Timmer
Timmer
Henderson
191 registered members (68 royalstar tony), 1,794 guests, and 512 spiders.
Jody Camak, analyse, Drifter, john harrison, David Stothard
10040 Registered Users
Lannis 149
kommando 117
Stuart 63
479,099 mail-order LSR
Topics65,751
Posts635,624
Members10,040
Bsa A65 lightning #710491
10/04/17 11:33 am
10/04/17 11:33 am
Waiheke Island New Zealand
Grant Offline OP
New poster
Grant  Offline OP
New poster
Hi recently purchased a A65 lightning in Australia have shipped it to New Zealand.
Informed it is US model imported into Aus Old Aus registration. Has it as 1966 model engine nos have engine as August 1970 frame no has prefix A65 J got me scratching my head will post some photos next couple of days
Have just started her after 5 years not been run have a multitude of tasks to do
have put new tyres on had her on the street for a 50 mile ride running boysen with 6 volt coils no ignition switch or Zener diode wiring was a mess sorting through it slowly battery does not seem to be charging have had intermittent missing put it down to low voltage and dodgy earth on coil charged up battery have tuned and running a lot better have changed all fluids reset valve clearance have not touched timing will be factoring in a complete engine tear down at some stage as funds permit any knowledge on the no ignition switch or Zener diode or dating of machine would be much appreciated
Re: Bsa A65 lightning [Re: Grant] #710494
10/04/17 12:19 pm
10/04/17 12:19 pm
Stuart Online content
Stuart  Online Content
Hi Grant,
Firstly, welcome to the Forum. bigt
Secondly, I had to read your post several times to get even a rough idea of what you're trying to say; any chance you could use some punctuation in later posts? smile
I've got: you've bought an A65 in Oz and shipped it to NZ; the Oz registration has it as a '66 but the engine number is '70; the bike hasn't run in 5 years; the electrics have a Boyer-Bransden (? afaik, "boysen" used to be a make of reed valve for two-smokes) electronic ignition but don't have an ignition switch or Zener diode and the battery doesn't seem to be charging? Correct?
Originally Posted by Grant
any knowledge on
dating of machine
What are the engine and frame numbers?
What model of A65? If the bike apart from the engine is a '66, BSA produced some with 6V electrics originally. These can be upgraded to 12V relatively easily but whoever does it does have to know what they're doing.
What sort of "ignition switch" are you expecting? BSA didn't fit proper multi-combination key switches 'til '68; '66 has two rotary switches - ignition and lighting; the "ignition" one should have a small slot in the top for a flat, spade-shaped 'key'. Or a screwdriver ...
6V bikes didn't have a Zener diode. But where have you looked for the Zener diode on your bike?
One reason the battery might not be charging is it's donald ... because you went for a 50-mile ride without a Zener diode ...
Re: Bsa A65 lightning [Re: Grant] #710553
10/05/17 1:26 am
10/05/17 1:26 am
Mark Z Online content
Mark Z  Online Content
Stuart, I thought BSA went 12V in 1965.
A50 and A65 frame numbers were all A50... until 1966. I cannot find/have never seen A65J though. Any chance that's a "T"?
No ignition switch? How do you kill the engine?
Yes, if 12V system, no zener diode will cook the battery in short order. Light bulbs won't last long either.
Re: Bsa A65 lightning [Re: Mark Z] #710580
10/05/17 8:25 am
10/05/17 8:25 am
Hi Mark,
Haven't come across any BSA or Triumph built before '66 with original 12V electrics; all 6V or conversions. Have come across a couple of '66 Thunderbolts with 6V electrics.
'66 12V bikes I've come across still had the same 88SA rotary switches as '62-on 6V bikes, so the Ignition switch has the "Off" position. I think the 'key' in it was supposed to stop the switch knob being turned, but I've never seen the absence of one that did ...
Can depend how any 12V 'conversion' has been done. Can't remember if it was here or TriumphRat but there was one not very long ago where the old 6V regulation connections from the alternator to the Ignition and Lighting switches hadn't been disconnected so, despite a Zener having been fitted, the alternator output was still being depressed depending on the switch connections ... facepalm Giveaway was the ammeter showed a greater charge with the lights on than with 'em off. grin
