Ob1quixote
Ob1quixote
Charleston SC
207 registered members (1xfatboy), 1,885 guests, and 584 spiders.
BosBSA, Ron 1973 TR7RV, barnett468, dohck4, Pascal Di Marco
10028 Registered Users
Lannis 146
Stuart 63
475,357 mail-order LSR
Topics65,693
Posts634,978
Members10,028
Page 2 of 2 1 2
Re: A65 timing side bushing service info needed [Re: Ron C] #704216
08/07/17 1:14 pm
08/07/17 1:14 pm
Ron C Offline OP
Ron C  Offline OP
Ok parts list is coming along, I have a couple of questions as I get deeper into this and start trying to figure out what is causing what.
First question.
crank end play, was measure at 0.01 which seems way more then it should be. My Haynes manual does to give any specification for the Crank end-play/runout, I would expect that to be in the 0.001-0.002 range? Since it is 0.01 the only thing that I can see that would cause that is the roller bearing? It looks to be in good shape, and shows no sign of wear but the crank end play has be worried. Should I replace this as well?
Second question.
Seems to be two types of timing side bearings.
The original BSA version which is VP23 Copper Lead Lined Strip, and are super cheap, Appears to be original`
Then there are ones that are solid brass made by Kibblewhite
and finally ones that are steal with a brass insert. Steal/Brass
The problem I see with the second two choices is that they look a bit different from the bushing that is currently installed. There is a separate thrust washer on my setup, which seems to have been machined into these two types of bushings. Am I missing something here?
Any advice on which way to go on this?
With that said anyone know what the service limits are for the Crank on the timing side? My book does not talk about them I assume that is because I line bore the bushing to fit anyway. I know that is is Concentric but that is about it.
As far as the head goes I have that worked out. I could get one from eBay, there are several, my current head I just replaced the valves, springs and guides so I would hate to waste that and start over.
One last question, where do you guys source your parts in the us? Seems to me that British Bike Bits have the best prices since I do not have to pay the VAT tax being in the US.
Re: A65 timing side bushing service info needed [Re: Ron C] #704224
08/07/17 3:31 pm
08/07/17 3:31 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
I have no idea which type of TS bearing material is best, I believe its more important to get the drive and timing sides Concentric and also use an oil filter together with regular oil changes.
Re: A65 timing side bushing service info needed [Re: Ron C] #704228
08/07/17 4:11 pm
08/07/17 4:11 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
The bushing is bronze, not brass. The steel backed one is preferred because it is more rigid, just like the rod shell bearings.
The service limit on the crank is what is available in under size shells. Since shops did not just clean up the journal and bore the bush to fit originally there were only two main sizes available. A10s have a smaller main so you could easily go less than the -0.020"
Is this originally a ball or roller drive setup? The roller has a cup with shims with a thrust washer inside the timing bush (separate piece) to set the end play. Ball does not need any of this. There are different case widths between the two.
Aluminum rods work fine and last for years if not used for racing. Make sure the drive side has the small bleed hole.
You have to see which is cheaper, another head and valve work or welding/machining your head. I am not sure there is the need for the small through hole and split pin in the rocker shaft mount. The oil is going to be sprayed around from the ends of the rockers and flung off the springs anyway. Plus the rockers are drilled to the pushrod pin to feed oil there (maybe not on early rockers?)
Re: A65 timing side bushing service info needed [Re: Ron C] #704232
08/07/17 4:20 pm
08/07/17 4:20 pm
melbourne florida
bodine031 Online content
bodine031  Online Content
melbourne florida
6+ years on my 64 Hornet engine. Kibblewhite bronze bush. Valvoline 60wt "R",MAP oil filter, Uses a Trident filter,Small oil cooler. Single carb head with 32mm kuni, Boyer with 3 ohm dual tower dual fire HD coil, Solid State Reg/Rect. Always ride it 7-10 miles get oil to temp and I don't beat the [censored] outta it cause I don't want to fix it. Bike is reliable and used 3-4x's a week
PS I have a spare 68-72 T-Bolt head bare and in nice condition. you are welcome to if you want it N/C
Re: A65 timing side bushing service info needed [Re: Ron C] #704250
08/07/17 8:39 pm
08/07/17 8:39 pm
bon Online content
bon  Online Content
With all the trouble these bushes cause, why not spring for an end-feed/roller bearing conversion and forget all about it ?
Re: A65 timing side bushing service info needed [Re: Ron C] #704430
08/09/17 2:39 pm
08/09/17 2:39 pm
Bolton Lancs UK
Andy Higham Online content
Andy Higham  Online Content
Bolton Lancs UK
I agree the end feed/roller conversion is the ideal course of action.
I have to disagree about the bushes, the 2 parts of the 2 piece bush are not located not located relative to each other. The inner can creep inside the outer blocking the oil holes, starving the bush and the big ends of oil with disasterous consequences. Don't ask me how I know, even after 30 years it's still raw.
