DC
DC
197 registered members (1xfatboy), 2,144 guests, and 542 spiders.
Jerry Dahlinger, RoyalSpares.com, GabrielSoren, JoshP, spikey45
10079 Registered Users
koan58 85
NickL 84
Lannis 81
504,784 mail-order LSR
Topics66,041
Posts639,260
Members10,079
Bsa A65 kick lever removal. Help #712279
10/22/17 8:15 pm
10/22/17 8:15 pm
Milwaukee, Wisconsin
bezza Tim Offline OP
Pulling a frozen motor out of the bike. Kicker turns 360.
Any suggestion on how to get this off the spinal?
Thx
Re: Bsa A65 kick lever removal. Help [Re: bezza Tim] #712322
10/23/17 12:55 am
10/23/17 12:55 am
Fergus, Ontario, Canada
Dave T Offline
Dave T  Offline
The kickstart lever is not on a spline, it is located by means of a wedge pin. If you can turn it 360 deg, then that pin has been removed and you should be able to pull the lever off the shaft, it might need a bit of rocking.
You mention splines so are you maybe meaning the shift lever? That is located on a splined shaft. If so that is removed by removing the nut and bolts through split end of the lever and again the lever should just pull off with a bit of rocking. You might have to slightly open the slot on the end of the lever by means of a screwdriver or similar.
Re: Bsa A65 kick lever removal. Help [Re: Dave T] #712367
10/23/17 11:44 am
10/23/17 11:44 am
BSA_WM20 Online content
BSA_WM20  Online Content
It could be splines as there are a couple of bods doing splined kick starters for BSA singles at least ( hear they were not up to scratch ) .
Re: Bsa A65 kick lever removal. Help [Re: bezza Tim] #712373
10/23/17 12:15 pm
10/23/17 12:15 pm
gavin eisler Online content
gavin eisler  Online Content
I read "spinal" as badly spelt spindle. Sometimes the kick lever is trapped by a swollen shaft end, push the lever on as far as it will go and dress the shaft end with a file.. Should free up.
Re: Bsa A65 kick lever removal. Help [Re: bezza Tim] #712403
10/23/17 4:32 pm
10/23/17 4:32 pm
Canada
Alexp Online content
Alexp  Online Content
Canada
What Gavin said.
I had that exact problem of the shaft slightly mushrooming. Ten minutes with a file and it was good to go. You should not have to force the kickstarter on there. It should slide on with little to no resistance.
Alex
Re: Bsa A65 kick lever removal. Help [Re: bezza Tim] #712419
10/23/17 6:49 pm
10/23/17 6:49 pm
Yeah, me too. Saw this earlier, couldn't figure out spinal. I was gonna say push it back, grind, grease, maybe heat, both feet against the bike and TWIST.
Page Time: 0.062s Queries: 15 (0.006s) Memory: 1.0233 MB (Peak: 1.1872 MB) Zlib disabled. Server Time: 2018-02-24 00:23:12 UTC
