Tim Lynch
Tim Lynch
Devon, UK
34 registered members (Bob E), 217 guests, and 473 spiders.
Trondgv, Jonathan Ytterli, hunterjim00, Gary J, SpeedTwin38
10329 Registered Users
Stuart 125
reverb 86
Lannis 61
657,506 mail-order LSR
Topics67,664
Posts657,308
Members10,329
Commando Idle #711098
10/10/17 2:12 pm
10/10/17 2:12 pm
just a guy from Jersey [Hopewe...
nert Offline OP
nert  Offline OP
I've looked in the owners manual, and service book. I could be missing it, but I don't see a recommended rpm for a 73' 850 Commando.
Any one know, or where is it stated?
thanks
Re: Commando Idle [Re: nert] #711104
10/10/17 3:28 pm
10/10/17 3:28 pm
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
There wasn't a factory recommended idle speed.
Re: Commando Idle [Re: L.A.B.] #711105
10/10/17 3:34 pm
10/10/17 3:34 pm
nert Offline OP
nert  Offline OP
What do you all set your Norton Commando "tick over speed", with twin carbs at??
Re: Commando Idle [Re: nert] #711107
10/10/17 3:52 pm
10/10/17 3:52 pm
New Zealand
johnm Offline
johnm  Offline
New Zealand
Right or wrong I have never set any of my bikes to idle.
I always set them so they cut out unless there is a little weight on the throttle.
You should never let a Commando idle on start up because it kills the camshaft.
And once it is running I always found it safer to keep my hand on the throttle keeping the bike alive and ready to get out of the way of the idiot behind me who wasn't stopping fast enough at the lights.
It's worked for 49 years :-)
Re: Commando Idle [Re: nert] #711108
10/10/17 3:57 pm
10/10/17 3:57 pm
Norfolk, UK
L.A.B. Offline
L.A.B.  Offline
Norfolk, UK
Approximately 1000 RPM, with the engine fully warmed up.
Re: Commando Idle [Re: nert] #711156
10/10/17 10:21 pm
10/10/17 10:21 pm
kommando Offline
kommando  Offline
Go with 1000 and ride it, if it keeps running then leave it, if it stops as you pull up to lights try 1100 but more likely you just need to find the idle mixture for best running.
Re: Commando Idle [Re: nert] #711212
10/11/17 4:55 pm
10/11/17 4:55 pm
belgium
ludwig Offline
ludwig  Offline
belgium
I set it at 1200 - 1300 rpm , but avoid idling if I can ..
Re: Commando Idle [Re: ludwig] #711216
10/11/17 5:08 pm
10/11/17 5:08 pm
nert Offline OP
nert  Offline OP
That is where mine is currently, 1200-1300. What is this taboo about idling? I have not heard that.
Re: Commando Idle [Re: nert] #711236
10/11/17 8:32 pm
10/11/17 8:32 pm
belgium
ludwig Offline
ludwig  Offline
belgium
It is generally accepted that ( lubrication of ) the camshaft is one of the weaker points in a Norton engine .
It does not like low rpm and prolonged idling ..
Re: Commando Idle [Re: nert] #712974
10/28/17 8:43 am
10/28/17 8:43 am
Wolverhampton, U.K
Simon Ratcliff Offline
Wolverhampton, U.K
As has been mentioned it's vital to generate sufficient oil pressure at all engine speeds hence the importance of correct calibration of the pressure relief valve. A good pump should produce approx. 20psi at idle with a hot engine. I know M Hemmings and others recommend shimming the valve so it rattles when shaken. This method tells you absolutely nothing about what pressure the valve opens at. Connecting a pressure gauge is the only way to establish prv opening pressure which should be between 45 and 55psi. engine hot.
Norton Mk3 Commando.
Re: Commando Idle [Re: nert] #713031
10/28/17 9:14 pm
10/28/17 9:14 pm
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
This flies in the face of those willy wavers who pride themselves in the slowest possible idle speed
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Commando Idle [Re: nert] #713064
10/29/17 11:08 am
10/29/17 11:08 am
Wolverhampton, U.K
Wolverhampton, U.K
Yeah, I agree. The priority is high enough engine idle speed to generate sufficient oil pressure. The cams will then get enough lubrication from the oil spraying out of the con rod journals in addition to oil draining down the pushrod tunnels. Obviously if the pump is struggling to generate sufficient pressure at tickover then the lubrication system needs looking at.
Re: Commando Idle [Re: nert] #713069
10/29/17 11:57 am
10/29/17 11:57 am
Bolton Lancs UK
Andy Higham Offline
Andy Higham  Offline
Bolton Lancs UK
Nowt worse than an ultra low idle. Pull clutch in, put in gear and the bugger stops
1962/67 Greeves 350
Moderated by  Dave Comeau