1955 BSA B31 400cc "Stargazer"
1962/67 Greeves 350cc
1967 Greeves 360cc Challenger
Jawa 500cc grasstrack
Re: A65 timing side bushing service info needed [Re: Andy Higham] #704431
08/09/17 3:03 pm
08/09/17 3:03 pm
Ron C Offline OP
Ron C  Offline OP
Perhaps I have not poked around enough on the end feed, bearing conversion. Are there any links you can point me too. I am not too interested in sending to SRM or another shop. I would rather do the work myself, that is why I was going the bush route.
Re: A65 timing side bushing service info needed [Re: Ron C] #704437
08/09/17 4:36 pm
08/09/17 4:36 pm
Texas, USA
Ray Elliott Offline
Ray Elliott  Offline
Texas, USA
Ron - I've not done an SRM conversion (NKIB 5907 C3 bearing) but have done one using a NKIS30 C3 roller bearing. I wasted 3 crankshafts getting it correct, but it works very well. Hopefully you're a far better machinist than I. Rather than weld the inner timing case I machined a block that screws in place. The block holds the oil seal around the crank quill & I feed the oil externally.
If you'll PM me I'll gladly send you pix & my procedures.
Ray Elliott
Re: A65 timing side bushing service info needed [Re: Ron C] #704440
08/09/17 5:15 pm
08/09/17 5:15 pm
ca, us
DMadigan Offline
DMadigan  Offline
ca, us
Why waste time and money on an end-feed/roller bearing conversion and go for a full roller crank and rods with 90 degree offset, steel rods and three main bearings? I am probably the only one stupid enough to do this but it solves a lot of deficiencies.
In reality, the bush will last a long time if done right with adequate filtering of the oil and is slightly cheaper.
Re: A65 timing side bushing service info needed [Re: DMadigan] #704445
08/09/17 5:28 pm
08/09/17 5:28 pm
Ron C Offline OP
Ron C  Offline OP
The biggest reason I decided on the bush route because if done correctly, which I am confident I can do, will last and the motor will be reliable. With that said, it might be worth picking up a second motor to play around with.
Re: A65 timing side bushing service info needed [Re: Ron C] #704459
08/09/17 7:18 pm
08/09/17 7:18 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
Regarding the end feed conversion, there's an interesting article On this Site which describes one of the variations on how it can be done.
My own personal opinion is that the original setup is adequate if you ensure most of the following are present:-
- an oil filter is fitted (commonly in the return line)
- an alloy sump plate with magnetic drain plug is used
- the oil is suitable (e.g. 20W50 classic type with API rating no higher than SG or synthetic motorcycle equivalent such as Mobil 1 V Twin)
- the oil is changed at regular intervals (probably every 1k miles for mineral)
- the OPRV is the later piston type rather than the earlier ball and spring variety, this helps maintain better oil pressure
- the crank sludge trap has been recently cleaned, these have a habit if filling rapidly unless an oil filter is fitted
- the crank is correctly shimmed to take up end play if a drive side roller is being used, a shim cup supposed to be fitted between the DS roller and crank to ensure exact end float
- the TS bearing is Concentric with the drive side and the TS journal has the correct clearance with the bearing
- the oil pump is operating efficiently with no leaks, preferably using a later DD type or iron bodied, see BSA A50/A65 installation tips At this Link
Converting to an end fed crank is certainy a good idea, however I believe the original setup will work OK if detailed attention to the above is made and this has been the approach I have taken over the last few years. All has been OK so far after admittedly only a few thousand miles.
Re: A65 timing side bushing service info needed [Re: Andy Higham] #704480
08/10/17 12:19 am
08/10/17 12:19 am
Rich B Online happy
Rich B  Online Happy
BSA made a change to install a dowel to the 2 piece bearing to retain the inner bush to the outer steel housing. The early unit twins did not have the dowel. Service bearings for the early unit twins (62 - 65) have an updated P/N that have the dowel.
Not all aftermarket bearings have the dowel installed.
I would not run a 2 piece bearing without a dowel. Not if they fail, but when
Re: A65 timing side bushing service info needed [Re: Ron C] #704513
08/10/17 12:15 pm
08/10/17 12:15 pm
Ron C Offline OP
Ron C  Offline OP
Another question to ponder. I am currently running the late model DD pump. It is worth an upgrade to an SRM. From what I understand they use the same internal parts, just have tighter tolerances on the pump body and is less likely to warp. The DD pumps seems to in workable shape. I have had it apart and there was some contact between the internal gears and the cover plate and it tended to bind up when the pump screws were tight. I moved a bit of material from the internal gears to resolve that issue and now there is no binding, so I assume it would pump as normal. It was pumping over 50PSI when the engine was cold.
It the SRM really worth the upgrade?
Re: A65 timing side bushing service info needed [Re: Ron C] #704531
08/10/17 3:45 pm
08/10/17 3:45 pm
bon Online content
bon  Online Content
http://bsa-a10.hailwood.com/mybsaa10rollerconversion.html
Re: A65 timing side bushing service info needed [Re: Ron C] #704539
08/10/17 4:40 pm
08/10/17 4:40 pm
Farnham, Surrey, UK
gunner Offline
gunner  Offline
Farnham, Surrey, UK
The SRM pump is certainly worthwhile if you can afford one although I'm led to believe the flow isn't that much greater than original.
