DodgyRog
DodgyRog
Essex
44 registered members (998John), 289 guests, and 470 spiders.
10257 Registered Users
Lannis 54
TBolt72 47
610,583 mail-order LSR
Topics67,143
Posts651,578
Members10,257
69/74 Engine rebuild #704358
08/08/17 9:05 pm
08/08/17 9:05 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
This was a thread on my struggles with my 69/74 bitsa. http://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=689483&page=13 Because of the broken photo links thanks to photo bucket I have decided to start a new thread on the engine and gearbox rebuild along with new fotki photo links. I may eventually go back and fix the links in the older thread but right now I have better ways to spend my time. Where that thread left off I had made the bike rideable and it was actually running pretty good, good enough for me to take it on some longer rides and find out the oil pressure was marginal at best at sub 40psi at 4000 rpm. The clutch was also slipping badly, so the primary had to come apart. Once I got it apart, I decided to go ahead and strip the engine and replace the bearings. Here's some pics from the strip down.
Here she is before the strip down
[Linked Image]Hosted on Fotki
Badly glazed clutch, will replace with new.
Drive chain sprocket was a fight getting off. Heat and an impact gun finally got it. Had to special order the socket
Head off. I have recently replaced the valves.
Top cylinders, compression was 140,135,130
cylinders off, pistons had been knurled at some point, standard bore will go +20 and new pistons and rings
Cylinders are glazed and show some light scoring.
gear box apart
More to follow.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
2-1974 Norton Commandos
2004 XL 1200R Sportster
Re: 69/74 Engine rebuild [Re: htown] #704404
08/09/17 9:52 am
08/09/17 9:52 am
Great Southern Land
tridentt150v Offline
Great Southern Land
Timing side piston looks like its been hammered from a previous encounter with a metal let go!!! Head has scars as well. That can't be good smile
What is the significance of the MML stamps? I can't remember seeing that before but my memory isn't eidetic.
Re: 69/74 Engine rebuild [Re: htown] #704429
08/09/17 2:32 pm
08/09/17 2:32 pm
Tridentman Online content
Tridentman  Online Content
Indicates gradated bore size for piston fitment.
Pistons on initial build came in three sizes for standard bore---Large, Medium and Small.
After first rebore it is of course irrelevant.
Re: 69/74 Engine rebuild [Re: Tridentman] #704433
08/09/17 3:10 pm
08/09/17 3:10 pm
Norfolk, UK
L.A.B. Online content
L.A.B.  Online Content
Norfolk, UK
L-Low (smallest), M-Medium, H-High.
Later, just L and H.
Re: 69/74 Engine rebuild [Re: htown] #704434
08/09/17 3:42 pm
08/09/17 3:42 pm
Thanks Les--I stand corrected.
Re: 69/74 Engine rebuild [Re: htown] #704441
08/09/17 5:16 pm
08/09/17 5:16 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
If this engine could talk it probably could tell some tales. Definitely some hard object in the timing cylinder. Piston is getting replaced and I removed any sharp edges from the divot in the head to prevent hot spots. Bottom end is from a 69 while rest of engine appears to be 74 same as the frame. More tear down pics.
Crank has been reground at least once. When I miked the journals I found the rods were -.010 but mains were actually -0.20, no indication stamped anywhere.
Main journal showing scoring. I'm thinking maybe on the second regrind the cleanout plugs weren't removed and debris damaged the journals
Main bearings. Also the caps were switched side to side. Guess the po didn't know what the t & d stood for. Being a 69 the caps had the rocker feeds but they were blanked off.
Typical rod journal
Rod bearings
Exhaust cam has a divot in it, its getting replaced. Got a good deal on the pair, so a new intake too.
Lifters are badly scuffed so new stellite tipped ones
I seriously debated whether to strip this engine or not. Based on what I've seen I'm glad I did. Crank and cylinders went to Big D in Dallas for a regrind and +20 over bore.
1974 Trident
Re: 69/74 Engine rebuild [Re: L.A.B.] #704596
08/11/17 5:24 am
08/11/17 5:24 am
Great Southern Land
Great Southern Land
OK, who did it?? and when did they stop doing it....I have never seen it on any '73 on Trident I've worked on and I've seen a few [never worked on a pre '73].
