SBoyd
SBoyd
Virginia, USA
43 registered members (Alan_nc), 251 guests, and 396 spiders.
Bruce1947, Robert mickey, Geofft, WJS, Trondgv
10333 Registered Users
Stuart 129
reverb 69
DavidP 64
660,220 mail-order LSR
Topics67,703
Posts657,731
Members10,333
A65T wet sumping while running #710058
09/30/17 2:06 pm
09/30/17 2:06 pm
BSA_WM20 Offline OP
BSA_WM20  Offline OP
On the subject of oil.
Got a weird one here & I am out of ideas.
Newly rebuilt engine, everything replaced.
New SRM oil pump new SRM OPRV.
Starting with a dry sump, the crankcase fills with oil after around 10 minutes of running.
The entire time the oil pump is returning oil to the tank, a strong but continious stream of oil ( no air bubbles )
Tried refiting the original sump in case the magnet was holding the ball in the scavenge pipe down the bottom of the tube.
Checked the return line in clear, checked the oil lines were correctly fitted.
Pressure tested , with air , both the input & return drillings in the crank case for mounting bolt holes intersecting the oil drillings. \
Blocked off the return pipes and presurised the return oil galleys & it held pressure.
One of the few things I have never had reason to pull apart is an A65 oil pump, but by the looks of the parts book you can not transpose the input & return gears on a std pump.
Is this possible with the SRM High volume pump ?
And any other ideas ?
Owner is about to strip the the engine again and pull the crank but I can not see how a problem with the crank or timing bush could cause a built up of oil in the sump.
Re: A65T wet sumping while running [Re: BSA_WM20] #710060
09/30/17 2:30 pm
09/30/17 2:30 pm
Iowa
konon Offline
konon  Offline
Iowa
Is the OPRV stuck open , dumping oil into sump ?
1968 BSA Firebird
1200 HD
XS 1100
1972 Rickman 125
Re: A65T wet sumping while running [Re: BSA_WM20] #710062
09/30/17 2:48 pm
09/30/17 2:48 pm
kommando Offline
kommando  Offline
As there is no air in the return its saying the return is not normal, there should be air as the scavenge has a higher capacity than the feed, that's assuming the SRM is the same as the std BSA of course. Is there an oil filter in the return line, they can have oil pressure valves in them that restrict flow in case of the filter becoming blocked, should not be operating as there is no restriction in the return other than the filter but stranger things have happened and this maybe the reason SRM are anti return line filters.
Re: A65T wet sumping while running [Re: kommando] #710084
09/30/17 5:57 pm
09/30/17 5:57 pm
Cork Ireland
chaterlea25 Online content
chaterlea25  Online Content
Cork Ireland
Hi All,
As the oil is accumulating in the sump there will be no air in the return, air in the return oil happens when the sump is "emptied"
Even if the OPRV was stuck open the return side should be able to clear the sump
If the OPRV was stuck shut excess pressure could cause problems as below
Has the ball and spring behind the pump been assembled with the ball against the pump as it should be?
I would check the pump gasket face on the crankcase to make sure the pump is sitting flat against the case /gasket
If the pump gasket leaked across from feed to return or into the case I could imagine the scenario happening
The usual gaskets supplied with gasket sets are poor in my opinion, but I thought SRM supplied a "proper" gasket with the pumps nowadays
After that I can only suggest trying another pump, is the old one serviceable?
Re: A65T wet sumping while running [Re: BSA_WM20] #710100
09/30/17 9:18 pm
09/30/17 9:18 pm
gavin eisler Offline
You cannot transpose the gears, the SRM is a better made copy of the late pumps,, possibly the the scavenge suction line is drawing air,The return should dry out the sump in a few seconds, solid oil to begin with , then spurts with air if its done its job.
The pump mount face , as kpmmando mentioned, is a possible culprit,. Although your pressure test suggest it is tight I would check that first. The SS OPRVs have been known to stick/gall,
Re: A65T wet sumping while running [Re: gavin eisler] #710134
10/01/17 9:58 am
10/01/17 9:58 am
BSA_WM20 Offline OP
BSA_WM20  Offline OP
Thanks Gavin,
That excludes one possibility that I had no idea about at all
The cases were machined flat at an avaition workshop so there is no chance of warping and this bloke does his side cover nuts up with a tension wrench.
The gasket came off clean with no signs of channeling between it and the pump,
The internal oil passages have been checked and found sound and the OPRV had been checked again wih no problems found.
The scavenge side just can not keep up with the delivery side so a backwards pump was the last shot in the dark.
