Timmer
Timmer
Henderson
191 registered members (68 royalstar tony), 1,794 guests, and 512 spiders.
Jody Camak, analyse, Drifter, john harrison, David Stothard
10040 Registered Users
Lannis 149
kommando 117
Stuart 63
479,099 mail-order LSR
Topics65,751
Posts635,624
Members10,040
Intermittent oil return flow from 1968 Lightning.. #710942
10/09/17 1:05 am
10/09/17 1:05 am
Victoria, Australia
Gordon Smith Offline OP
Victoria, Australia
Hi all, scoured as many past threads as I could find and haven't come across a thread that answers my particular problem.
Did a fairly extensive rebuild, new primary side roller bearing, new timing side-bush and realign, rebore +060 pistons and rings, gearbox bearings , replaced all Oil seals, replaced oil pump with SRM piston type and SRM ORPV as well. Oil tank cleaned out and flushed with a cleaning agent, blown dry all good, seemingly. Oil sludge trap had been removed by previous owner( so didnt remove again).Replaced both oil hoses between oil tank and engine pipes( Correct way around too!!)
Did the oil pump test with hose and cordless driver attached and worm drive removed, got good flow through pump and but return flow back though into tank was very flaky and intermittent, yet through plastic hose into separate oil receptegal looked ok..
Boxed everything back up. got the bike running. Just got steady drips back into oil tank via the usual return pipe. Stopped and checked a few times, still no steady flow. drained sump in between and found approx. 1-2 litres still in the bottom of the engine each time and oil tank was empty . Last time same thing, revved the bike up a few times, to see if any better flow back into oil tank and suddenly engine oil pours out from under the bike near the rear chain case area, with oil tank empty once again. Gearbox oil still in tact and correct quantity.. I use 10-40 multi semi synthetic
Any thoughts from anyone please? could a broken timed breather or incorrectly installed breather be at fault ? Any other suggestions?
Thanks in anticipation
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #710962
10/09/17 7:29 am
10/09/17 7:29 am
The return side has double the capacity of the feedside so it's a mixture of air and oil. A check for you is to pour some oil into the rocker box and wait until it's drained into the sump. Then repeat your test and with the surplus oil in the sump the return flow will be all oil, then as the sump clears it will revert to a mixture of oil and air and be spurty.
As you have a buildup in the sump you need to check the non return ball is not sticking in the sump pick up, you don't have a magnet in the sump plate do you?
Ps save the semi synthetic oil for after the engine is run in, your rings will never seat with that oil. Use a high ZDDP Dino oil for first 1500 miles changed often.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #710965
10/09/17 8:03 am
10/09/17 8:03 am
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
If you were getting a good oil return to a separate receptacle but poor return to the tank, I would check for blockages in the return pipe or the return fitting and pipe inside the oil tank.
Have you fitted a return line oil filter? The oil should flow into the outer ring of holes and out of the centre threaded hole
1955 BSA B31 400cc "Stargazer"
1962/67 Greeves 350cc
1967 Greeves 360cc Challenger
Jawa 500cc grasstrack
Re: Intermittent oil return flow from 1968 Lightning.. [Re: kommando] #710967
10/09/17 9:19 am
10/09/17 9:19 am
Victoria, Australia
Victoria, Australia
Thanks Kommando, will try that suggestion on the weekend.
Yes I have a magnetic sump bolt fitted, I should eliminate that possibility I'm assuming. The ball valve is free to move and not stuck in the down position with plate removed
Good point about the oil, will hunt around for some mineral multi grade 10-40 or 20-50 ?
Andy
Have blown out and poked some wire through both sets of pipes in the oil tank, when I cleaned it out, pretty confident those lines are clear of blockages... I have blown some air back up the return pipe from the bottom of the sump plate area, might try that again to be sure.
No extra filters added any where on the bike
Thanks to both of you for your replies so far.
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #710972
10/09/17 11:40 am
10/09/17 11:40 am
It is a remote possibility but best eliminated for a test as it has been an issue before.
20/50 would be my preference, the tolerances and clearances on these engines are as they were in the 50's and 60's so thicker oil is preferable especially in hotter climates.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #710973
10/09/17 11:42 am
10/09/17 11:42 am
BSA_WM20 Online content
BSA_WM20  Online Content
And when ever the oil pump comes out, replace the ball & spring that sits behind it.