Re: 69/74 Engine rebuild [Re: tridentt150v] #704615
08/11/17 12:52 pm
08/11/17 12:52 pm
Norfolk, UK
Norfolk, UK
http://www.eBay.com/itm/BSA-A75R-Rocket-3-Mk1-750-Triple-A75-Trident-III-HURRICANE-TOP-END-CYLINDERS-/142212179729?hash=item211c81a711:g:P7wAAOSw-0xYUYkk&vxp=mtr
http://www.eBay.com/itm/Triumph-T160-750-Trident-Cylinder-Barrel-Pistons-1069-/372040726660
Re: 69/74 Engine rebuild [Re: htown] #704645
08/11/17 5:23 pm
08/11/17 5:23 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Now to start putting it back together. The strip down photos were taken a while back. I've found this series of videos on Youtube to be quite helpful. https://www.youtube.com/watch?v=Dg8gvkWQ6io
Reground crank, access plugs removed and oil ways cleaned, new plugs.
Rods polished and new bearing shells fitted.
Rods on crank, will fit middle cylinder with barrel
New main bearings
Crank in the center case
New cams ready to install, nos standard grind
Drive and timing cases installed. Crank turns buttery smooth.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #704653
08/11/17 7:19 pm
08/11/17 7:19 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
I do not think the scoring on the journals is from a previous regrind. There is only the cross drilling for the oilways and plugs, not a clean-out per say. Dirt trapped beyond the hole to the bearing will stay there from centripetal force. Anything up to the bearing hole or dirt in the oil will get to the journal.
As an alternative to grinding the crank further you can have the journals hard face built up and reground for nearly the same cost. They would be less sensitive to scoring.
Re: 69/74 Engine rebuild [Re: htown] #704837
08/13/17 1:32 am
08/13/17 1:32 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Thanks for the suggestion DM. Crank has already been reground. I still have one more grind on the mains and two on the big ends. Hope I never need to see the crank again. Considering my age and amount of miles each bike gets, if its done right I shouldn't.
Timing gears installed today.
Strange grooves on one of the drive side tappet blocks. Has two matching grooves on the other side but not as deep. Almost like the tappet was forced from side to side. Tappet fits in there nice and smooth now and doesn't rock side to side. Wondering if it would be okay or need to replace. Not sure how to replace it. All of the tappet tools I see for sale have 2 pins. No instructions in manual.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #704840
08/13/17 2:22 am
08/13/17 2:22 am
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
My guess is the face of the tappet was not square to the shaft. Your tappet faces were fairly scuffed. As the tappet was lifted it would twist twist one way then twist the other on the falling side.
There is a plug in the face of the cylinder base (70-9465) that orients the tappet block. The cylinder flange must be supported when driving the tappet block in or out. There is an o-ring seal (70-6560) around the tappet block that should be replaced also.
You should blue the tappet faces and check the cam does not run off the face. Very quick cam wear will follow.
Re: 69/74 Engine rebuild [Re: htown] #704877
08/13/17 3:40 pm
08/13/17 3:40 pm
Houston
GaleGorman Offline
GaleGorman  Offline
Houston
When I tore my T150 down one cam follower was crossways from the factory and the result was these same grooves. Install a new follower correctly and it should be OK. The bike only ran 1662 miles to make those grooves and destroy the cam lobe.
Gale Gorman
Houston
1974 Triumph Trident
1983 BMW R100S
Re: 69/74 Engine rebuild [Re: htown] #704909
08/13/17 8:41 pm
08/13/17 8:41 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Thanks for the replies. . It looks like replacing the guide blocks on these is close to impossible. There is a dowel that holds them in place and the dowel is driven in flush with surface of the casting and then staked with a punch. I don't see anyway possible to remove the dowel as it can't be driven out and there is nothing to grab to pull it out.
One other question I have is on the tappet there is a flat with a hole in it on the stem. How should these be oriented. My cases are from a 69 but the rocker feeds have been capped at the main bearing caps.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #704969
08/14/17 1:31 pm
08/14/17 1:31 pm
Houston
GaleGorman Offline
GaleGorman  Offline
Houston
I think these get all the oil they need from the pushrod tubes and crankcase splash.
