Anders_t120
Anders_t120
Gotland Sweden
44 registered members (Alan_nc), 229 guests, and 379 spiders.
10478 Registered Users
NickL 92
franko 77
Triless 70
749,210 mail-order LSR
Topics68,856
Posts670,740
Members10,478
1955 A10 Golden Flash Rocker box. #712704
10/25/17 8:34 pm
10/25/17 8:34 pm
Houston, Texas
Samsmc1 Offline OP
Samsmc1  Offline OP
Houston, Texas
I need help - I'm restoring a '55 A10 from a large pile of parts. Most of the sheet metal and hard to get stuff was there - I just had to figure out what was correct for the '55 model. I'm about 90% of the way there, but I'm jammed up on the rocker box. BSA appears to have used a number of different rocker box's on just the A10's excluding what they used on the A7's. All have numbers on the bottom, but they do not conform to the parts list.
I think the new valves in the head must be the correct length or I couldn't get any rocker box over them. Just to be on the safe side, can anyone tell me what the installed height of the valve or collar to head should be.
The box that works on a later aluminum head model will not go past the valve collars. This box is stamped 42-1142. I have a box stamped 67-260 that fits (barely) over the valve collars, but does not match up with the correct push rods. BSA says the correct part number for the box I need is 67-259. Can anyone tell me what number should be stamped on the bottom of the box correct for a '55 model iron head A10?
Sam
Re: 1955 A10 Golden Flash Rocker box. [Re: Samsmc1] #712706
10/25/17 9:02 pm
10/25/17 9:02 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
When I bought my '54 A10 it had an iron head, I later fitted a super rocket head-same rocker box, I then fitted a heavily modified A7 twin port head-again with the same rocker box.
The only difference was the length of the holding down studs
BSA B31 500cc "Stargazer"
Greeves 200cc "Blue Meanie"
Greeves 360 Challenger
Jawa 500cc "Llareggub"
'35 OK Supreme
'36 OK Supreme
Re: 1955 A10 Golden Flash Rocker box. [Re: Samsmc1] #712745
10/26/17 6:28 am
10/26/17 6:28 am
BSA_WM20 Offline
Happy Birthday BSA_WM20  Offline
Sam
Sam ,
part 67-259 is what happens when part number 67-260 is fully machined.
A part number is always stamped into a part.
Ant other number is the raw casting / forging before machining.
Generally the finished number will be 1 less so
67-260 + machining = 67-259
Re: 1955 A10 Golden Flash Rocker box. [Re: BSA_WM20] #712792
10/26/17 3:42 pm
10/26/17 3:42 pm
Houston, Texas
Samsmc1 Offline OP
Samsmc1  Offline OP
Houston, Texas
That makes sense. I wonder why I'm having so much trouble with the push rods now that I have a box that fits over the valves. I have the correct length push rods, yet they appear to be to short. I had the lifters ground by Megacycle, but they only removed a minor amount of metal - these pups are 3/16th too short.
Sam
Re: 1955 A10 Golden Flash Rocker box. [Re: Samsmc1] #712807
10/26/17 5:22 pm
10/26/17 5:22 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
There are only three alternatives for pushrod sets, Pre 1950 A7 (longs troke), post 1950 A7 and post 1950 A10
If yours are too short they may be A7
'35 OK Supreme
'36 OK Supreme
Re: 1955 A10 Golden Flash Rocker box. [Re: Samsmc1] #712809
10/26/17 5:46 pm
10/26/17 5:46 pm
Houston, Texas
Samsmc1 Offline OP
Samsmc1  Offline OP
Houston, Texas
I already measured them - they're just over 8 1/2 and 9 1/2 inches.
