 frame with less rake than the later models, this works in my favor as the turn in should be better for motocross, I still have to figure out the offset for the triple clamps, that will happen when I can mock up the chassis with the 13 inch shocks and the 1973 Husqvarna forks and wheels, yes the bike is a "bitsa" but a well thought out one. I scored a 1960's Webco oil tank in great condition (it should look nice with the TR5T alloy tank) so Its the prize of the week and the Carrillo rods showed up... Woot.
: Mike
Re: T140 Ported Head Question? [Re: Mike Austin] #721229
01/06/18 12:36 am
01/06/18 12:36 am
Murrieta California
Murrieta California
It's been a while so time for an update. Johnson Cams should ship my new head sometime next week, its fairly basic, porting to match the T-65 cams, Kibblewhite valves + guides, Norton springs, reground "R" tappets, and steel pushrods at their recommendation. This is what the cams look like.
Triumph T-65 Cam
Between a Q and a Jomo 15. Good for hot street, short track, and TT in 650 and 750 twins.
(this may be a mess as I cant get this to format correctly)
Lift Center Lash Tappet Dur'n Open Close At
Intake .344 105 .008 R 280 36 64 .020
Intake .344 105 .008 R 255 23 52 .040
Exhaust .344 105 .010 R 280 66 35 .020
Exhaust .344 105 .010 R 255 53 22 .040
An Electrex World digital CDI crank triggered ignition system was sourced, made in England a nice piece of kit and saves a bunch of weight.
I found a somewhat rusty but straight and solid 1967 TR6R frame, 28 degree steering head that will work well for the Husqvarna fork conversion. Emig Racing is building the conversion triple clamps (parallel clamps with 49 mm of offset that use the factory steering stops). This combination should turn well as the clamp geometry is the same as the early aftermarket Profab clamps that worked quite well back in the day. Here's a photo of the chassis in mockup (the oil tank is at the platers having the chrome stripped, it will be back to bare aluminum in a few days)
[/align].
Some detab work in progress.
So progress is being made but somewhat slowly.
: Mike[list]
[align:left]
Re: T140 Ported Head Question? [Re: Mike Austin] #721234
01/06/18 1:24 am
01/06/18 1:24 am
OZ
Triless Online content
Triless  Online Content
OZ
That's the ignition I have for my race project, and, yes, Mike, it is a nice bit of gear ! My cams are Megacycle " Jomo 15's.
I was talking to a bloke here in OZ who is using one of these Electrex World kits in his classic racer and is really happy with it.
Incidently, I , too, will be using chrome moly pushrods, Kibblewhite valves and their Beehive valve springs, and a host of other
good stuff !
I reckon my progress has been much slower than yours, though !
Re: T140 Ported Head Question? [Re: Mike Austin] #721699
01/11/18 4:20 am
01/11/18 4:20 am
Murrieta California
Murrieta California
Hi Triless,
Progress is one of the hardest things to make, between work and the wife I try to steal time whenever possible. Triumphs are special, like biting into a slice of history, like any mechanical endeavor I realize I am standing on the shoulders of everyone who has built one of these engines before me.
This forum has been a great resource with so many people sharing their experience of all aspects of these engines, I have found so much great information here BritBike has become my main resource for information and research, by my estimate I have read about a third of this entire website.
This is my first "hot rod" Triumph engine build (lots of builds with certain pushrod v twins), and it's proving to be one of my most enjoyable mechanical experiences ever. Its also a lot of detective work to find competent machine work, an example would be finding the guy who has the tooling fixture to mill the cylinder deck parallel to the crank centerline and square to the cam bushings. As I progress through this build I have discovered people and shops that have directed me to other reliable sources for machine work, most of which were involved with mile flat track racing in the golden years of the 70's and 80's
The sad thing is a lot of the deep knowledge and skill resides in men in their 70's, in a few years most of this will be lost to the sands of time.
: Mike
Moderated by  Allan Gill