We are busy now preping for the BSA National in October so it will now have to wait till November
Re: A65T wet sumping while running [Re: BSA_WM20] #710137
10/01/17 11:42 am
10/01/17 11:42 am
Hi Trevor, there have been instances of the pump suction line drawing air where the sump to case leg fits in, i.e the bit with the suction side NRV inside the sump plate, this can be tested with the sump plate removed, first check the suction leg is firm in the cases , any waggle is a possible air leak. A section of hose is fitted over the end and allowed to dip into a small reservoir of oil, this should only be a few inches long, start the motor , the oil should be lifted easily. This can also be leak tested by applying air pressure, leaks will be obvious as hissing from the leg to case join.
Another possible leak point is the OPRV casing threads, these are slack on many A65s , I assemble this with a dot of pipe sealer applied to the casing threads inner section , so that the HP side is correctly sealed from the dump side, this prevents bleed through.
Re: A65T wet sumping while running [Re: gavin eisler] #710195
10/01/17 9:22 pm
10/01/17 9:22 pm
Cork Ireland
Cork Ireland
HI All,
If the suction tube was admitting air would not there be air in the oil return?
Trevor says there is constant return flow to the tank ??
Again leakage at the PRV should not make any difference to the return as the return pump has greater capacity than the feed
Re: A65T wet sumping while running [Re: chaterlea25] #710201
10/01/17 10:35 pm
10/01/17 10:35 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
the return side of the pump can only possibly pump oil that reaches the sump.
it cannot pump oil thats being flung and re-flung by the crankshaft.
if the pump volume is excessive or delivered incorrectly
an inordinance amount is keep in suspension
and does not make its way to the sump in the ordinary fashion.
so there's this layer of unwanted oily activity
happening above any normal sump pumping
Re: A65T wet sumping while running [Re: BSA_WM20] #710259
10/02/17 11:15 am
10/02/17 11:15 am
Hi Chaterlea.
"If the suction tube was admitting air would not there be air in the oil return?
Again leakage at the PRV should not make any difference to the return as the return pump has greater capacity than the feed"
Thats what you would think, however this fault has occurred before with similar symptoms and a badly fitted / leaking suction leg was the culprit.
If the suction leg has an air leak , the scavenge side will not pump until the leak is covered by oil, by then the sump is full and oil is getting chucked out the breather, at least thats my take on it.
Re: A65T wet sumping while running [Re: quinten] #710260
10/02/17 11:23 am
10/02/17 11:23 am
BSA_WM20 Offline OP
BSA_WM20  Offline OP
Quinten,
I was originally thinking along those lines.
Back in my teen years when we "knew more" than the BSA engineers, crimping the return stand pipe to direct the "right" amount oil to the head was not an umcommon "improvement".
I am about to get him to try running an external return line just to double check that is not the case but it really seems that the return side is under capacity.
Reluctant that I am to do it we might even pull down the new pump to see if there is something funny going on.
Thanks for all who have taken the time to respond but we have covered all of those bases already. Just thought there might be something was not aware of as the last time I ran an A65 was back in 92 but even then I was runnigng a B40 & B50 so things can get lost or mixed up in time, particularly in my thick head.
Re: A65T wet sumping while running [Re: BSA_WM20] #710274
10/02/17 2:31 pm
10/02/17 2:31 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
"Newly rebuilt" - Perchance you forgot the split pin on the top end feed? That would make oil return to the sump from the return line. Leave the valve cover off and run it momentarily. If excessive oil is squirting out at the pushrods then that could be the problem.
What year engine case? The early engines had the OPRV dump into the case directly. Later cases went into the return drilling and the ball the the pickup tube keeps it from flowing back into the sump.
Re: A65T wet sumping while running [Re: BSA_WM20] #710388
10/03/17 12:26 pm
10/03/17 12:26 pm
BSA_WM20 Offline OP
BSA_WM20  Offline OP
Split pin is in.
I always though it was just there to deflect to oil and prevent it squirting directly back down the pushrod tunnel.
Not sure of the case numbers, not my bike & it is 30 miles away.
I am just the Agony Aunt for every one with problems they can not understand.
Re: A65T wet sumping while running [Re: BSA_WM20] #711135
10/10/17 8:26 pm
10/10/17 8:26 pm
Southampton UK
Peter Gascoigne Offline
Southampton UK
Trevor,
I had exactly the same problem with my T150 Trident, so I did this.
We removed the sump plate and gauze filter. There is a rubber pipe on the oil pump pick-up extending it into the ice cream tub, so that we could see what was happening to the oil level. Start the bike up, the oil reaches the bottom of the tube, and the oil level never moved from that level no matter what the engine speed. I was surprised how little oil was circulating, I thought we might have a problem seeing where the oil level was, but no matter what revs, it just trickled into the tub and was returned to the tank, still with no air visible in the oil!
