Spitfire Ken
Spitfire Ken
Illinois
27 registered members (BikeVice), 200 guests, and 414 spiders.
FireGuyKC, spuggy, Vinny Cotroneo, KeithM, Mridul Handa
10285 Registered Users
Stuart 97
Lannis 62
633,845 mail-order LSR
Topics67,352
Posts653,894
Members10,285
Page 5 of 5 1 2 3 4 5
Re: B31 "clubman" [Re: chaterlea25] #687793
03/12/17 2:20 pm
03/12/17 2:20 pm
Bolton Lancs UK
Andy Higham Offline OP
Bolton Lancs UK
Ok I re-designed the starter arrangement.
This time I am using a Royal Enfield sprag. I machined a sprocket to take two 12mm x 28mm x 8mm bearings on the inside and a 35mm x 40mm x 12.5mm needle roller inner ring. This is pressed and Loctite (648) on. I machined an outer race for the sprag from "gauge plate" which will be oil hardened, this is held on a carrier keyed to the central shaft. A bearing housing completes the ensemble.
The "rotating parts"
The sprocket
The outer race, sprag and carrier
How it fits together
The assembly fitted in the bearing housing
A trial fit on the bike
1962/67 Greeves 350
1967 Greeves 360 Challenger
Jawa 500cc "Llareggub"
Re: B31 "clubman" [Re: Andy Higham] #687812
03/12/17 5:02 pm
03/12/17 5:02 pm
Bolton Lancs UK
Bolton Lancs UK
The nuts and bolts holding the reinforcing ring on the clutch are about 1.5mm from the sprag outer. I will replace these with rivets for more clearance
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #687947
03/13/17 8:32 am
03/13/17 8:32 am
Forfar, Scotland
JER.Hill Offline
JER.Hill  Offline
Forfar, Scotland
Hi Andy
You might find that you don't actually need the reinforcing ring! Some moto cross engines don't have them and work fine and probably getting a harder life.
Re: B31 "clubman" [Re: Andy Higham] #690447
04/04/17 2:35 pm
04/04/17 2:35 pm
Bolton Lancs UK
Bolton Lancs UK
This afternoon the tank arrived from Holtworks, it wouldn't be right not to see how it looks on the bike
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #690474
04/04/17 6:45 pm
04/04/17 6:45 pm
Neenah, WI
Hoodellyhoo Offline
Hoodellyhoo  Offline
Neenah, WI
bigt
1970 BSA A50
1972 Honda CB350F
1965 Honda S65
2007 Kymco People S200
Re: B31 "clubman" [Re: Hoodellyhoo] #690603
04/05/17 7:52 pm
04/05/17 7:52 pm
england
GS DAVE Offline
GS DAVE  Offline
england
Lovely, they do excellent work...
Looks like you have plenty of room above the carb top for adjustments.
Re: B31 "clubman" [Re: Andy Higham] #690631
04/05/17 11:31 pm
04/05/17 11:31 pm
gavin eisler Offline
The whole job looks great Andy, if you stir up that iron thing it will make a good bit more heat , considered an oil cooler?
My iron sporster got the oil too hot to touch in 6 miles.
Great persistence on the leccy leg, it will be a boon when sorted.
Remember the home plating stuff , forget my method, get a kit would be my advice, results in the real world 2 out of 10.
Re: B31 "clubman" [Re: Andy Higham] #691284
04/11/17 6:03 pm
04/11/17 6:03 pm
Bolton Lancs UK
Bolton Lancs UK
I bought a little 2KW muffle furnace, this had been used for enamelling and the only control was a " stove hob type" power regulator.
I built a little control panel with a K type thermocouple controller and SSR regulator to give reasonably precise temperature control.
Today I put my sprag clutch outer housing in it and warmed it up to 500 Deg C to pre-heat soak, then increased the temperature to 800 Deg C. After allowing 1/2 Hour at this temperature I dunked the housing in ex Aprilia engine oil. I then allowed the furnace to cool to 250 Deg C and after cleaning the oil off I put the housing back in the furnace for an hour to temper.
