gudgean
gudgean
fulton county pennsylvania
23 registered members (Bikeosaurus), 193 guests, and 451 spiders.
10257 Registered Users
Lannis 60
TBolt72 46
609,388 mail-order LSR
Topics67,124
Posts651,412
Members10,257
'66 TR6C Clutch Weirdness? Or Maybe Not? #708736
09/17/17 5:19 am
09/17/17 5:19 am
Kenya
Peter Gee Offline OP
Kenya
Am used to pre-unit clutch setups. Put in my new or v.g.c 2nd hand clutch parts, with new pushrod into my 1966 3 spring unit. . Springs measured to 1.75", "3 Balls" activator assembly ( new to me) seemed working fine on pre-build. Cable appears correct and is new.
Tightened the springs to the top of the spring pins after adjusting the clutch lever and backed off the clutch adjuster half a turn, having set it to just touching the pushrod..and pulled the rather stiff clutch lever with anticipation.
Result is about 15mm of movement and it's at once spring bound and wont go any further towards the grip. Yet the springs are the right length for a 12 plate clutch.
The only way I can get some reasonable movement in the clutch lever is by backing off the spring nuts from their starting tightness of " first pin thread showing" about 4 whole turns or more .
I bought new spring pins, claimed to be stock size. This might be the prob but I don't know the spec length.
Maybe this is wholly normal on units, maybe something else is going on. I don't want to gasket up my primary and have to remove it all over again. Comments welcome
Re: '66 TR6C Clutch Weirdness? Or Maybe Not? [Re: Peter Gee] #708739
09/17/17 5:40 am
09/17/17 5:40 am
triton thrasher Offline
I'd back the spring nuts off until the springs don't bind (and a bit more) and wouldn't worry about it as long as the nuts are holding by a reasonable number of threads, the nuts don't touch the outer cover and the clutch grips and releases.
Re: '66 TR6C Clutch Weirdness? Or Maybe Not? [Re: Peter Gee] #708740
09/17/17 5:42 am
09/17/17 5:42 am
Christchurch NZ
R Moulding Online content
R Moulding  Online Content
Christchurch NZ
Do you have the correct earlier lifting arrangement with the little spoke? If so this can get jammed in the abutment that screw into the outer cover. simple fix is to drill out the abutment.
Rod
So remember, when you're feeling very small and insecure,
How amazingly unlikely is your birth;
And pray that there's intelligent life somewhere out in space,
'Cause there's bugger all down here on Earth!
Re: '66 TR6C Clutch Weirdness? Or Maybe Not? [Re: R Moulding] #708743
09/17/17 8:12 am
09/17/17 8:12 am
Kenya
Kenya
Yes I have the little spoke and am going to check this carefully.....but it seems not to be a problem.
Re: '66 TR6C Clutch Weirdness? Or Maybe Not? [Re: Peter Gee] #708753
09/17/17 11:41 am
09/17/17 11:41 am
Kenya
Kenya
UPDATE: Well I took the springs out. Thout the right length, they are 81/2 turns instead of the WSM spec 7 1/2 which would account for the binding but,
Even with all the springs out and the pressure plate out, the clutch lever still does not depress to the grip...it only goes about half way. The engagement 3 Balls thingy does have a spoke with a screwed end with a locknut, that is set about halfway....
Very puzzling, ideas welcomed.
Here is the travel/lift of the clutch push rod from clutch out, pushing towards the 3 balls so no slack there and then pulling the lever. 0.124 = 3.2mm only!
Hmmmmmm....................do the clutch lever will never go down unless there is more travel on the push rod from the 3Balls engager.
OK I don't have Doherty levers but a reasonable Taiwanese version of levers...that's the only variable I can think of.[/color][color:#FF6666]
Re: '66 TR6C Clutch Weirdness? Or Maybe Not? [Re: Peter Gee] #708757
09/17/17 12:59 pm
09/17/17 12:59 pm
Kent, UK
Nick_Smith Offline
Nick_Smith  Offline
Kent, UK
As previously posted, check the threaded 'abutment' that the cable locates in, in the top of the gearbox cover.
The block on the end of the spoke that carries the cable nipple goes up inside the abutment when the lever is pulled, but the abutment is drilled internally to two different diameters - large at the end that screws into the gearbox, smaller at the top to accept a split sleeve that serves to take up some of the cable length in final assembly, in which the cable outer ferrule locates.
This means that the abutment effectively has a step inside it. I had to drill mine out to move the 'step' further up towards the top of the part (allowing more travel for the block on the end of the spoke), and it seems like the other poster did too.
Otherwise, there is a small conical spring on the centre pin of the three-ball setup - is that going coil-bound?
If it feels like a 'dead-stop' then I would look to the abutment first.
Otherwise, if you haven't already, this:
http://shop.triumphtwinspares.co.uk/triumph-workshop-manual-1963-70-650-twins-3927-p.asp
Nick
"1967 TR6R"
Re: '66 TR6C Clutch Weirdness? Or Maybe Not? [Re: Peter Gee] #708773
09/17/17 3:52 pm
09/17/17 3:52 pm
Kenya
Kenya
Thanks guys, well the abutment is certainly a possible problem, I will ceck it out tomorrow, if it has two different diameters that could be the reason, it would stop the clutch pull cold....