The spring is quite weak and is supposed to be replaced every 30,000 when ( i the day ) you pulled the bike down for a decoke & bottom end.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: kommando] #711039
10/09/17 9:02 pm
10/09/17 9:02 pm
Victoria, Australia
Victoria, Australia
Thanks Trevor, I did purchase one of each, so will install both those items..
Kommando, thanks for your tips
Re: Intermittent oil return flow from 1968 Lightning.. [Re: kommando] #711409
10/13/17 11:51 am
10/13/17 11:51 am
Victoria, Australia
Victoria, Australia
Kommando, no joy with adding the oil through the pushrod tunnel , still no flow back to oil tank nor changing the magnetic plug for standard vareity sump plug.
Any other thoughts at all please ?
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #711414
10/13/17 1:19 pm
10/13/17 1:19 pm
gavin eisler Online content
gavin eisler  Online Content
Replace the oil return line, another possibility is debris between the suction line and the pump inlet, or an air leak in the same section where the sump pickup meets the cases. its either part blocked on the inlet or the delivery from the return half of the pump.
Coincidentally there is another thread here with almost exactly the same ingredients and symptoms
http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=710058#Post710058
At work this kind of thing would happen a lot, Fitter A strips component and plugs drippy oil ways to prevent mess. Sometime later , weeks , days whatever, fitter B reassembles component, fails on test run, strip to find J cloth blocking oil ways, jamming valve/ blocking pump, blocking c/w flow.
Some holes attract insects, there is a chance that some creature is stuck in the oil return ways. My Cagiva fuel tank lid drain pipe gets blocked by flies which crawl into it. see Bee Gap, i cut and pasted this bit from a beekeepers site, applies to other flying insects as well.
We all "KNOW" that bee space is between 4.5 mm and 8 mm and it is also widely reported as being between 6 mm and 9 mm. However it is not a "variable" quantity, it is either 5.3 mm + or - 0.5 mm or it is 9.0 mm + 0.0 mm - 1.0 mm. In other words there are two distinct bands of possible bee space and these occur because in some situations the bees will work individually, but in other situations they need to be able to work back to back.
A gap of:- less than 4 mm... is too small for any but deformed worker bees to pass through. Any spaces, cracks or crevices of this or smaller dimension will be filled with propolis or sometimes a mixture of wax and propolis and on yet other occasions pollen may be mixed in with the filling (I suspect that this is for reasons of porosity or possibly the transmission of light, but I am not certain).
A gap of:- 4.3 mm is a standard European spacing for wires in a Queen Excluder.
A gap of:- 5 mm if used between the wires of a square mesh will make an excellent pollen stripper as the workers can get through, but a significant portion of pollen will be stripped from their legs.
A gap of:- 5.2 - 5.4 mm is a spacing that can be used to exclude or differentiate Drones, as Workers and Queens will freely pass, but Drones cannot.
A gap of:- 6 mm Is the smallest gap that bees will leave between adjacent comb surfaces (outside of the usual clustering area) the bees can defend this more easily and they can work individually within this dimension. The smaller gap around the periphery of the nest, also renders the nest less susceptible to draughts, and may help in maintaining humidity.
A gap of:- 7 mm not used by the bees themselves, but some people regard it as a valid bee space to use in some parts of beekeeping equipment. If this spacing occurs between the side faces of frame top bars they are the least likely to suffer from accretions of wax. Frames spaced at 35 mm pitch (normal Hoffman spacing) that have top bars 28 mm in width give rise to this 7 mm gap.
A gap of:- 8 mm is a popular bee space among those that design their own equipment as it falls midway between the 1/4" and 3/8" figures so often quoted in old books. I used to be keen on this dimension myself, but I have come to regard it as 'neither one thing or the other' and now I favour 9 mm or in some circumstances 6 mm.
A gap of:- 9 mm is the usual space the bees will leave between adjacent areas of capped brood. This allows two layers of bees to work back to back, usually in an oval pattern roughly in the centre of a frame.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #711425
10/13/17 3:04 pm
10/13/17 3:04 pm
All what Gavin said plus
You can get hose where the inner lining has come loose and the flap created blocks the flow when the oil is pressurised but not if you blow through the same pipe using your lungs. Normally happens with old pipe but worth a check.
Also did you fit a filter in the return line, these sometimes have a non return valve and if fitted the wrong way will block the return. Others have bypass valves and the pressure is set too high.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #711453
10/13/17 8:35 pm
10/13/17 8:35 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
This statement is very revealing and sounds like there may be a blockage in the return side to the tank.
