Timmer
Timmer
Henderson
191 registered members (68 royalstar tony), 1,794 guests, and 512 spiders.
Jody Camak, analyse, Drifter, john harrison, David Stothard
10040 Registered Users
Lannis 149
kommando 117
Stuart 63
479,099 mail-order LSR
Topics65,751
Posts635,624
Members10,040
66’ Lightning drops out of gear #710039
09/30/17 3:55 am
09/30/17 3:55 am
Streetsboro, Ohio, USA
U
usamike10 Offline OP
U
When accelerating in 2nd gear, especially when getting up to 4K rpm or higher the bike has the tendency to drop into neutral. The harder I accelerate the more likely this happens. This doesn’t happen in any other gear, any ideas what’s going on?
Re: 66’ Lightning drops out of gear [Re: usamike10] #710041
09/30/17 6:48 am
09/30/17 6:48 am
Worn dogs on the sliding gear and worn holes on the gear it slides across into and engages with for second. Cute is to replace both gears.
Re: 66’ Lightning drops out of gear [Re: usamike10] #710044
09/30/17 10:24 am
09/30/17 10:24 am
Rich B Online happy
Rich B  Online Happy
2nd gear is on the lay shaft. The end play of the layshaft is shimmed against the DS of the case. Per BSA, the end play should be "just perceptible". Shims are available in 3 thicknesses to tighten end play.
Shift fork can be bent, make sure fork is perpendicular to shift rod
If you have standard ratios (most likely), then 2nd and 3rd sliding gears are interchangeable. Swap layshaft and maishaft sliding gears. Unless someone has already saved the gearbox in the past with this trick! Check the dogs first.
The mating gear may be worn. If so find one that isn't.
Re: 66’ Lightning drops out of gear [Re: usamike10] #710408
10/03/17 3:55 pm
10/03/17 3:55 pm
gavin eisler Online content
gavin eisler  Online Content
When my bike did this it turned out to be a badly worn cam plate and plunger.
The dogs are probably a bit worn on the sliding gear, I didnt replace it at the time, but did pay attention to the LS end float, it never jumped out after that.
Re: 66’ Lightning drops out of gear [Re: usamike10] #710495
10/04/17 12:44 pm
10/04/17 12:44 pm
U
U
Thanks for all the good advice, sounds like a project. I’ve never been into the gearbox, but I do have the manual.