1971 BSA A65 Lightning "Bitsa"
1966 BSA A65 "Beezuki" with GT550 two-stroke engine
1974 Triumph T150 830cc
1975 Suzuki GT550
1975 Laverda 1000 3C
1986 Yamaha SRX 600
Re: A65T wet sumping while running [Re: BSA_WM20] #711161
10/10/17 11:14 pm
10/10/17 11:14 pm
Long shot, is the oil tank breather blocked?
Another long shot, is the return line / pipe OK , sometimes the steel stub can gouge out a flap which will impede the return flow.
Seems like its got to be somewhere in the return plumbing, if its not drawing air at the suction leg it may be part blocked somewhere, either between suction inlet and pump or between pump and tank. A scrap of cloth or whatever between suction leg and pump return inlet , this wouldnt show up in a pressure test. To prove this leg is clear you would need to blow through from bottom entry with the pump off, bit of a headache.
Re: A65T wet sumping while running [Re: gavin eisler] #713197
10/30/17 1:11 pm
10/30/17 1:11 pm
BSA_WM20 Offline OP
BSA_WM20  Offline OP
Covered that one by running with the cap removed.
Pete brought the cases & pump around the other day and we could see nothing wrong, no obstructions and the pump, at low speeds off a drill pumped about double the oil from the return than it did from the supply.
Did notice a nice moon in the gasket over the return hole where tha gasket had dropped so he has put a new one on, positioned with some spray on Hylomar so it won't slip down during fitting.
Will keep you posted about how it goes as the bike is not yet back together.
Re: A65T wet sumping while running [Re: BSA_WM20] #713324
10/31/17 9:25 am
10/31/17 9:25 am
BSA_WM20 Offline OP
BSA_WM20  Offline OP
Be fine for this owner who only drinks "barista made coffee"
Re: A65T wet sumping while running [Re: BSA_WM20] #713326
10/31/17 10:12 am
10/31/17 10:12 am
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
Let's think about this in a logical way.
The return side of the oil pump is twice the capacity of the feed side, if all is well there should be air bubbles in the oil return to the tank because the return is pumping all the oil out of the crankcases and drawing air in.
Some of the return oil is diverted to the rocker box which then drains back to the crankcase.
The OPRV is after the feed side of the pump and returns oil to the crankcase or directly to the return side of the pump. Therefore open or closed there is always the same amount of oil flowing through the feed side of the pump.
To fill the sump either
1) The return side of the pump is not pumping to it's full capacity
or
2) Return oil is returning to the crankcase instead of the tank
Possible reasons for 1) are air leak between pick up and pump (but there would be bubbles), partial blockage between pickup and pump, partial blockage between pump and tank, leaking pump gasket
Possible reasons for 2) are unrestricted oil flow to rockers, damaged internal oilway, leaking pump gasket
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: A65T wet sumping while running [Re: BSA_WM20] #713518
11/01/17 11:09 pm
11/01/17 11:09 pm
BSA_WM20 Offline OP
BSA_WM20  Offline OP
We should have measured the actual volumes of oil each side of the pump was moving but spinning the pump with the input side in oil, the outlet on the return side was definitely shifting considerably more oil than the feed side.
Tried pinching off the rocker feed in case too much was doing the closed loop sump -head- sump no difference.
That was an early thought as in my youth when at 17 we knew more than the BSA engineers it was a common "fix" to partially block off the return line to force more oil to the head.
The bike is going back together with the gasket fixed into the right place as the only problem I could see was the slipped gasket partially blocking off the return hole in the pump.
It is a bit of a long shot as I can not see that sort of restriction making such a big difference but we will see.
Pete is busy now but it should be back together in a week or two .
Unless there was a major leak at the manifold / crankcase joint, all other lines were pressure tested and found to be sound.
Some times one can miss sonthing staring you in the face which is why I posted.
The last time I pulled down an A65 oil pump, I had thick long brown hair and a full set of teeth
Re: A65T wet sumping while running [Re: BSA_WM20] #713532
11/02/17 12:41 am
11/02/17 12:41 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Early oil drilling cases had the OPRV drain into the sump, late cases return to the drilling between the pickup tube (with ball check valve) and the pump. You can tell the difference from the outside by the shape of the case between the OPRV and the vertical drilling extension below the oil pump. If the case comes out to the surface of the OPRV seat then it is a late drilling case.
Either way the return side should be pumping more than the feed and you should see air bubbles in the return. Have you put an oil pressure gauge on it?
Gear pumps are positive displacement so the gasket would have increased the pressure upstream but not appreciably changed the flow unless the pump has a lot of clearance either axial or radial to the gears.
Re: A65T wet sumping while running [Re: NickL] #713681
11/03/17 2:20 am
11/03/17 2:20 am
BSA_WM20 Offline OP
BSA_WM20  Offline OP
It is a 71 fellas so OIF with the cross drilling from the OPR to the scavenge side.