Some alternatives to consider:-
- try and find the iron bodied pump as used by BSA from 71 onwards. This pump is rare but was the best of all the A65 pumps.
- It is possible to make the alloy pumps work OK and there's a really good write up on the E&V website on how to install and check your pump, see This Link which explains how to simulate running and visualise whats going on with the pump in situ.
Re: A65 timing side bushing service info needed [Re: Ron C] #705317
08/17/17 4:54 pm
08/17/17 4:54 pm
Ron C Offline OP
Ron C  Offline OP
Few more questions. My original plan was to have a -0.01 under bush line bored to my crank, According to my machinist that is not enough, due to misalignment. Since this is a 1965 A50 those bush's are different then the 66 and up. So I am on a search for a -0.03 bush, as quick as possible. Not much luck finding anymore smaller then 0.02 under. These are all Alpha bushings and are limited to 0.02 under.
I see the kibblewhite bushings will go down to 0.04 under, but when I look a those they list the same bush part number for both pre 1966 bush and post 1966 bush. Has to be a typo right? They do not have a real contact number so I can not speak to a real person there, so I can not ask them. but how is it the Kibblewhite bushings span Pre 1966 and post 1966 models?
Any other suggestions?
Re: A65 timing side bushing service info needed [Re: Ron C] #705319
08/17/17 5:08 pm
08/17/17 5:08 pm
gavin eisler Online content
gavin eisler  Online Content
A badly worn crank TS journal can be ground down and fitted with a harder sleeve to bring it back to std. Before SRM took over from Devimead with the roller conversion they used to offer this service. Is the TS bush miss-aligned or is the crank journal still oval?
Check your cases are a matched pair, on the lower mount castings there are 3 digit numbers on each side , these should match, if different you have a non matching set of cases and this might explain the miss alignment.
Re: A65 timing side bushing service info needed [Re: gavin eisler] #705320
08/17/17 5:17 pm
08/17/17 5:17 pm
Ron C Offline OP
Ron C  Offline OP
The Crank is with in spec it is 0.0002 out from inside to out. The problem is the 0.01 under TSB that does not have enough meat on it to make alignment. I talked to Kibblewhite on the phone and they assure me that their bush will work for a 1962 thru 1970 A50. Everything I see says they are different bushings but these are also the Alpha bushings. So I am hoping kibblewhite knows what they are talking about. Either way I will know tomorrow
Re: A65 timing side bushing service info needed [Re: Ron C] #705395
08/18/17 2:54 pm
08/18/17 2:54 pm
melbourne florida
melbourne florida
Yes they do
Re: A65 timing side bushing service info needed [Re: Ron C] #705400
08/18/17 4:19 pm
08/18/17 4:19 pm
Ron C Offline OP
Ron C  Offline OP
I just received the bushing that the sales rep from Kibblewhite promised would work on a 1965 A50, and it is not even close. Wasted that overnight charge. The outer diameter for the TSB is much larger for the 1965 and earlier models.
Bummer
Re: A65 timing side bushing service info needed [Re: Ron C] #705417
08/18/17 6:42 pm
08/18/17 6:42 pm
John Healy Online content
John Healy  Online Content
I have been following this thread because we distribute Alpha BSA timing side bushes (up to .030") for the A7-A10, up to 1965 for the A50 - A65 to 1965 and for the 1966-up for A50 - A65.
Watch this , https://www.youtube.com/watch?v=Lg5AcTqq_9g its an A10 but the set up is the same.
I sat through this video, and sat while he bumbled around. He makes two omissions worth noting. First he assumed that when you lay the drive side crankcase on the table, that the gasket surface for the timing cover is parallel to the crankcase center line surface. They rarely are and can effect the outcome.
Also, the surface of the crankcase mouth where the cylinder sits is rarely square to the center line of the crankshaft. Relying on either of these two surfaces to square up the crankcases can lead to poor outcomes. I have found it is wiser to rely on the crankcase parting surfaces to square up the case to the table.
Then with the timing side crankcase strapped to the table and the parting surface clocked to the table you can center on the hole for the bush in the in the timing side crankcase. Then drop the drive side on, securing it to the timing side case and clock the drive side bearing - if everything is right you should clock "0" with your dial indicator on both the x and y axis.
If it doesn't clock "0" either your machine arbor wasn't squared to the table properly, the cases are not squared to the table properly, age and stress has caught up with the cases (aluminum cases sort of drift around with the aluminum aging process and stress), or the factory screwed up.
Re: A65 timing side bushing service info needed [Re: Ron C] #706597
08/29/17 2:52 pm
08/29/17 2:52 pm
Ron C Offline OP
Ron C  Offline OP
Wow, what a difference a non wore out TSB makes. Oil pressure pegs my 50PSI pressure gauge continuously. Incredible how quiet the engine actually is now. What I thought was valve train noise must of been the bottom end.
Thanks to everyone that offered advice. Looks like I will get some ride time in before the leaves begin to change.
Page 2 of 2 1 2
