737Captain
737Captain
Tampa Fl.
22 registered members (Andy Higham), 161 guests, and 134 spiders.
10294 Registered Users
Stuart 97
Lannis 68
Mori55 67
640,178 mail-order LSR
Topics67,420
Posts654,643
Members10,294
Page 1 of 3 1 2 3
4CA ET ignition wires #707652
09/08/17 12:12 am
09/08/17 12:12 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
I'm getting my 67TR 6C back together. Got the jugs in stator hooked up. Put the auto advance in.
I put the points on the plate with condensers. My problem is I can't seem to get the wires routed right around the points and condensers. No matter how I do it there's something interfering with them.
Why is it the simplest things that are the biggest pain in the ass. Plus now I'm getting tired and frustrated. Time to walk away before I screw something up. Only thing I didn't take a pick of. I looked in the manual but the pic doesn't seem like it'll work that way. The cover will hits.
Re: 4CA ET ignition wires [Re: Mori55] #707657
09/08/17 1:52 am
09/08/17 1:52 am
Frazier Park, CA
Chris Johnson Offline
Frazier Park, CA
Did you use new condensers? The Daiichi and Lucas (reboxed Daiichi) are too long and ground out against the timing recess. Otherwise it should all fit under the points cover.
Chris
Re: 4CA ET ignition wires [Re: Mori55] #707658
09/08/17 2:21 am
09/08/17 2:21 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
I bought them but like u say they are to long. Actually the old one I trstested before I pulled it apart had a stronger spark.
It's just the routing of the wires that's giving me a headache.
Also since the ads off I can see top dead center real good. How do I static time it ? The manual say have the points starting to open when the piston is 1/32 from tdc. Does this sound right ?
Re: 4CA ET ignition wires [Re: Mori55] #707667
09/08/17 3:46 am
09/08/17 3:46 am
Frazier Park, CA
Frazier Park, CA
I don't trust timing by piston position. I'd follow the procedure in the workshop manual.
Chris
Re: 4CA ET ignition wires [Re: Mori55] #707671
09/08/17 9:30 am
09/08/17 9:30 am
Stuart Offline
Stuart  Offline
Originally Posted by Mori55
67TR 6C
Given fifty years ago Lucas supplied and Triumph (and everyone else) fitted a better points plate (6CA) and moved the condensers out of the points compartment because engine heat shortens their life, and you're having difficulty with modern parts in an unsuitable position, why use the inferior points plate and condensers mounting? confused
Re: 4CA ET ignition wires [Re: Mori55] #707672
09/08/17 9:45 am
09/08/17 9:45 am
Wiltshire England
DUHC Offline
DUHC  Offline
Wiltshire England
Mori55 - I echo Stuart's good technical reasons for updating to 6CA. Plus, I agree with your frustrations with 4CA arrangement and lack of space which made me change to 6CA set up. Bought secondhand 6CA points, plate and auto advance off eBay and located MGB condensers (v cheap in UK) up near coils. Much easier to set up and more accurate to time on each pot. .
Re: 4CA ET ignition wires [Re: Mori55] #707675
09/08/17 11:17 am
09/08/17 11:17 am
kommando Offline
kommando  Offline
Its important to get the 6CA AAU as well as the 6CA points plate, the 4CA cam creates secondary bounces and sparks leading to seized pistons which the 6CA cures.
Re: 4CA ET ignition wires [Re: Mori55] #707676
09/08/17 11:18 am
09/08/17 11:18 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
Well unfortantly I just had the rotor remagnitized and a new stator. Plus I reall y didn't want to have to replace the harness in the bike. I was trying to keep it original. So as of now I'm stuck with what I have.
My workshop manual says that's how you setup the points with top dead center as far as I can tell
Re: 4CA ET ignition wires [Re: kommando] #707695
09/08/17 1:21 pm
09/08/17 1:21 pm
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
Kommando , so that means I'd have to change the rotor and stator and wiring harness since this is a ET ignition bike ? I'm just confused with this. I k ow you can't run the 6ca aau with this system. I don't even have a battery box.
