Timmer
Timmer
Henderson
191 registered members (68 royalstar tony), 1,794 guests, and 512 spiders.
Jody Camak, analyse, Drifter, john harrison, David Stothard
10040 Registered Users
Lannis 149
kommando 117
Stuart 63
479,099 mail-order LSR
Topics65,751
Posts635,624
Members10,040
A65 Stock Piston Weight #710872
10/08/17 1:30 pm
10/08/17 1:30 pm
USA
Thunderlizard Offline OP
USA
Hello, new guy here with a question, I am building a 68 Thunderbolt from boxes of parts and it did not include the original pistons. I am trying to find out the weight of one original standard bore piston
thanks
Randy
Re: A65 Stock Piston Weight [Re: Thunderlizard] #710986
10/09/17 1:24 pm
10/09/17 1:24 pm
Mississauga, Ontario.
Adam M. Online content
Adam M.  Online Content
You don't need this information, Taiwanese JCC pistons sold on eBay are very good with weight and quality of workmanship.
They are also cheap for $100.- a pair. You just need good rings for them.
Re: A65 Stock Piston Weight [Re: Adam M.] #710987
10/09/17 1:29 pm
10/09/17 1:29 pm
USA
USA
Thanks Adam, I already have a pair, I want to know the difference between the weight of them and the originals
Re: A65 Stock Piston Weight [Re: Thunderlizard] #711020
10/09/17 6:34 pm
10/09/17 6:34 pm
A lot of us out here would be glad to give you that info, but got no way to get an accurate weight.
Re: A65 Stock Piston Weight [Re: Thunderlizard] #711064
10/10/17 3:03 am
10/10/17 3:03 am
Mark Z Online content
Mark Z  Online Content
I have an original standard piston from a '67 Lightning. I will find it and weigh it, but too late tonight; will have to be tomorrow.
Re: A65 Stock Piston Weight [Re: Thunderlizard] #711094
10/10/17 12:42 pm
10/10/17 12:42 pm
Mark Parker Offline
Mark Parker  Offline
The std pistons are lighter than most, and early ones are different again. Sorry I don't have the weight of a std piston, but what looks like a + .020" JCC 397g a + .030" Hepolite 420g .040" 425g both latter style 9-1. MC 10-1 402g all with pins. Different brands can be different weights. Generally with cast pistons, the bigger the heavier because they are thicker in the skirt. Forged B44 80mm are around 372g with pin, 79.5mm Omega cast are about the same. T140 are 340g with pin.
Re: A65 Stock Piston Weight [Re: Thunderlizard] #711169
10/11/17 12:10 am
10/11/17 12:10 am
I didn't find the '67 L pistons, but I did find a pair of OE pistons from a '65 Lightning Rocket. I can't say for sure if they would have used the same pistons in '66, but it would seem likely. They appear to be 9:1 CR. I'll include the markings on the pistons if that helps anyone.
Piston 1: On the crown, 68-892 BSA/T, and 46/4/67 L. Next to the pin, 68-743 and AM, other side, LO-EX and L66. Weight without rings and gudgeon pin is 9.9 oz or 281 grams.
Piston 2: On the crown, 68-892 BSA/T, and 46/9/67 H. Next to the pin, 68-743 and AM, other side, LO-EX and M66. Weight without rings and gudgeon pin is 10.1 oz, or 286 grams.
Re: A65 Stock Piston Weight [Re: Thunderlizard] #711170
10/11/17 12:25 am
10/11/17 12:25 am
One other note: I had done this comparison a while ago, and left a note in the box. But that time I measured WITH rings and gudgeon pin.
Standard OE piston from '65 LR: 13.7 oz, or 389 grams.
EMGO Taiwanese +.040 piston: 15.1 oz, or 429 grams.
That's a pretty significant difference I would say...
Re: A65 Stock Piston Weight [Re: Thunderlizard] #711175
10/11/17 1:28 am
10/11/17 1:28 am
USA
USA
Wow, thanks everyone, that's a bunch to digest.
Randy