Tomorrow may be the big try out of Mk 3 starter
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #707706
09/08/17 2:48 pm
09/08/17 2:48 pm
Bolton Lancs UK
Bolton Lancs UK
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #707712
09/08/17 3:27 pm
09/08/17 3:27 pm
Bolton Lancs UK
Bolton Lancs UK
The carburation needs sorting out yet, it is as rich as Bill Gates. Next weekend I have entered the British records event at Elvington with both my Greeves and B31, ideal place to sort the carburation with a 2 mile long runway. I hope I can get timing tickets for both bikes at 100+MPH
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #707724
09/08/17 4:41 pm
09/08/17 4:41 pm
MN
Shades34 Offline
Shades34  Offline
MN
Beautiful
Re: B31 "clubman" [Re: Shades34] #707774
09/08/17 11:37 pm
09/08/17 11:37 pm
OZ
Triless Online content
Triless  Online Content
OZ
Absolutely ! Fantastic machine, Andy.
Re: B31 "clubman" [Re: Andy Higham] #707948
09/10/17 6:50 pm
09/10/17 6:50 pm
Bolton Lancs UK
Bolton Lancs UK
I had a quick twiddle with the pilot air screw, set it to 3 turns out instead of 1 1/2.
That made it slightly lean at idle as evident by the occasional spit back but then as I open the throttle it goes back to rich. As I have not tried it under load yet, I have only run it on the full diameter of the needle.
I deduce from that the pilot jet is probably close and the needle jet is rich. I will put in a leaner needle jet and try again.
After work I made up a cable and fitted the handlebar lever choke instead of the button on the left (hard to reach) side of the carb. Its so easy to make cables with a birdcage tool and solder pot
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #708119
09/12/17 2:41 am
09/12/17 2:41 am
wadeschields Offline
Thats beautiful !!!
Re: B31 "clubman" [Re: Andy Higham] #708423
09/14/17 5:49 pm
09/14/17 5:49 pm
Bolton Lancs UK
Bolton Lancs UK
MOT is done.
I rode down to the MOT test station, the engine feels lovely and smooth, the exhaust note is glorious deep yet staccato sound. I have a slight issue with the gearbox, when down shifting sometimes the lever sticks, I need to hook my toe under it to nudge it back to the central position
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #708807
09/17/17 8:56 pm
09/17/17 8:56 pm
Nanaimo, B.C. Canada
W
Wilfred Offline
Wilfred  Offline
W
Wonderful! All it needs now is a little dirt and lots of dead bugs all over the front of it. Interesting clamps on the control levers.....
Cheers, Wilf
"It's about the ride..."
Re: B31 "clubman" [Re: Andy Higham] #708868
09/18/17 10:24 am
09/18/17 10:24 am
Bolton Lancs UK
Bolton Lancs UK
Over the weekend I entered the records meeting at Elvington. The B31 behaved beautifully, fastest one way standing start mile 85MPH.
The bike is very smooth, it would be comfortable at 70MPH all day. I have a very slight oil drip from the clutch case but that's all.
Wilf, the levers are replica Tomaselli matador alloy levers. I modified the brake lever to a compensated twin pull
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #708938
09/19/17 6:26 am
09/19/17 6:26 am
W
Wilfred Offline
Wilfred  Offline
W
Andy
Those lever clamps look so much better than almost anything else....especially the ones that are so thin that the whole thing can't help but flex when used. I must keep an eye out for something like that.
Cheers, Wilf
Re: B31 "clubman" [Re: Andy Higham] #709320
09/22/17 8:24 pm
09/22/17 8:24 pm
Bolton Lancs UK
Bolton Lancs UK
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #709387
09/23/17 6:54 am
09/23/17 6:54 am
W
Wilfred Offline
Wilfred  Offline
W
Thanks, Andy.
Cheers, Wilf
Re: B31 "clubman" [Re: Andy Higham] #738157
06/09/18 3:01 pm
06/09/18 3:01 pm
Bolton Lancs UK
Bolton Lancs UK
Spot the changes
[Linked Image]20180609_152238 by Sigma Projects, on Flickr
[Linked Image]20180609_152321 by Sigma Projects, on Flickr
[Linked Image]20180609_152256 by Sigma Projects, on Flickr
The Mikuni VM carb is straight out of the box, it started first touch of the button and idles nicely
1962/67 Greeves 350
Re: B31 "clubman" [Re: Andy Higham] #738183
06/09/18 8:31 pm
06/09/18 8:31 pm
Bolton Lancs UK
Bolton Lancs UK
Click picture to play video
[Linked Image]20180609_152516 by Sigma Projects, on Flickr
1962/67 Greeves 350
