james johnson
james johnson
california
220 registered members (21inGoldie), 2,354 guests, and 559 spiders.
10071 Registered Users
Lannis 83
koan58 83
NickL 76
502,324 mail-order LSR
Topics66,008
Posts638,850
Members10,071
Bicycle instruments #710367
10/03/17 4:07 am
10/03/17 4:07 am
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
I had someone ask about wanting a small speedometer and tachometer for a project bike. The speedometer part was easy, a bicycle unit (Sigma makes one with a back light). The tachometer took some thinking.
An engine turning 1000 RPM makes one revolution every 0.06 seconds.
At 10 MPH a vehicle travels 8.8 feet/second.
If a wheel of 8.8 feet in circumference turned one revolution in one second a bicycle speedometer would read 10 (MPH). But if the speedometer was calibrated so each pulse from the wheel was in 0.6 seconds to read 10 MPH the pulses from the crank could be divided by ten to read RPM. So back calculating, the wheel would be 8.8 * 0.6 / PI * 12 = 20.168 inches (512.27 mm) diameter or 1609 mm circumference. Most bicycle speedometers can be set for wheel circumference.
So, putting in 1609 as the calibration, a magnetic pickup on the crank to measure each revolution, a divide by 10 counter to feed the speedometer, it can be used as a tachometer reading hundreds of RPM.
A wired speedometer would be preferred. The crank pickup could be set near the generator rotor which would need an additional divide by 3 or 6 depending upon the pickup and amplifier. Using the engine sprocket teeth would need a divide by 28 which is not as convenient.
Sigma makes a motorcycle version with three digit output for those turning over 9,900 RPM.
Re: Bicycle instruments [Re: DMadigan] #710382
10/03/17 11:44 am
10/03/17 11:44 am
UK Berks
AngloBike Online content
AngloBike  Online Content
UK Berks
Doesn't running the speedo off the engine mean that revving the bike while stationary means you get a reading and the gears do nothing?
Surely you need pickup from a wheel or gearbox output?
Measuring rpm could be via emf pulses from the HT
Re: Bicycle instruments [Re: DMadigan] #710384
10/03/17 11:57 am
10/03/17 11:57 am
I read the post as the speedo acting as speedo is run off the front wheel, its the speedo acting as tacho is run off the engine.
Re: Bicycle instruments [Re: DMadigan] #710386
10/03/17 12:12 pm
10/03/17 12:12 pm
Jordan, NY
Al Eckstadt Online content
Al Eckstadt  Online Content
Jordan, NY
There are a number of small speedos with tachs built-in. But I am thinking of using one of these - small engine hourmeter/tachometer - hourmeter/tach on amazon.
Weatherproof and digital readout should help with stuff like tuning carbs. It's not backlit but then it only needs one small wire coil around an ignition cable.
Al Eckstadt
Re: Bicycle instruments [Re: DMadigan] #710399
10/03/17 3:16 pm
10/03/17 3:16 pm
Running from demons in WNY
Hillbilly bike Online content
I tried one of those small engine tachs similar to shown above for the race bike. It was just for tuning purposes... The reading lagged behind actual engine RPM and was never stable...That was my experience, yours may differ....
Re: Bicycle instruments [Re: DMadigan] #710403
10/03/17 3:26 pm
10/03/17 3:26 pm
Jordan, NY
Jordan, NY
Thanks Tony. I'll investigate further before using.
Al Eckstadt
Re: Bicycle instruments [Re: DMadigan] #710758
10/07/17 2:50 am
10/07/17 2:50 am
Mark Z Online content
Mark Z  Online Content
I had a Sigma bicycle speedometer on my BSA for a while. The problem I experienced is that the sensor (which is actually a magnetic switch and not a pickup as in the sense of a coil, and therefore has a moving part) cannot stand up to the frequency of switching at 60-70 mph for very long. I went through two of them, each one lasting a couple of months.
Re: Bicycle instruments [Re: NickL] #710787
10/07/17 1:19 pm
10/07/17 1:19 pm
Nice info Nick, but most guys here have trouble wiring a tail light wink grin
Re: Bicycle instruments [Re: Hillbilly bike] #710791
10/07/17 2:21 pm
10/07/17 2:21 pm
I use this sort of thing.
http://www.eBay.co.uk/itm/Digital-E...4?hash=item41cd394f94:g:lgsAAOSw8DNZlxRo
It does get erratic. You have to experiment with numbers of turns of wire and mess about like that. I don't race, so it doesn't matter so much.
These GPS speedos are amazing (to me).
https://www.eBay.co.uk/i/1525967616...428-41853-0%2526rvr_id%253D1329369971191
I've got a similar one on the bike and it does work. Hope it keeps working!
Re: Bicycle instruments [Re: DMadigan] #710797
10/07/17 4:10 pm
10/07/17 4:10 pm
ca, us
DMadigan Offline OP
DMadigan  Offline OP
ca, us
Mark, you should use a solid state Hall effect switch. They are not affected by the vibration or switching speed.
A digital tachometer is not much use on the road. It cannot be read easily in your peripheral vision. I bought some stepper motors GM uses for their instruments to play with. Debating whether to make original style instruments or a small all-in-one analogue tachometer with digital speedometer, shift light, multi-colour oil light, beam(?) and two line digital readout for miles/trip/time, maybe a turn light too. Just the essentials.
$miths already makes original style instruments so other than for my own use, not much need there. Back in the day, racers used Krober tachometers which have a 90 degree movement. Of course, no need to start from zero as that is pretty useless. If you have seen the recent Kenny Roberts video of him riding the TZ around a track, the tachometer starts somewhere around 6K RPM.
Re: Bicycle instruments [Re: DMadigan] #710800
10/07/17 4:36 pm
10/07/17 4:36 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
I use a Scitsu tacho on my Greeves, it is rechargable and just has a sensing wire cable tied to the HT lead.
An unexpected advantage I found was when I was experiencing a misfire due to fuelling issues, the tacho was dropping back to zero indicating a low HT voltage=fouled / shorted plug=very rich
http://www.scitsu.com
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: Bicycle instruments [Re: DMadigan] #710802
10/07/17 4:41 pm
10/07/17 4:41 pm
Yes, I only posted that because someone mentioned Sigma bicycle meters, and I was messing with them because they're cheaper than dirt.
My next attempt at a gauge was an electronic tachometer from Speedhut. This works great when it works, but it keeps failing. It has a lifetime warrantee, so I keep sending it back for repair, but I'm about ready to write it off and go for a GPS speedometer.
The Smiths electronic gauges are a little too pricey for me and my bitsa.
Page Time: 0.599s Queries: 15 (0.020s) Memory: 1.0849 MB (Peak: 1.2956 MB) Zlib disabled. Server Time: 2018-02-19 21:38:04 UTC
