FullThrottle
FullThrottle
Sweden
31 registered members (Al Eckstadt), 302 guests, and 461 spiders.
10291 Registered Users
Stuart 93
Lannis 67
Mori55 66
638,199 mail-order LSR
Topics67,398
Posts654,395
Members10,291
Page 3 of 3 1 2 3
Re: new engine [Re: lemans] #646167
03/28/16 5:06 pm
03/28/16 5:06 pm
gavin eisler Online content
gavin eisler  Online Content
Hi Anne, nice progress, in the pic below you can see the Devimead solution for lubrication of the Timing side bearing, the original pressure feed is blanked and a small cavity is created on the top side of the bearing boss allowing oil to drip into the bearing.
Re: new engine [Re: lemans] #646176
03/28/16 5:38 pm
03/28/16 5:38 pm
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
hi Gavin, that is indeed a clever solution, being a needle roller the dripfeed is more than enough. As you can see in my earlier posts I used a scrub srew with a 1mm orifice. Same setup as with the old engine which lasted some 32 years/ 12000 miles. Regards A
see post 500026 and just follow the links
Re: new engine [Re: lemans] #680466
01/08/17 1:02 pm
01/08/17 1:02 pm
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
been a while but this christmass the new engine is work in progress.
solved the axiaal end float voodoo, made a new bearing out of some phosphor bronze.
in the end it is just a 5,25 mm thick slab of bronze, milled to the correct dimensions. end float is now 0,04 mm
next jobs on the list are:
1. camshaft
2. the SRM-Oilpump
3. gearbox, pity the five-speed from Scotland isn't available yet so have to resort to the four-speed.
regards A
Re: new engine [Re: lemans] #680496
01/08/17 3:59 pm
01/08/17 3:59 pm
Forfar, Scotland
JER.Hill Offline
JER.Hill  Offline
Forfar, Scotland
Hi Anne
Nice to see your moving forward again. With regards to the 5 speed clusters, I've been surprised by the lack of interest, other than myself the other two which I know are in use, Mark Parker and Gavin Eisler are happy with the performance, of the 11 sets sold others don't really give you much feed back.
Hopefully your post can generate a little more interest, at the moment there are your self and four other who have shown an interest. I need to order a batch of ten, so if anyone is interested PM here or get in touch.
regards
Re: new engine [Re: lemans] #680502
01/08/17 4:29 pm
01/08/17 4:29 pm
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
well the five-speeder can be exchanged with the engine in the frame, so there's no real hurry yet
still..... I want to shift one more time when they don't expect it.
the bike used to be run two-up and then the four-speed hasn't the best spaced ratio's.
future use is again two-up
regards A
Re: new engine [Re: lemans] #684593
02/11/17 8:53 am
02/11/17 8:53 am
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
what better way to spend a snowy saturday morning
Re: new engine [Re: lemans] #701030
07/07/17 2:02 pm
07/07/17 2:02 pm
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
[censored] photobucket
Re: new engine [Re: lemans] #701031
07/07/17 2:03 pm
07/07/17 2:03 pm
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
cool this auto-censor-function
see if it works with this one
ooops Photobucket
Re: new engine [Re: lemans] #707812
09/09/17 11:37 am
09/09/17 11:37 am
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
progress with the new engine is slow, very slow. with the upcoming winter season the objective is to have all components ready.
and now the camshaft. I purchased a 90-drg camshaft a couple of years ago. and it is not straight. although new the complaining period is long past and I'm having a new one made at the local camshaft-shop
http://www.hurricaneracing.nl/
question now is:
are the profiles for inlet- and exhaust-cam identical?.
regards Anne
Re: new engine [Re: NickL] #708184
09/12/17 4:48 pm
09/12/17 4:48 pm
Originally Posted by NickL
It depends which cam you have. The standard 'spitfire' form is different.
I think this also alters depending on if its an original cam (to which I think your referring) or a remanufactured item, which I have seen lift heights and duration different to that of the factory item (and different to other makers versions of the same cam)
The SRM race cam as far as 360 degree motors are concerned is a good cam.
Re: new engine [Re: Allan Gill] #708243
09/13/17 9:29 am
09/13/17 9:29 am
netherlands
lemans Offline OP
lemans  Offline OP
netherlands
[quote=NickL]
I do think so but where can I find the profiles for the inlet- and exhaustcam.
I do not think they are the same.
regards Anne
Re: new engine [Re: lemans] #708581
09/15/17 9:12 pm
09/15/17 9:12 pm
Fergus, Ontario, Canada
Dave T Offline
Dave T  Offline
It seems I can no longer view the images on the forum threads unless I fork over money to photobucket to upgrade my account. Or am I doing something wrong?
Re: new engine [Re: lemans] #708584
09/15/17 9:21 pm
09/15/17 9:21 pm
shel Offline
shel  Offline
No, Dave you have to pay money to upload your own photos from photobucket, you still won't be able to see others photos unless the poster of those photos pays the ransom too
Re: new engine [Re: shel] #708876
09/18/17 12:08 pm
09/18/17 12:08 pm
Brisbane, Australia
BrizzoBrit Offline
BrizzoBrit  Offline
Brisbane, Australia
Go to BritBike FAQ.
Look at the photobucket ransom post by Andy Higham.
If you use Chrome as your browser you can install the app mentioned that shoves it right up Photo*uckits backside and allows you to view the images.
It works!!
BSA 1969 A65F
BSA 1966 A65H
Triumph 1968 T120
Kawasaki A1R
& too many projects!
Page 3 of 3 1 2 3