Re: 4CA ET ignition wires [Re: Mori55] #707713
09/08/17 3:38 pm
09/08/17 3:38 pm
Frazier Park, CA
Frazier Park, CA
You have to keep the ET specific AAU with its reduced range and different cam profile. The wiring harness doesn't change but you have to install the condensers near the coils... you can wire them into the connector between the points wire and coil.
6CA points plate is the same for BSA twins, in case you find them to be offensively expensive when sold as a Triumph part.
Timing requires you to accurately locate TDC, roll the engine backward to your full advance position (37, 39, or 41 degrees BTDC) lock the AAU at full advance, adjust the points to just open at this point. Repeat for the other side.
Chris
Re: 4CA ET ignition wires [Re: Chris Johnson] #707722
09/08/17 4:36 pm
09/08/17 4:36 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
as a cost-saving measure
keep the 4CA points plate and the special et cam profile ... and just fit your condensers remotely , up near the e t coils
the points bounce problem with some 4ca points plates was for Kettering ignitions
the et ignition does not "dwell or charge the coils " ... it's using a different cam
the 'dwell' or potential, is held as magnetic flux is in the ET stator. ..until the moment the points open.
at which point it races, at the speed of light , from the et stator. ..
through the ET coil (Transformer ) .. to the spark plug
you still have to time the 4ca points properly
by manipulating the Gap of the points. ... but you don't need any new parts. ...to make t what you have work
Re: 4CA ET ignition wires [Re: quinten] #707759
09/08/17 8:48 pm
09/08/17 8:48 pm
Frazier Park, CA
Frazier Park, CA
You still need condensers at the 4CA plate to act as the termination point for your points spring and wiring.
Re: 4CA ET ignition wires [Re: Chris Johnson] #707778
09/09/17 12:04 am
09/09/17 12:04 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
Well can someone let me know how to static time this to get it running ? I have theTdc tool and the heads off. Any help would be a appreciated. This is all new to me.
I think what you guys are saying is lock the aau full advance the have the points just starting to open a tdc? Is this correct ?
Re: 4CA ET ignition wires [Re: Mori55] #707782
09/09/17 12:52 am
09/09/17 12:52 am
Frazier Park, CA
Frazier Park, CA
You need to know at which position your alternator rotor is mounted. It should be driven by a peg on the backside that fits into one of three holes. S = 37 degrees, M = 39 degrees, R = 41 degrees. If the rotor is driven by a woodruff key, you don't have an ET rotor.
-Set both breaker point gaps to spec (.012-.016"?).
-Start by engaging the 'S' hole on the alternator rotor.
-You can now use your TDC tool to lock the engine at TDC.
-Mount your degree wheel securely to the crankshaft.
-Mount a pointer on the crankcase that points to 0 degrees/TDC.
-Find a way to force your AAU fully advanced against the springs and lock it there.
-Remove your TDC tool.
-Looking at the primary side, turn the engine CW to 37 degrees BTDC on the degree wheel.
-Rotate the points plate so the breaker points closest to the points cam just begin to open, verified with a light bulb or buzz box or cigarette paper.
-Turn the engine one full turn again to 37 degrees BTDC.
-Adjust the other contact breaker to just open using the same method to verify opening. With a 4CA you can only achieve this by varying the points gap (close to retard, open to advance) and you may have to go back and forth a few times to find the best balance to keep both points gaps in spec. A 6CA allows independent adjustment without having to fudge the points gap.
-Release the previously locked AAU.
Chris
Re: 4CA ET ignition wires [Re: Chris Johnson] #707783
09/09/17 12:58 am
09/09/17 12:58 am
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
true, i didnt think of that.
it makes the mod more complicated.
the wire and points need an insulated termination point, but it doesn't have to be a condenser fitted ...right there.