I would check several areas as follows:-:
- ensure the twin pipe oil manifold is fitted correctly and that the return side manifold is not obscured by misalignment or misplaced a O ring.
- you might want to disassemble the oil pump and check for broken gears, debris etc. Be careful and ensure each gear goes back exactly the same way.
- Repeat the cordless drill test procedure, there should be no leaks from the pump body or gasket interface with the crankcases. Use Loctite 518 anerobic gasket sealant in the pump bottom and top plates, this will stop leaks and maintain pressure.
- Check the OPRV, hopefully you are using the later BSA piston type (or SRM version). I guess its possible that the OPRV is not releasing pressure and not dumping excess oil back to the crankcases/return oil line
Re: Intermittent oil return flow from 1968 Lightning.. [Re: gunner] #711686
10/16/17 12:31 am
10/16/17 12:31 am
Victoria, Australia
Victoria, Australia
Thanks Gunner
I will check the joint on the manifold to crankcase, the o ring may have moved, it is a very tight fit when the engine is in the frame
- The oil pump and OPRV are brand new items installed upon rebuilding after engine reconditioning.
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: gavin eisler] #711689
10/16/17 12:57 am
10/16/17 12:57 am
Victoria, Australia
Victoria, Australia
Kommando
I replaced hoses with new items, can check again.
No extra oil filters installed, just original in tank item
Regards Gordon
Gavin, thanks for your input, will take on board your thoughts and investigate further. I had seen that other thread and thought it very similar to my issue too!!!
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #711705
10/16/17 11:09 am
10/16/17 11:09 am
Insects in brit motors, see this Vid https://www.youtube.com/watch?v=iBPB96Yfs18&t=1949s FFWD to 21:30 ( wasp ), 23:10 (ladybird)
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #711758
10/17/17 1:09 am
10/17/17 1:09 am
Monclova
sloppyoil Online content
sloppyoil  Online Content
Monclova
Better check that hi dollar oil pump too.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: sloppyoil] #711769
10/17/17 3:02 am
10/17/17 3:02 am
Victoria, Australia
Victoria, Australia
Sloppyoil
Being a new item and pumping in one direction the correct way, I just assumed the scavenging should be the same too.
And your right it was expensive !!! When I get it off again, will check that as well...
Thanks for your thoughts
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #717045
11/29/17 12:05 am
11/29/17 12:05 am
Victoria, Australia
Victoria, Australia
Hi all, have dismantled again, back down to removal of oil pump, OPRV, oil tank, oil lines etc.
Dismantled oil pump, nothing amiss that I could see there. OPRV seems to work correctly as well. Oil flow test using attachment to hand held portable drill gives steady flow but not great pressure or high quantity of oil flowing back to tank. If you continue test , oil tank needs to to be topped up to keep level up to pump and return flow doesnt keep up with feed flow from tank to the pump.
during the test, at high revs from the attached drill, oil leeches out from around the timing side bush and flows back down to sump, I'm assuming this is normal?
One other item I thought a bit odd, the level in the oil reservoir attached to bottom pick up when using the portable drill doesn't drop that much when in use. When it is first started, oil is sucked up very quickly to the pipe in the sump, but after that the level doesn't drop that much when drill is rotating at fairly high revs ?
Possible damaged pick up pipe in sump area?
Running out of options/ideas?
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #717049
11/29/17 12:50 am
11/29/17 12:50 am
Check all oil ways with pipe cleaners and compressed air, Blow through and poke through all return passages from pump pick up to pipe union in tank, ( pump will need to come off to blow through all ports)check the oil manifold isnt dented, seems like something is restricting the return flow it should clear the sump and maintain tank level. If that doesnt fix it , then send the pump back.
Have you checked the pump / casing joint is truly flat, a light rub with studs removed and face cleaned and some engineers blue will tell all. Its very common to find the stud holes have a protruding lip, easy to fix with a light countersink, be sure the gasket isnt masking any of the ports , trim to suit .
Yes oil will ooze out of the TS bearing, most should go to the bigends but the bearing is not sealed.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: gavin eisler] #717197
11/30/17 10:16 am
11/30/17 10:16 am
Victoria, Australia
Victoria, Australia
Thanks Gavin, have air blown all the passages and they seem to be clear.Haven't checked the oil manifold for dents, I know its not loose though. I didnt check the stud holes for any protruding lips as yet. Gasket has been trimmed to suit all ports
if I have a sticking or galling OPRV ,could this affect return oil flow?
