james johnson
james johnson
california
220 registered members (21inGoldie), 2,354 guests, and 559 spiders.
10071 Registered Users
Lannis 83
koan58 83
NickL 76
502,324 mail-order LSR
Topics66,008
Posts638,850
Members10,071
Amal premier - and what have we here!!! #710476
10/04/17 7:32 am
10/04/17 7:32 am
Geneva, Switzerland
BrettF Offline OP
BrettF  Offline OP
Geneva, Switzerland
Hi Folks,
Fooling around with some new premier carbs on my 71 T120 I tried the old AMAL idea of using an old drain plug with a tube fixed into it to measure in situ float height. Made a nice new tool but was sadly not successful. Firstly the carbs are not level (something I had looked at 1000 times but never registered before) which made accurate reading very difficult. The heights I obtained were clearly not correct , one was 10 mm too low the other 5 mm too high despite having checked the float height from top rim previously so I know I was in the ballpark (and both plugs looked identical from previous checks). Something is messing up the readings, a constriction somewhere or something like that. Anyway thats for another day.
After finding lots of aluminium bits in the drain when taking the above measurements of my almost (200km) brand new carbs, I've found a few posts that indicate also finding loads of chaff in them. I did inspect and blow the carbs out with air when I purchased them a year or so ago so I did not expect this.
Made me think that maybe this is from new wear? So i had a good look at the hard anodised slides and the carb body and it seems to have a lot of wear for 200 km.
I've never been fortunate enough to buy a carbed vehicle from new so have no idea whats normal (and with a new vehicle one would probably never look at the carbs for the first few thousand KM anyway) but I was a bit surprised by what I saw.
What do you folks think - normal?
Here is a picture of the chaff that came out of left carb (right was the same).
Slide wear
Carb body wear
I was very carefully to install the Carbs correctly - no over tightening of the flanges and lid - running standard air filters so should not get much grit, etc.
Finally there were some strange machining/scratching marks that seemed to close of the outer pilot exit hole slightly. Admitted I measured it very roughly by prodding gently with the smooth sides of minature drill bits. Here you can see it after the prodding - the chaff fell away while doing this - the hole is now the same as on my other three carbs. Borth carbs showed such markings in this area.
BMF
Bikes:
69 T120 on average (1967 rolling frame and 1971 Bonnie engine)
57 T110 on average (58 rolling frame - with 55 iron head engine)
Re: Amal premier - what have we here!! [Re: BrettF] #710479
10/04/17 7:47 am
10/04/17 7:47 am
Pleasant Hill, California USA
TR7RVMan Offline
TR7RVMan  Offline
Hi Brett, Interesting. I bought my bike new, but didn't have occasion to take carb apart until 9800 miles. Had a fair amount of slide wear, but doesn't seem to effect operation. Bike now has 22k miles on original slide & still working good.
I've had a lot of carbs apart & the wear pattern starting is what I've seen on my & other carbs. Again many more miles on those carbs.
I've personally had 2 sets of new Premiers with metal flash in the idle passage. I don't recall seeing metal bits in float bowls.
One of the new Premiers had a stubborn chip in idle passage. Finally was able to blow it out. I saw the spec fly out the rear air passage. Has been good since then.
Are there any metal chips that are magnetic?
I know for sure not running air filters wears carbs quite bad. However I don't know that metal gets into float bowl from slide wear.
Are you running air filters?
Regarding the level gauge you made, I did that as well. My Tiger 750 carb sits level. The gauge worked to a degree, but if I started motor vibration shook gas in tube so bad reading was useless. I gave up on it & just set floats by measurement from gasket surface of bowl.
Re: Amal premier - what have we here!! [Re: BrettF] #710484
10/04/17 9:47 am
10/04/17 9:47 am
Naarfuk, UK
Tigernuts Online content
Tigernuts  Online Content
Naarfuk, UK
The new Premier carb I bought for my TR7 came with the pilot jet part-blocked by drilling swarf (I didn't find this for a few hundred miles of wondering why it ran so badly at low throttle). The float level was also set way too low (again, not discovered until I took the carb apart after a few hundred miles of struggling to get it running anywhere near right). I made the mistake of assuming that a brand new carb bought direct from the manufacturer would have been checked before dispatch. It seems Burlen have a serious quality control problem. They need to sort it for thier own good, or their products will acquire a bad reputation.
Some of the pics inside the body look more like polishing of high spots than real wear. I see you have standard air filters, which are pretty efficient when working properly, so there really shouldn't have been any abrasive particles getting in during such a short period.
As for float level setting, I also gave up messing around with tubes to see the petrol level. For one thing, the meniscus in the tube accounts for a couple of mm and for another thing, it's so much easier to set it by looking at the float in relation to the top of the bowl.
Re: Amal premier - what have we here!! [Re: BrettF] #710584
10/05/17 10:32 am
10/05/17 10:32 am
Geneva, Switzerland
BrettF Offline OP
BrettF  Offline OP
Geneva, Switzerland
Hi Don, yes running standard air filters, and inline fuel filters also so I'm sure it's not from the tank. I have not made any change to the tank, and had no such particles in the Bowls before.
Bikes:
Page Time: 0.810s Queries: 15 (0.026s) Memory: 1.0158 MB (Peak: 1.1490 MB) Zlib disabled. Server Time: 2018-02-19 21:44:06 UTC
