blackhallr
blackhallr
north east england
39 registered members (Bart223), 246 guests, and 416 spiders.
FireGuyKC, spuggy, Vinny Cotroneo, KeithM, Mridul Handa
10285 Registered Users
Stuart 97
Lannis 62
634,097 mail-order LSR
Topics67,352
Posts653,918
Members10,285
My tappets don't fit #705072
08/15/17 2:52 am
08/15/17 2:52 am
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Ordered a new set of tappets from LP Williams, 3 of them fit, 3 of them are too tight and bind in the holes. I can switch them around in different holes and it doesn't matter. I tried miking them and I couldn't come up with much of a difference in the diameters. What to do other than return them which will sit project back.
1978 Bonneville T140E
1974 Trident
1970 BSA Thunderbolt
1971 Norton Commando
1973 Norton Commando
1974 Norton Commando
2004 XL 1200R Sportster
Re: My tappets don't fit [Re: htown] #705155
08/15/17 8:49 pm
08/15/17 8:49 pm
Magnolia, TX
htown Offline OP
htown  Offline OP
Magnolia, TX
Took it over to my local machine shop. The stem on the tite tappets measured one to two thou larger than the ones that fit. They reamed the bores larger to give .5 to 1.5 thou clearance.
1974 Trident
Re: My tappets don't fit [Re: htown] #705177
08/16/17 12:56 am
08/16/17 12:56 am
kevin roberts Online content
fefsa
kevin roberts  Online Content
fefsa
i had the same problem with some kibblewhite tappet blocks i put into my T120. thee tappets fit fine before i installed them, but the blocks compressed just enough afterwards for several of the tappets to fail to slip into the bores freely. i had my machinist ream the inside of the tappet blocks very slightly and they've been fine.
i have no idea what i'm doing.
Re: My tappets don't fit [Re: htown] #706366
08/27/17 10:02 am
08/27/17 10:02 am
Kenya
Peter Gee Offline
Peter Gee  Offline
Kenya
Polish the offending tappet stems with 1500 or 2000grade Emery strips cut to size, using the correct "belt pulling" technique and fit by trial, one by one. I have a stand mounted vice. I put the tappet foot in a soft jaw , then with a emery strip and a drop of light oil, walk around the vice slowly whilst simultaneously and continuously pulling back and forth on the strips. keep stopping and checking against the tappet block itself. Should work fine
