SBoyd
SBoyd
Virginia, USA
43 registered members (Alan_nc), 249 guests, and 396 spiders.
Bruce1947, Robert mickey, Geofft, WJS, Trondgv
10333 Registered Users
Stuart 129
reverb 69
DavidP 64
660,220 mail-order LSR
Topics67,703
Posts657,731
Members10,333
A 65 rocker ratio #709847
09/27/17 4:33 pm
09/27/17 4:33 pm
Duesseldorf/Germany
Phil in Germany Offline OP
Duesseldorf/Germany
Hi all,
I do have a possible issue. Together with a mate I have come across a '70 A 65 Lightning puzzle. We could not resist and bought it. grin
The cylinder head has already been refurbished with new Colsibro guides and new Nucleus valves.
What makes me feel slightly uncomfortable is a measurement I have taken on the guides. The valve stem ends do protrude through the guides only 22 mm, every other head I have in reach shows a measurement of 24 mm.
10 years ago I had my own Lightning head refurbed at the shop which did the current head as well and I ended up with too long guides. The collar had hit the guides with a hot engine. Of course this went along with nasty noises. eek
If I do assemble the top collar with the collets to a naked valve I measure around 11.5 mm from stem end to the collars bottom end. This leaves me with 10,5 mm available travel for the collar when the valve is opening.
The cam is a standard 68-0437 with .306" lift resp. 7.8 mm. If the rocker Ratio was 1:1.2 I I'd end up with 9.4 mm valve lift or about 1 mm clearance.
My gut feeling is that this will not suffice due to the dynamic behaviour of the valve train and thermal expansion.
Is my assumption regarding the rocker ratio reasonable? Unfortunately I could not find a figure with the search function on the forum.
I am inclined to get the guides shortened by 2 mm.
Can you help me out with any input regarding my issue?
Thanks in advance and best regards
Phil
Best regards
Phil
Duesseldorf/Germany
'62 A 65 Star (disassembled)
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
Re: A 65 rocker ratio [Re: Phil in Germany] #710648
10/05/17 10:25 pm
10/05/17 10:25 pm
gavin eisler Offline
Yes I had an issue, i had oversize inlet valves fitted, the new seat left the valve very proud in the combustion chamber, leading to piston clearance and valve binding issues, once the seat was cut 0.070" deeper normal service was restored, so not really a valve guide problem. Using the stock spit cam and valve springs from SRM , no issues 3K later, ( I dont push the rev ceiling very hard , its seen 6.5 k a couple of times.),
I dont know about rocker ratios, I believe Mark Parker has special rockers with offset buttons to get more travel.
Re: A 65 rocker ratio [Re: Phil in Germany] #711244
10/11/17 9:15 pm
10/11/17 9:15 pm
Duesseldorf/Germany
Duesseldorf/Germany
Hi there,
I have now done some measurement on the rockers. The inlet ratio seems to be 1.11, the exhaust ratio 1.16.
Anyway, I have shortened the guides to give me peace of mind. With the valves pushed to the seat the valve stems now protrude 24 mm resp. 15/16" in your money through the guides.
FWIW
Cheers!
Ph.
Best regards
Phil
Duesseldorf/Germany
'69 A 65 Lightning
'71 A 65 Firebird
'75 T 160
'84 Yamaha SR 500