Gordon
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #717198
11/30/17 10:48 am
11/30/17 10:48 am
Cork Ireland
chaterlea25 Offline
chaterlea25  Offline
Cork Ireland
HI Gordon,
[quote=
Gordon[/quote]
No it should not affect return as the PRV is on the pressure side
Have you tried putting a length of clear plastic tubing on instead of the oil return rubber pipe and lead this up and into the filler neck
That would bypass anything that might be restricting the return lines
The only other thing that has not been really checked is the possibility of an air leak on the suction side of the pump
You would need to rig up a pressure (or vacuum) test, blocking the return pipe from the engine and apply air pressure to the pickup pipe in the sump ??
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #717199
11/30/17 10:51 am
11/30/17 10:51 am
There have been cases where the oil pipe has leaked in air where it is pressed into the crankcase on the OD. What you are describing would be explained by the leak being covered by oil initially so the return side pumps 100% oil and the level drops, then once the gap is exposed by the dropping oil level air is pulled in instead of oil and the effective capacity of the return side is reduced.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #717230
11/30/17 4:33 pm
11/30/17 4:33 pm
SoCal
Phil R Offline
Phil R  Offline
SoCal
Really quite a frustrating situation for you I'm sure Gordon.
Just a thought, would it be possible to fit up the original oil pump if you still have it and do the drill test with that pump on the bike as a comparison in performance to the SRM pump?
I recently lapped the bottom of a pump on a surface plate to make sure it was flat & guess what ....it jammed up solid when installed on the bike ! ('70 T Bolt) .
I then installed another pump of unknown pedigree and spun it with the drill which resulted in an indicated (on my gauge) 45psi, and yes oil oozed from around the timing side bearing as well.
Wish I could remember what the return side looked like but I don't recall noticing that the return seemed on the weak side as you have been experiencing.
Hang in there.....if you remain PERSISTANT you will PREVAIL !
Phil
Re: Intermittent oil return flow from 1968 Lightning.. [Re: Gordon Smith] #717248
11/30/17 6:16 pm
11/30/17 6:16 pm
Isle of Wight, UK
koan58 Online content
koan58  Online Content
Isle of Wight, UK
I have no BSA specific experience, however that in your original post you say that after brief running you then drain 1-2 litres from the sump beggars belief. I would expect an engine running with that in it not only to be pumping it out the breather, but putting up a smokescreen like the Bismark, and hardly able to run at all without busting its cases.
I imagine the feed side pump capability to be somewhere in the region of a pint/minute at say 3000 rpm, of course with a gear pump this is not as positive as some might like to suggest, and will be reduced by back pressure, viscosity reduction of oil as temperature rises, and precision of fit of gears in bores and side plates.
Your observations suggest that there is hardly any scavenging at all.
The feed side, assuming the new bigends and timingside bush to be as good as new, should be easily reaching a high pressure when cold so opening the OPRV, when the oil is hot, I would still expect say 50 psi at 3500 rpm.
Can you put a known good pressure gauge on it? I would want to be assured of this before running the engine further.
Doubt about the quality of the scavenge side would make me double check the much more important feed side.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: gavin eisler] #717436
12/01/17 11:35 pm
12/01/17 11:35 pm
Yes,
Had the tank off the M20 and left it uncovered overnight - bad move.
Following day reassembled and off we went,
All was fine for about 300 km then the bike would not rev past 1/4 throttle so it was a trailer entry to the All British for me ( first time ).
A quick check found the remains of a wasp firmly embedded in the banjo filter under the Concentric carb.
Re: Intermittent oil return flow from 1968 Lightning.. [Re: chaterlea25] #717451
12/02/17 11:03 am
12/02/17 11:03 am
Victoria, Australia
Victoria, Australia
Thanks John, no I havent tried that one as yet, at least that would eliminate or highlight an issue. I haven't got a pressure gauge fitted on this bike unfortunately. I would have to work out how to do the second option with a vacuum gauge
Kommando, I'm leaning toward something like that as well, but would need a complete strip down to get to the area concerned to check it out. Last resort case I'm thinking.
Phil, Havent got the old one in a working state unfortunately, as I damaged the original spindle trying to refit it. Worth consideration however if I run out of other options !!
Thanks for everyone's ideas, will work through as many of them as I can in the short term..
Gordon
