Kevin (NZ).
Kevin (NZ).
Christchurch, NZ
29 registered members (998John), 196 guests, and 443 spiders.
Mickeyrat, Gtommy, Stew Dempsey, JoeBrown, Bart223
10176 Registered Users
Lannis 105
reverb 90
Stuart 68
koan58 68
L.A.B. 54
555,042 mail-order LSR
Topics66,612
Posts645,585
Members10,175
4ca switched to 6ca #711380
10/12/17 11:03 pm
10/12/17 11:03 pm
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
I took my 4ca out and bought a 6ca points plate for my 1967 Tr6c ET ignition. I notice the 6ca is thicker which I assumed because I’ve seen deeper points cover for sale. But I also notice about a third of the points follower is off the aau cam. I can’t change that since I’m using the 4ca 5o ET aau. Is this ok ? I was told I could use the 6ca on the forum
Re: 4ca switched to 6ca [Re: Mori55] #711389
10/13/17 1:56 am
10/13/17 1:56 am
Costa Mesa/Mammoth Lakes, CA
Chris Johnson Offline
Sounds like something’s not right. You might see a small change in height because of the two points sub-plates... but there should be enough length to the points cam to accommodate.
Here’s a pic of my 6CA with ET AAU in my T100SC (same parts for all the critical stuff).
Chris
Re: 4ca switched to 6ca [Re: Mori55] #711408
10/13/17 11:23 am
10/13/17 11:23 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
Mines deffinetly pass the cam. If I can figure how to post a picture later I will.
I don’t see how mine should be different since I have the same equipment.
I see were your back set of points hang over a little , both of mine do that but a little more.
Maybe my points follower is a little wider.
Re: 4ca switched to 6ca [Re: Mori55] #711438
10/13/17 6:24 pm
10/13/17 6:24 pm
Christchurch NZ
R Moulding Online content
R Moulding  Online Content
Christchurch NZ
It would be worth looking into the reason the 4CA points and AAU were updated and replace your AAU to match.
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Page Time: 0.819s Queries: 15 (0.009s) Memory: 1.0045 MB (Peak: 1.1480 MB) Zlib disabled. Server Time: 2018-04-27 06:54:06 UTC