Gale Gorman
Houston
1983 BMW R100S
Re: 69/74 Engine rebuild [Re: htown] #704977
08/14/17 3:07 pm
08/14/17 3:07 pm
Norfolk, UK
Norfolk, UK
http://www.classicbike.biz/Triumph/Repair/Trident/69-73TridentRepair.pdf
Section A4 Fig.A5 (or Section B17 Fig.17) 'according to the book'.
Re: 69/74 Engine rebuild [Re: htown] #705026
08/14/17 9:35 pm
08/14/17 9:35 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The dowel pins are removed by drilling a hole and tapping them then use a slide hammer. You should be able to get a #10-24 in there if you can find centre.
Remember the tappets are not square to the block so press them out and in square to the hole.
Re: 69/74 Engine rebuild [Re: htown] #705267
08/17/17 12:41 am
08/17/17 12:41 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
I think Gale nailed it, the tappet had been incorrectly installed turned 90 degrees. When I turn it that way it fit the grooves perfectly.
The cam lobe also had a v-shaped wear pattern. It was getting replaced anyway.
Here are the tappets installed after I had the bores reamed to .5 to 1.5 thou clearance. If you read my other thread you saw 3 of the tappets had oversized stems.
My lovely better half assisting me dropping the cylinders on.
Cylinders on, I used the middle piston in the cylinder method and then added the rod cap through the sump opening. Took 2 tries but last one went well. Everything rotates super smooth.
All buttoned up and ready to drop back into the frame. Need my ex linebacker son in law to come up and give me a hand.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #706340
08/27/17 1:05 am
08/27/17 1:05 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
My son in law came up the other day and picked up the engine and slid it into the frame like it was a loaf of bread. Here she is already to start bolting parts back on. Not sure whether to do the head or gearbox next. Should be plenty of time to work on it. Looks like we won't be riding any motorcycles in the Houston area for a while.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #706761
08/31/17 12:00 am
08/31/17 12:00 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Cylinder head sitting in place. I'm waiting on some new upper push rod seals. Haven't had mail for 4 days due to Harvey. Not sure when it will resume.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #706800
08/31/17 9:42 am
08/31/17 9:42 am
Houston
GaleGorman Offline
GaleGorman  Offline
Houston
My internet and TV came back on at 9:00 last night. We are dry and OK. How about you?
Gale Gorman
Houston
1983 BMW R100S
Re: 69/74 Engine rebuild [Re: htown] #706831
08/31/17 2:52 pm
08/31/17 2:52 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Glad to hear you didn't get flooded, Gale. We were fortunate not to get any water in house.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #708348
09/14/17 2:42 am
09/14/17 2:42 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Rocker boxes on, head torqued down, valves set and timing cover installed.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #710092
09/30/17 7:55 pm
09/30/17 7:55 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Back on track after a bit of a set back. After I got the top end assembled I found a plastic bag with two dowels. Carefully going through the parts book I determined they were supposed to go between the crankcases and cylinder block. So long story short, the top end came back apart, dowels and new gaskets installed and everything buttoned back up again.
Next install was a new NOS oil pump.
Testing the pump and priming the engine. 100 psi oil pressure and return to oil tank.
With good test on oil pressure, I assembled the gearbox.
Hooked 20 tooth gearbox sprocket. Needs replaced
Next task the clutch and primary.
1974 Trident
Re: 69/74 Engine rebuild [Re: htown] #714711
11/12/17 3:55 am
11/12/17 3:55 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Back on the Trident after a little over a month off. Rebuilt the gearbox on my 70 Thunderbolt because I only had 1st and 2nd. After some waits on parts and other things the gb is back together and shifting well. So back to the Trident. I tried the various techniques in this video to set up the clutch.
https://www.youtube.com/watch?v=elM3h2RGbGQ
I got all the papers except one to remove with .0025 lift and it came out at .0035. One thing I noticed is the clutch disc is not the same thickness everywhere. There is at least a thou difference in different places. So where you measure the lift would be effected by that. I also did the clutch spline trials. Didn't really seem to have much variation, best was about .0010 runout. Anyway I'm getting excited about getting it finished and firing it up. Not really much left at this point.
1974 Trident