.. if a simple mount was fabricated , larger or generic condensers could be remotely teed-in anywhere in points supply wire.
Re: 4CA ET ignition wires [Re: Mori55] #707784
09/09/17 1:13 am
09/09/17 1:13 am
kevin roberts Offline
fefsa
fefsa
i have no idea what i'm doing.
Re: 4CA ET ignition wires [Re: kevin roberts] #707787
09/09/17 2:26 am
09/09/17 2:26 am
Frazier Park, CA
Frazier Park, CA
Not ET compatible.
Re: 4CA ET ignition wires [Re: Mori55] #707830
09/09/17 3:49 pm
09/09/17 3:49 pm
fefsa
fefsa
bummer
that usually shortcuts the 4CA conundrum. i've cussed the too-big condensors as well.
Re: 4CA ET ignition wires [Re: Chris Johnson] #707870
09/09/17 11:38 pm
09/09/17 11:38 pm
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
Thanks that really makes it simple. Only thing l need is a degree wheel. I acutuall have the paper one that's in the parts book that could just glue to a thin piece of plastic or something till I order one. Is there any particular one I should order ?
Re: 4CA ET ignition wires [Re: Mori55] #707875
09/10/17 12:34 am
09/10/17 12:34 am
Frazier Park, CA
Frazier Park, CA
The paper one will get the job done if you're careful. I would recommend a proper aluminum or plastic wheel and I'm sure someone sells a kit with wheel and adapter to make it most straight-forward.
Chris
Re: 4CA ET ignition wires [Re: Mori55] #707958
09/10/17 9:44 pm
09/10/17 9:44 pm
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
I saw this one. Goes on the exhaust camshaft. Can I use this ?
Or get the other type ?
https://www.lowbrowcustoms.com/triu...agsab1gIVSjyBCh0NJA0IEAkYAiABEgLHYvD_BwE
Or this type ?https://fagengine.com/franz-and-grubb-triumph-degree-wheels-in-stock/
Re: 4CA ET ignition wires [Re: Mori55] #707961
09/10/17 9:55 pm
09/10/17 9:55 pm
Pacific northwest
quinten Offline
quinten  Offline
Pacific northwest
scalable print out here :
https://www.blocklayer.com/degree-wheel.aspx
print it to CD size, or scale and glue it to any disk you happen to have around .
Engineering choices are dependent on the resources available
meaning there is often more then one way to skin a cat
so for reference only, gleened from a triumph t120 tech Bulletin ;
full advance timing of 38* BTDC. .... is equal to. ...(27/64" ) for the old school , down hole piston method
and for E.T. static, slack plate timing with a 5* advance ... its 28* BTDC. .. down hole postion = ( 15/64 " )
Re: 4CA ET ignition wires [Re: Mori55] #707964
09/10/17 10:07 pm
09/10/17 10:07 pm
Frazier Park, CA
Frazier Park, CA
The exhaust cam degree wheel works but can be frustrating as you're making adjustments through the slots in the wheel. You probably need the early style unless your exhaust cam isn't original to the bike. F&G's is a fine unit (out of stock last time I looked) but you still need a way to attach it to the crankshaft.
Chris
Re: 4CA ET ignition wires [Re: Chris Johnson] #707984
09/11/17 12:45 am
09/11/17 12:45 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
That's what I wondering on how to attach to the crank. Yes cams and all are original. When you attach to exhaust cam what way to you turn it ? Is it opposite ?
Re: 4CA ET ignition wires [Re: quinten] #707987
09/11/17 12:49 am
09/11/17 12:49 am
NJ USA
Mori55 Offline OP
Mori55  Offline OP
NJ USA
Quinton ,That's with the ET AAU lock full advance ? I have the head off so measuring is no problem.
This would be the easiest way.
Page 1 of 3 1 2 3
